  • apologies if this isn’t the right thread on forum
Was having problem with my truck starting. So got a new battery and it fired right up.  Like 30 mins later check engine started flashing.   And seem to misfire   , then when I stopped in my drive way. It went from Blinking to steady Light.   To off.   Then back on to steady ,    Drove down the street. It started flashing again.
now this truck has 220k miles.  So it could be a number of things.
many advice ( on a budget , cus I wouldn’t be riding this if I had $$ for a new one 1). Lol
many where I put new battery it just reset everything and chances are it could work itself out after driving a while ?   I’ve read that ,
Or disconnect battery and a while and try again ??
  But other then trying that.   Any advice ?   Or anyone else had this issue ?
thanks a lot.   Any replies would be greatly appreciated 🙏
Check and make sure every cable is TIGHT and its connections clean. If there was a bad connection inside, it may have got worse by handling it during the battery swap. Voltage drop test both cables while it's cranking -  you'll need a helper. Anything more than 250mV and I'd replace the cable. But, make sure the terminals are tight FIRST.
If that all checks out, look around for any wiring that might have got tugged on and damaged, or any connections that are unplugged or not together tight.  If after all that you're still having misfires, you've got nothing to lose by disconnecting the battery for a half hour or more, and reconnecting it later. And if that doesn't work, start from the beginning diagnosing a misfire - check for good spark, fuel pressure, intake leaks, etc..
Thanks so much.  I did take battery off again. But not for 30 min.   I jus see it blinks when driving sometimes.  Not all.    Then will be a regular engine light when stopped
Blinking light means it's a catalytic-converter-melting misfire. I wouldn't drive it if at all possible until you get this figured out, unless you live where they don't do emission testing - in that case it won't matter. If the cat melts, just punch it out and move on.
The way you describe this sounds like an intake manifold leak. Under part-throttle cruise when vacuum is highest is when they'll leak the most. Common cause for a P0300 random misfire code. You can check for that by using a soda or water bottle, punch a small hole in the cap, and squirt water onto the gasket mating surfaces between the head and intake manifold. Any changes in running, or to fuel trims while watching live data on a scan tool, and you found the issue.
EDIT to say, also check to make sure a vacuum line didn't somehow get knocked out of place or torn in half.
Edited by Jsdirt
No they don’t check emissions around here.    But I’m lost on tine bottle water trick.    Po 301 I got codes P0449  and P0455. On the check at auto zone.  That says cylinder 1 misfire.
Edited by Tipsey Hussle
So you have a P0301? Yes, that's a cylinder 1 misfire. The other 2 are EVAP codes.  Not a problem unless that vent is sucking air in and leaning out the mixture when the purge valve opens.
Find and fix that misfire, and you'll be good. Doesn't have to be a water bottle - just get water onto the gasket surface. But skip that for now since you've got a specific cylinder with a miss. Troubleshoot that first.
    • Howdy folks,   Recently I pulled a heated steering wheel and clock spring out of a 2015 Sierra All Terrain (part numbers coming soon - will have to disassemble), and just installed it on my 2016 Sierra WT (as base model as it gets).   On install, I noticed that I’m missing the connector often tucked behind the dash for the heating element.     No problem… or so I thought.   I used an “Add-A-Fuse” at my heated steering wheel fuse location, which has voltage, but no wires. I ran it to the positive of the heated steering wheel (Violet/White), and took black to ground.   Hooked up the battery, turned the truck on - no heated steering wheel. No button backlights. Was pleased to see that my cruise control was working though.   Read a post suggesting reversing polarity, so I gave it a shot. Violet and White to ground, Black to power.    Aha! Heat! But I seemingly can’t turn it off AND still no backlights on any of the buttons.    Checked all fuses, everything is still in good order. I’m stumped.   Does anyone have any insight? If so, please share!
    • I'm about 1800 miles into my last oil change, and yesterday a message appeared saying oil life was at 77%. Not sure why it popped up but I think all of these electronics could be susceptible to solar flares or somesuch. I change my oil right at 3K each time, and that was the first time in 10870 miles that message came up. Strange thing is that it showed on the screen at all since I don't drive with that sort of info displayed on the DIC.
    • I’m praying that someone sees this and can help me out… pulled a heated steering wheel and clock spring out of a 2015 Sierra All Terrain, and just installed it on my 2016 Sierra WT (as base model as it gets).   On install, I noticed that I’m missing the connector often tucked behind the dash.     No problem… or so I thought.   I used an “Add-A-Fuse” at my heated steering wheel fuse location, which has voltage, but no wires. I ran it to the positive of the heated steering wheel (Violet/White), and took black to ground.   Hooked up the battery, turned the truck on - no heated steering wheel. No button backlights. Was pleased to see that my cruise control was working though.   Read a post suggesting reversing polarity, so I gave it a shot. Violet and White to ground, Black to power.    Aha! Heat! But can’t turn it off AND still no backlights.   Checked all fuses, everything is still in good order. I’m stumped.   Does anyone have any insight? If so, please share!
    • Checked the pads today and there's plenty of meat on them. If the message keeps coming up, I'll just answer YES that the pads were replaced and wait for the squeal.
    • Welcome to the Forum! Always post the code definitions along with the codes. there are over 18000 possible codes, no one remembers them all and most will skip over your post rather than look them up
