I bought an OEM front license plate bracket from GM for my 2015 GMC Sierra 1500 but it does not lineup up on the bumper. The bracket (part # 22763523) is said on the website to fit my truck but does not sit flush in place. It seems to be wider than the space given. Has anyone else experienced issues with this installation or know of something I may be missing or doing wrong? Thanks in advance for any help. Also if you know of any install vids please let me know. Pics included
From what I'm looking at, it looks like it has the cutouts that fit over those 2 little extensions. It may not be supposed to fit flush. I know you probably tried but what happens if you flip it upside down?
Edited by mikeyk101
Yes I flipped it upside down and none of the holes aligned that way either. The bracket is actually wider than the space on the bumper which is the other thing that has me kind of questioning it.
Can you show a picture of it sitting on the bumper? On mine although it is a different setup, the holes on the bracket didn't line up with and holes on bumper. It just used screws that go through the plastic but hold really well. If when in place, the holes match up with bumper plastic without a gap, that may be the way it goes on.
Edited by mikeyk101
It looks like the silverado shares the same part #. Fits the silverado contours great, for some reason gmc was an after thought. Nobody will notice but you.
I'm assuming those two little indentations on your bumper are where the screws go through.
https://www.gm-trucks.com/forums/topic/156307-those-with-front-license-plates-on-gmc-sierra/
Edited by M1ck3y
    • I just can't think of the exact term GM uses for that higher gvw package without looking at the website but basically sort of a trailering package and I imagine it may also have been created to skirt around the licensing fee differences between a3/4 and 1 ton that apply in some states although ironically I believe in some states its the reverse that a 1 ton is the cheaper truck to license over a 3/4 ton. It makes no difference here in Alberta but oddly enough a 1 ton through my insurance company is a bit cheaper to insure over a 3/4 ton as its based on the insurance statistics they generate.    For sure when ever you do have the chance to weigh your truck and to be fair, try to have the fuel tank full or nearly so rather than give yourself a false sense of the truck being lighter by having an almost empty tank.    In my other comment I was mentioning stock sized tires and partly in case someone was reading this and thinking they could lower their pressure down to what your aftermarket tires are able to do with your empty truck as that is a vastly different picture in the leeway you have to play with for running minimum pressures while remaining safe. I will say also that its easy to see from reactions of truck owners that may have been more used to owning a half ton in the past or a car and be it on a forum like this or in person etc that they get so wrapped up in that placard pressure sticker that they can't get their head wrapped around the fact that an HD truck due to how much it can carry can also vary the tire pressures drastically lower than those pressures ( typically more so for the rear axle on stock sized tires ) when empty vs some car that isn't made to carry much so the tire pressures can't be lowered since it needs almost that much pressure just to carry the empty car.    If I ever do find myself in the states with this truck, I will only be too happy to switch it over to the US measuring system as then I will understand all the dash readings. The only thing that is off for me slightly with US measurements is US miles per gallon as I grew up with the Imperial gallon and to this day up here anyway speak in Imperial miles per gallon ( I don't do that on this forum though as that would confuse everyone for no good reason ).
