Yes I did I also had a vibration on and off on the highway and turns out there a TBN out on the oil used in the 8 speed tranmission paired with the 5.3 v8 they did a transmission flush yesterday and seems to be ok now
5.3L 10 speed?
Possibly related?
https://gm-techlink.com/?p=15387
Shudder Condition When Coasting to a Stop
September 30, 2021
Some 2021 Silverado 1500 and Sierra 1500 trucks equipped with the 5.3L V8 (RPO L84) and 10L80 10-speed automatic transmission (RPO MQB), excluding models with RPO YK9, may have a shudder condition when coasting to a stop between 15—13 mph (24—21 km/h). (Fig. 10) The shudder may feel similar to driving over rumble strips on the pavement when the vehicle is coming to a stop.
F10-shudder-2.jpgFig. 10
During diagnosis, the shudder condition will be easily duplicated every time the vehicle coasts at the affected speeds. The shudder may be due to the reduction in the number of cylinders firing during deceleration, which may lead to structure-borne noise, vibration and harshness (NVH) on some vehicles when coasting to a stop between 15—13 mph (24—21 km/h).
If the shudder condition at the affected speeds is confirmed, reprogram the Engine Control Module (ECM) with the latest calibration available. Do not replace any parts for this condition.
It will also be necessary to perform the Crankshaft Position Variation Learn procedure covered in the appropriate Service Information once the ECM has been updated. The crankshaft position sensor variation is used to calculate reference period errors caused by slight tolerance variations in the crankshaft and crankshaft positon sensor, which allows the ECM to accurately compensate for reference period variations and detect misfire events over a wider range of engine speed and load. If the Crankshaft Position Variation Learn procedure is not completed, the ECM calibration will not provide the desired results.
TIP: Always verify that the VIN displayed in the left-side drop-down menu in Techline Connect and the top-center window match the VIN plate of the vehicle to be programmed prior to using Service Programming System 2 (SPS2) for programming or reprogramming a module. (Fig. 11)
F11-shudder-1.pngFig. 11
Refer to Bulletin #21-NA-207 for additional information.
Just saw this thread. I've had issues with a slight vibration on the highway. I could feel it in the floorboard and steering wheel. Hard downshift from second to first coming to a stop. Some hard up shifts. I have the eight speed. Yesterday, took it in for oil service. Told the service writer what was going on. We took it on the road, and of course it wouldn't duplicate. Pulled in to the service lane and it did do the hard downshift. After explaining how that transmission works, he said it needed a fluid change.
I asked if that was supposed to have been done on all 2019s prior to sale. He said he would have it done anyway.
After service and on the way home, at 1.5 hour drive, it did seem to eliminate the vibration. But not the hard downshift coming to a stop. Called him when I got home. He again said it was the transmission design that causes the hard shift. Anyone else?
    • Google converting 98 4.3 spider injection to carburetor if all else fails.
    • That computer lies!
    • The truck is a 1995 Chevrolet S10 Blazer, 4.3 VIN "W" engine. :cracks knuckles:   On a whim - because I needed a headache - this truck was for sale so I stopped to take a look. Doesn't run. Well, it does, but barely. Long crank, choppy idle, bad misfire(s), it REEKS of fuel. I can DO this..I'm thinking. Diamond in the rough. One owner until last year. A young guy is selling it, he bought it 6 months ago. It stranded him more than once, he's got a newborn. It was in the shop 10 days ago and he "thinks" they said it needs a new fuel injection system. He can't put any more money into it, needs it gone. I was thinking of upgrading my Macbook, which is a total want, not a need. For less than the price of a new laptop I can have fun for months tinkering on this truck and enjoying it. I'm taking this truck home. The guy was beyond thrilled, his wife was there, she thanked me profusely, I could tell they were hurting. They seemed like good people in a bind.   Some parts, a wash, maybe a set of tires, and I can have a few months of fun and then turn it for beer money (or the next project).   Sure enough, there's a work order from a shop last week in the INCHES of paperwork on this truck dating back to when the first owner bought it. They put a new distributor in it, fuel injection work describes basically opening the plenum and putting it back together. He said he couldn't afford any more work so he had them button it up and that's when he put it up for sale.   I'm not well versed in 4.3. I did discover 1995 uses the 1992-1995 SCPI "Spider" injector which is riddled with issues from splitting lines, clogged or cracked poppet valves and plastic spider legs that crumble over time. Cool. I'll just order me a ne---. Oh, the auto parts store doesn't have it? Rock Auto doesn't have it. eBay? $$$$$$ for used. These are UNAVAILABLE period end of story unless you know "a guy" who's still got one in a box somewhere.   Can't upgrade to the '96-'04 injector, it's a different plenum, wiring/pinout and sensor config.   There are a few kinda "know a guy" -guy rebuild services for these injectors out there for about $350. Okay, Okay... I'd like to know if anyone has used them? Anyone got a lead on these crappy 92-95 spiders?   I also don't want to send MY spider to Narnia and back without knowing if that's truly the problem. I guess I'll need to pull apart the plenum and do some digging.   I was also thrown for a loop. This 1995 model year truck has an OBD-II connector. The interface is decidedly not OBD-II. I can read and reset trouble codes and view live data, but there's not a lot of data. Like misfire count and on what cylinder, that's not there. It's OBD-1.5.   Nothing is ever easy. Now it makes sense why this guy wanted to disappear this thing for cheap. I'm guessing the shop told him the injector is toast, the part is unobtainable and they're not going to sort sending the thing to a rando offering rebuild service on craigslist, and the kid likely can't be without a working car for 3 weeks even if they'd facilitate that.   Experience with these early SCPI's? Stories? Things to check? Sympathy? (..Nah...)   This can sit until I sort it. But I haven't had a problem with a vehicle I couldn't easily solve in a long time.
    • I have four that read by the dash 8 to 10% better than miles/pump calculations and I have one that is spot on.
Ă—
Ă—
