On 4/1/2022 at 1:52 PM, JONBLARC7 said:
Very nice build.  I have the same TSP cam in my L86 with some porting on my heads.  I hope to have boost soon but I just had to pull the engine mysellf from two spun rod bearings.  So I had to spend my boost money on pistons and rebiulding the engine.  It's almost back together.  It's just hard to get parts right now.
But hey now I have a new crank with Forged Diamond pistons on stock rods.
I'm curious how you like that cam with boost?
Thanks! Oh wow, I'm sorry to hear that. Sounds like my lifter situation. I went ahead and did a full rebuild as well. The ARP bolts and studs aren't cheap. Spent over $1500 on bolts and studs from ARP. Bought every bolt they offered.
That's right. You'll have a built engine ready for alot of power.
The cam works flawlessly. I was worried about it with boost as well but it really helped spooling the smaller turbo that I had. Now that it's a bigger turbo, it spools a tad slower but I prefer it to not boost at lower RPM's. With the TSP stage 2 cam with the bigger turbo , I begin spooling around 3000 RPM's. I am fully spooled by around 3500 RPM's.
Rad build!  I'd love to boost my 6.2 but cringe having that much tube & snail under the truck (but I understand your logic).  I have my truck offroad quite a bit and know full well that I'd crunch something that would shut me down.
Obviously you have the background and skill but what made you go turbo as opposed to supercharger?
Cheers!
Cheers!
There are plenty of options for boosting these trucks. If you off-road a lot, having a PD blower (something like a magnuson TVS2300) would fit nicely.
On 4/12/2022 at 1:58 PM, Regan Menzies said:
With the VS Racing Billet 75/65 turbo, it made 505 WHP at only 7 PSI. The graph showed how restrictive the turbo was in the higher RPM's due to the smaller turbine so I swapped the turbo out for a On3 Billet 78/75. I plan on putting the truck on the dyno again this weekend.
What muffler are you running? The turbo sizing doesn’t sound tooo bad but with a baffled or chambered muffler, it’ll act like the turbine side is too small and choke up the exhaust.
what brand intercooler are you running?
Cheers!
Thank you. It's a fun truck for sure. It tows very well too. Fortunately for me, my truck stays on the road or trails. I don't do any mudding with this truck. I wouldn't do a rear mount turbo if I was using this truck to go into the mud unless I snorkeled the intake up into the rear fender or even better, put the intake through the bed under a bed cover. As for the piping and everything else, if you have never dented your driveshaft or your frame, you won't touch the turbo setup. It is tucked high and out of the way. It really depends what you want to use the truck for. One build will always have its pros and cons. The debate for turbo vs supercharger also depends on what you plan on using the truck for.
I prefer turbo over supercharger any day. The benefit of supercharger is the ability to have boost at any RPM. This is also a con. Having more torque at lower RPM's is harder on engines. Supercharger consume alot of HP to make HP. Therefore, Superchargers will also get worse MPG.
With turbo, you are using energy that your engine is already producing. Turbo's need higher RPM's to spool up. Once the turbo is spooled, it remains spooled until you let off the throttle. If you're driving on the road at 40 mph and floor it, it may take about a second to spool back up. Even with a rear mount 78/75, I am fully spooled at 3500 RPM.
I would only supercharge for ease of installation or all out drag racing.
My exhaust after the turbo is an inch bigger than the turbo outlet and it's only about 6' long. I am using a Magnaflow straight through 4" In & Out. The turbo wasn't small if I wanted to keep it under 4500 RPM's. It's the smallest turbo that I would recommend for a 5.3. The exhaust side was choking it. Now the truck is a different animal but I'm still keeping the boost around 6 PSI to keep it at 500 WHP to keep my trans from slipping.
Edited by Regan Menzies
It's an off brand delta core. I chose delta core because I've seen many reviews and tests that have proven them much more efficient than flat plate.
