Hi all,
Truck is a 2017 Sierra Max Trailering edition with the 6.2, 8 spd and about 34,000 miles on it.
I bought the truck in 2019 and have taken it in 4x now over the last 20,000 miles for clunky shifting.  I had the shuttering issue early on, but that was fixed.
Now under low throttle, when in traffic, or leaving my driveway on a downhill...the truck likes to clunk into 2nd gear.  It's not every time, but I feel like it happens at least once per trip but only under light throttle.
This morning as I was coasting up to a light, it turned green and it slammed so hard into 2nd gear that the tires chirped.
How are you guys handling a dealer that can't replicate the hard shifting/clunk into 2nd gear on the 8 spd?  I love the truck but quite frankly, this crap is getting old.  I'm worried about premature failure, etc - though the tech at the dealer has said "You have a paper trail"....but I trust that as far as I can throw him.
If yours were mine I would data log until the issue replicates and then show it to the dealer/technicians.
We had a banging issue with a FWD transmission once.  It was the input clutch piston.  The tech could not replicate, so we put him in the car and had my wife drive it and before we even pulled onto the road, it was replicated and he knew what it was.  His driving style, my driving style could not replicate the issue.
MDI2 adapter connected to a laptop running GDS2 software.  There are other less expensive options if you research or ask around.
You did not say what has been during those visits, or how the shuttering issue was fixed by the dealer.
Have they swapped the fluid to the new one?
Hi, sorry about that.
1st visit was a "relearn" - I guess they reset the TCM and let it relearn my driving style?  Shutter issue happened a few months later on a road trip so I took it in for visit #2.
2nd visit was a flush and new fluid - shutter was gone, but it still had the occasional hard shifting.
3rd visit was a flush and new fluid - still hard shifting about once per trip.
4th visit was nothing - they couldn't replicate the issue so they did nothing.
  • Thanks 1
I hadn't thought of that.  I don't know much about data logging but I'll look into it.
    ChristopherDobson
    ChristopherDobson
  • Who's Online   5 Members, 0 Anonymous, 1,296 Guests (See full list)
    • Thanks newdude!  By the time manual selection is needed, I'm probably too much of a control-freak to depend on the transmission sensing braking to activate automatic downshifting.  I would be anticipating the situation and already be manually downshifting.   This truck replaced a 2004.5 LLY diesel with the Allison 5-speed.  Putting it in T/H made noticeable differences (when the torque converter locked, upshift points, downshift behavior).  On this 2024 gasser with the 10L1000 I haven't been able to detect much, if any, difference.  Ok, I can never tell now when the torque converter locks up.  But I also don't notice differences in shifting.  For downhills, I've probably already manually downshifted by then anyway.  Since it's also more awkward (than the 2004.5) to engage/disengage I don't even bother.  Or maybe it doesn't really matter with just a 3k lb. camper in the bed?   Thanks also for the list of reasons the charging system might select various voltages.  However, what I am seeing doesn't fall into any of those categories.  It very definitely, and very consistently, rises after coasting/braking.  Maybe not immediately, but not very long after coasting/braking.  Very consistently drops voltage when no longer coasting/braking.  It might also be interacting with the camper battery charging (I might disconnect the camper and see if it changes the charging behavior).  I also need to recheck turning on headlights for when I want to force it to charge the camper.   Another JR, in June I converted the camper to LiFePO4.  Since it's not a good idea to try to charge lithiums directly using truck, I installed a Victron Orion XS DC-DC charger (which BTW is AMAZING!!).  Being cheap, I only had to buy that one item (besides the battery, of course) to do the conversion.  The camper OEM 120v battery charger (only 19 years old and works perfectly) and the truck feed the input to the DC-DC charger (not at the same time).  But I didn't want the camper charger feeding back to the truck so I kept the old separator.  I considered replacing the separator with a 30amp diode but that means more work and might add another 1/2 volt drop.  One thing that surprised me was the voltage drop over the long 10awg wire run, so I can only charge smoothly at 8 amps (because the DC-DC charger is completely configurable).  Another reason I don't want an added voltage drop with the diode.  I might also be a little lazy but all this work is being done under the sink with a small cabinet opening.
