I just purchased an 02 C6500 dump truck. Getting it ready for inspection.
I can't, and the dealers have been no help...find the high beam indicator in the dash or cluster.  The truck lights work perfectly.  The daytime running lights and indicator work. But, not high beam indicator...and no obvious location for it.
Can anybody help me with this mystery?
Did you pull the circuit board out? I would try and look up a youtube video of someone starting the truck and just guess game where it is if you can see it.
Is that really required to pass?
Thanks Tim. Owner's manual long gone. No less than 8 qualified techs, including me ( ase master,  md.state inspector...years ago) have looked. I wish it was that simple. I've had the cluster out, to change a bulb ( daytime running, that I thought was high beam indicator), and checked the other bulbs with a meter.
  So, in anyone has a c6500, or knows of one, and can clue me onto the location...I'd be much obliged ! Been to 3 dealers, no help. Spent hours on the web. Way more than this problem deserves. I'll likely fit a new lamp in...but I'd like to know where the manufacturer intended it..
Or was it missed? It would be a first to me.
Thanks
Yes, it's required. And to the best of my knowledge,  I've exhausted the web and YouTube.
Thanks
Just curious, because I enjoy learning new things about trucks, is it this one?
Or one of the newer style in the 2005 or so era?
See the source image
Found it!  It's in the block, just above the odometer.  Between ck gages and battery symbol.  The bulb tested good, but I replaced it, and it works.  You can't see it, period, from outside...shining a light. Myst have been a dirty connection.  It's marked high beam, on the back of the cluster, but I didn't see it first...I wasn't looking.
Thanks
Yes. Exactly
    • I use Amsoil's OE line of motor oil (5W20) in our 19 Hyundai Santa Fe. I noticed today on the web site it now says (47% more wear protection1 than required by the GM dexos1 Gen 2 specification). Maybe I  missed it but I don't think so.
    • The amount of storage in the rear seat area is huge. You can keep all your cycle gear dry and clean back there
    • Truck in fluid changes and investigate subtle shudder at cruising speeds.  Told them it felt like my ‘14’s shudder when AFM kicked in.   Dealer #1 :  You need a new torque converter.   6 weeks later, after causing other damages to my truck, I get the truck back.  Same shudder exists. New, more violent shifts and vibrations at low speed.  After choice words and a few more weeks of waiting for them to replace my running boards supports, I move on to another Dealer.   Dealer #2:  The cruising speed shudder is DFM.  (I didn’t realize truck had it.) The TCM/ECM needs updates.  Updates will solve all vibration issues.   They perform updates, truck seemed ok in lot.  Not a mile down the road, SERVICE BRAKE PAD MONITOR. Dealer #1 stated brakes were at 4mm.   took truck back to Dealer #2, rear brakes at 2mm and less than 1mm.     New pads/rotors on rear, new pads up front.   truck seems good. Toggle through menus, brake monitor system is disabled.  Huh?  Why? Turn that sucker on : SERVICE BRAKE SYSTEM!     will not reset manually, automatically, or even after pulling negative bat cable for 30min.     Could the TCM/ECM updates the culprit?    A torque converter diagnosis for a “normal” shudder and now I’m thousands in the hole and the truck still isn’t right!  Beyond pissed.
    • Your right on. 👍🏻
    • Seats matter a lot.  I would start there - good advise here.  I had a 2018 LT Colorado before my 2026 LT Silverado, and the seats are so much better in the new one it's not even a contest.  That was one thing I always hated about the Colorado and I owned two of them spanning 10 years - but I did it so I could park in the garage mainly.  Now I have a much larger property and a huge barn so I have plenty of parking options and a full size is more useful for maintaining the property and current hobbies as well.  I wasn't evenb thinking about the seats as part of the reason for the move to the Silverado, but after two back to back 700mile road trips I am sold on the LT seats w/ leather 100%.  The other LT features are also nice - one thing I really like is the power rear window on the back window by the bed.  And the lighting in the bed is also very nice to have - I doubt that comes on the lower models.  Power tailgate - also quite useful - it's a heavy slug!  What else - I could take or leave the screen - but heated seats and steering wheel and cruise control on the steering wheel is very useable - I would never want to live without that.  Even the colorados had that.