    AidenVorpagel
    AidenVorpagel
  • Who's Online   2 Members, 0 Anonymous, 504 Guests (See full list)
    • Can it still be Assembled I?    Stribeck says that we need a certain amount of viscosity under conditions of load and velocity to prevent two surfaces of a know roughness from tearing each other asunder. And we have marketing trying to tell the masses that those two surfaced require less of that commodity due to more exact limits being placed on the same old clearances. We also know that there are limits to how hard something can before it becomes to brittle to be viable and to smooth to 'wet' the surface and that both of those conditions have been known and met since about the Second World War.    That viscosity value shook out at 10 centistokes at 212 F just under a hundred years ago.  Give this a look: [Anton Parr]     What is advertised is the Kinematic viscosity (mm2/s) or that which has been density adjusted but the value we are after is the dynamic viscosity (mPa.s) or true viscosity. You can see that this number is dependent on density thus base stock and temperature. You can also see that an SAE 30 doesn't reach that value in this example. However an SAE 30 that is at the upper end of the SAE 30 range; 12.5 cSt (mm2/s), might. 12.5 * .83 = 10.375 (mm2/s). If you could find an SAE 30 at the upper end these days.   Then there is the complication of viscosity modifiers or VII or VM, whatever you wish to call them. Polymers added to very thin base oils, perhaps 3 to 6 cP oils, that will meet the SAE *W30 spec at 'tested' shear rates and 100 C/212F  target temperature. So a polymer fortified base that is a fraction of the 10 cP requirement Stribeck insist upon.   This could be all well and good if those polymers didn't have two very problematic 'features'. They shear or loose viscosity both 1.) permanently and 2.) temporality. And they do both omitted in the advertised data with the distinct  purpose of deceiving the consumer of the actual operating state of the fluid. I've shown the example of Warren Oils COSTCO 10.91 cSt 5W30 formuation several times where the 100 C HTHS value is 6.9 cP!! That's the temporary shear down and with and SSI or shear stability index of 9.4 cSt. Note the intentional deception in using mixed units?    After a short while that 9.4 cSt oil has a viscosity corrected dynamic value of 7.8 cP. But as the SSI is still within the range of an SAE *W30 whose lower value is 9.3 cSt.    This allows them to continue to call this SAE 16 weight oil a 30 weight, the cake, and still meet the API requirements for fuel efficiency IMPROVEMENT mandated by the EPA. The eating of the cake. By the time you've worn out your motor doing the responsible thing by adhering to the warranty requirements, (the stick), you get deprived of the carrot, wear control. So sad, to bad.   So what can be done? Do I need actually say? [Anton Parr]       Even this must be monitored if the oil is on the low side and the VII an organic or you opt for a 0W40 with an even lighter base oil and more / higher MW VII. (Note the lower density of the 40 weight versus the SAE 30 mono-weight?)    There is another workaround. Temperature. An SAE *W30 run at a bulk temperature of between 180 and 195 F.    Being the belt and suspenders sort I am I do both. Run it cook and run it heavy.    In Part II I'll work the AW package.
    • So, do I go elbow-deep on this thing or list it for sale and play dumb? Seems to "runs good."   I'm about $1200 away from having: -a rebuilt injector ($300) -a new cat ($250) -a new cat back exhaust (OE style) ($300) -a new AC compressor ($200) -AC refrigerant charge ($150)   In theory, this should rectify the obvious detracting issues from its value and operability. Cold AC with a non-squeaking AC pulley both sounds and feels good. An exhaust that isn't cut/hacked in 17 different places and doesn't vibrate on a crossmember would make it sound and feel less janky. A working cat would help the stink, and will save the earth, but *if and only if* the fuel system is working properly, which would also address the intermittent "rich" CEL.   Heard a good one... CEL for "Rich condition" means you haven't spent enough money on the truck lately, and it's letting you know.   Rebuilding the injector would seem to be the most important part. Replacing the cat would be secondary. I don't think mine is plugged or overly restricted, but it might be a little restricted? I have no good way to tell other than seat of the pants feel. I hate the smell.   The current theory is I have a rich idle problem: A bad fuel pressure regulator, or a leaking injector(s) being the highest probabilities. I already replaced the FPR but that doesn't mean its replacement isn't also bad. It was a new part from Dorman, but the packaging looked like it had been sitting on a shelf for 20 years.   This is the (single) upstream O2 sensor shown at idle. I'm getting a lot of "rich" it seems. Sometimes it stays high like that and doesn't drop down. That makes me think it's processing injector leaks or a partially stuck open injector.     Other times it looks like this. Nice oscillations between rich and lean, which is what I think it should be. Under load and at speed, the oscillations are nice and tight and uniform looking, high and low.     Fuel trims suggest the PCM is compensating pretty hard at idle to pull fuel out. But it's not enough to trip a CEL. Something about slowing to a stop: brake vaccum booster, EGR, or the EVAP purge is delayed, or there's pooled fuel in the intake again that's draining into a cylinder is enough to set the CEL. Of course, in two days of driving, it hasn't set. I was hoping to actually look at the freeze-frame data when it sets. IAT is high because it's idling on an 83 degree day here.
