Recently got a 06 Silverado and now the Transmission is slipping going into 3rd.
does fine 1st and 2nd.   No 3rd.   Then kinda just rides high in 2nd .
I’ve read this seems to be a problem with a lot of the trucks of this model.  This Trucks has 220k miles.  And the former owner said they don’t know when the last time fluid was changed.  That it was probably Atleast 50-60k ago.  If not more.
so my question is.   Would going to have the transmission fluid changed help this problem out ?   Or is it a waste of time and $$   , or the trans if probably screwed by now ?   That it needs a solenoid or other repair ?
Just seeing if anyone else had this problem or what there fix was ?  Or any advice on a budget.   Thanks 🙏
any replies greatly appreciated
Far as I know it never has.  But if fluid hasn’t been changed in who knows how long.  I didn’t kno if that may help a while.  Wasn’t sure.
Classic 4l60 failure. Not sure I would waste the time oe money on a fluid change. She's toast. I've had a couple go out with those exact symptoms.  Honestly 220k is pretty good for a 4l60. A couple of years ago you could get a rebuilt one for about $800. Not sure what they cost now.
What's the fluid level and condition?
What condition is the truck in?
Can you justify the expense of putting a transmission in it?
Edited by It's Tim
    • Thank You.   So far my new ride is making me look like a genius for going with the 3.0L, as my first fuel refill occurred over three weeks from when I took delivery.  This engine combination is very amazing.  So far no issues and had not done a regen yet.
    • I am curious as to how much fluid you put back in the transmission ( assuming you had replaced the filter to compare to my findings ) and then went through the process of warming up the trans before pulling the check plug to drain out the excess and if you measured how much came back out.    I just found it surprising that some claimed a certain amount less fluid being put in and then draining some back out. The attitude of the truck as per if the surface is level and how the trucks stance is would make quite a difference since the check plug is right at the front of the transmission.
