Can the factory front camera be added plug and play, or is there more required?  Saw a video where a guy said they were plug and play and the wires were pulled to the passenger side kick panel and plugged in, he also showed pulling up the menu to add it.  Wondered if any type module is needed?
Do you have the link of the Video?  I would love to add the camera to the front end but I suspect you will need the upscale informat system atleast.  I have a IOR so I think I am out of luck but I would like to review the video for options.
I do have the ios infotainment system.  That was not the same video that I watched.  This is the one I watched, kind of confused a little as to whether the echomaster intellihaul module/system is factory?
Edited by shadow gray 2020 hd
The base InteliHaul system 2.0 is $1200
Add on Front Camera add on is $150
Add on Wireless Trailer is $408
I wonder if it will work with an IOR system, that does add up to a pretty penny.
Yeah, that would be a bit too expensive, would be better off adding a dash cam system with add on cam to the grill.  I don't see anything on my build sheet showing the intellihaul system, so don't guess I have it.  I do have the module for tpms.  Guess I may contact echomaster and give them my vin.
What did you find out?  I am the same way, I have TPMS for trailer but I don’t know about Echomaster
I never did contact echomaster.
I just got my truck today, and it's hella cold to the point I don't want to dive into it. So I really don't know what's all controlling stuff. My truck has bed view and two trailer camera provision, and I don't know how signals are processed in an OEM way. I would like to add a front camera, also.
I noticed White Automotive has (V)ideo (P)rocessor (M)odule programming. So clearly there is hardware, but IDK *what* functions it controls-maybe anything from a simple low-res backup camera to HD Surround Vision (programming and hardware-dependent). I couldn't imagine there is a separate VPM for certain functions and an EchoMaster VPM for other functions. So I wonder if EchoMaster is providing the VPM to GM AND selling it for aftermarket installs.
I will probably contact WAMS at some point and see what's possible. Don't know about sourcing side-view cameras on mirror bottom, as I don't see EchoMaster offers them separate (in the event the OEM VPM can accommodate the other cameras). Or if someone else finds out, I'd sure like to know.
    • Can it still be Assembled II?   Viscosity on the decline by various means. Heat on the rise making that worse. Engine RPM in the tank. Smaller motors with more boost trying to emulate an electric motor. Full torque, zero rpm. Then we will triple the OCI. Argh.    But wait....there is more. LSPI has pushed a shift from Ca to Mg and as that cost more PLUS the run to lower sulfur compounds the TBN is moving in the wrong direction for the increased OCI's demanded.    That not being enough to placate a demand for a parameter they can't measure the other sulfur bearing compounds are also under attack. That would be zinc and phosphorus sulfonate compounds. To some degree those are being replaced with boron esters and others, i.e. titanium ect. All of which have shorter service lives. And there there is the "Secrete Sauce" marketing for AW adds that 'Can't be detected by UOA's" but trust me because I (the blenders) never ever lie.    Spoiler alert; ALL additives are sacrificial! Smaller amounts of the old blended with less robust versions of the new do not equal longer service lives. So what are the blenders recommending? Wait for it.......   MOVING THE GOAL POSTS! OMG      Let's declare the long standing TAN/TBN crossover irrelevant and tell people that soot is a great 'graphite' based lubricant which can aid tribo films. Wait, what? Let's declare that the standards used for oxidation and nitration were to conservative and can be expanded. Let's tell them that because GDI fuel dilution, although being a VISCOSITY KILLER and an acid generator is actually okay because we have better base oils that limit viscosity failure limits. (Said knowing this is measured in fractions of a centipoise and in bases not commonly used in shelf oils)   Lying from the heart is not just the new normal but we have a public, a very young public, that is so ignorant of the facts and so sure of their "RESEARCH" into AI driven models base in regurgitated  instead of scientific research based unvarnished, peer reviewed FACTS that the incoming guard is loosing their grip on reality and the OEM's are tickled pink while the blends bend the knee.    You have an ever limited set of tools to work with. And sooner or later those will be taken from you as the API and the EPA strangle the last remaining fluids from the system. What you have left is your wits. If you care to use them.    At some point in the very near future it will not longer be possible to do "What is best for the machine", and be replaced with "The best you have access too". You WILL be rewarded with half the life and twice the cost. That isn't that hard to predict.
