Greetings to all,
I have a 2015 High Country 1500 6.2 litre late model production (Sep 2015) and would like to install OEM tow mirrors and keep the functions that I presently have with my factory mirrors. According to the Harness Doctors explanation I have the DL3 mirrors that came stock with my truck.   Could you guys suggest what OEM tow mirrors(GM Part number maybe) also, would I need a special harness from the Doctor to make them work ?? Thank you for your help and answer.
Best regards, Joe
15 hours ago, Joey's HighCountry said:
Greetings to all,
Best regards, Joe
Yes, you'll need a harness to make them work properly.
Here is a thread about that.
If you go here:
https://www.gm-trucks.com/forums/profile/159655-pgamboa/
and message him, he will let you know everything you need to accomplish you goals. I purchased the mirrors, switch and harnesses from him. Stand up guy that loves to help. I went from having factory mirrors that only had defrost to power folding tow mirrors with blinkers, reverse lights and running lights.
Thank you very much, and yes indeed, I've contacted Phil the Harness Doctor and he is definitely the doctor which is a very well deserved title.  Looking forward to getting all the components from him.  Thank you very much for your input.
    • It really is comical when people don’t agree or see the reason some people prefer the older vehicles. They become condescending. All the while they may be busting their knuckles on old vehicles. I have found memories of swapping out engines in my old GM cars in a weekend without much hassle. Unlike today. One wrong move a computer will shut you down. Even on something as easy as a brake job. There’s a pretty comical YouTuber called the car wizard. A garage owner who puts it all in perspective. Another Vicegrip garage that’s shows just how tough the old stuff is.
