Does anyone else have an issue with their phone volume being reduced whenever you drive?  My iPhone resets it's volume to about 10% whenever I get in my 2020 Sierra Denali.
Yes, had it anyway.  In Sound and Haptics settings, toggle off "changes with buttons". I have no clue why this works and why GM designed the system to do this.
It happens with all iPhones on the new vehicles.  Like stated above, why they do it is unknown.  I'm sure there is a reason. To me if it lowers it, it also should go back to the way it was when you leave the vehicle.
I have the same issue on my iPhone 12 Pro and 21 Silverado.  Turning of the change with buttons didn't help.  My wife's honda does the same thing to the phone.   Volume damn near zero getting out of the vehicles.  IMO it is clearly and apply car play issue.
I don't care if it is a MFR problem or Apple issue, just find a solution together...
Edited by A321Driver
    Frank V
    Frank V
  • Who's Online   5 Members, 0 Anonymous, 1,150 Guests (See full list)
    • "Life is getting back to normal."    I'm driving again and all new joints are operating as expected for this stage of recovery.   My most recent joint replacement still requires a lot of attention but experience has taught me that time will quiet the remaining pain.  I joked with my surgeon that another joint replacement would take my mind off my most recent surgery and he responded by saying the next will be a hip!  There are no plans for another surgery but, unlike me, I don't think he was joking!  I certainly wouldn't refuse further replacement  if required but hope to spend time out of the "post-op"  period.  I can't stress enough that if you have been recommended for total hip, knee or shoulder replacement that you welcome the offer.  Post-op "recovery" may sound daunting and painful, however, this is far better than the insidious erosion of mobility you are currently experiencing.  Imagine what it would feel like to wake up most mornings feeling better and more mobile than you did the previous day!  Prior to my first surgery in June 2025, even getting out of bed was becoming a formidable task.  Since the day after my first surgery, I get out of bed everyday easily and unassisted.  Making the switch to feeling a little better each day rather than a little worse, is hugely motivating!
