I bought an OEM front license plate bracket from GM for my 2015 GMC Sierra 1500 but it does not lineup up on the bumper. The bracket (part # 22763523) is said on the website to fit my truck but does not sit flush in place. It seems to be wider than the space given. Has anyone else experienced issues with this installation or know of something I may be missing or doing wrong? Thanks in advance for any help. Also if you know of any install vids please let me know. Pics included
From what I'm looking at, it looks like it has the cutouts that fit over those 2 little extensions. It may not be supposed to fit flush. I know you probably tried but what happens if you flip it upside down?
Edited by mikeyk101
Yes I flipped it upside down and none of the holes aligned that way either. The bracket is actually wider than the space on the bumper which is the other thing that has me kind of questioning it.
Can you show a picture of it sitting on the bumper? On mine although it is a different setup, the holes on the bracket didn't line up with and holes on bumper. It just used screws that go through the plastic but hold really well. If when in place, the holes match up with bumper plastic without a gap, that may be the way it goes on.
Edited by mikeyk101
It looks like the silverado shares the same part #. Fits the silverado contours great, for some reason gmc was an after thought. Nobody will notice but you.
I'm assuming those two little indentations on your bumper are where the screws go through.
https://www.gm-trucks.com/forums/topic/156307-those-with-front-license-plates-on-gmc-sierra/
Edited by M1ck3y
    • Can it still be Assembled II?   Viscosity on the decline by various means. Heat on the rise making that worse. Engine RPM in the tank. Smaller motors with more boost trying to emulate an electric motor. Full torque, zero rpm. Then we will triple the OCI. Argh.    But wait....there is more. LSPI has pushed a shift from Ca to Mg and as that cost more PLUS the run to lower sulfur compounds the TBN is moving in the wrong direction for the increased OCI's demanded.    That not being enough to placate a demand for a parameter they can't measure the other sulfur bearing compounds are also under attack. That would be zinc and phosphorus sulfonate compounds. To some degree those are being replaced with boron esters and others, i.e. titanium ect. All of which have shorter service lives. And there there is the "Secrete Sauce" marketing for AW adds that 'Can't be detected by UOA's" but trust me because I (the blenders) never ever lie.    Spoiler alert; ALL additives are sacrificial! Smaller amounts of the old blended with less robust versions of the new do not equal longer service lives. So what are the blenders recommending? Wait for it.......   MOVING THE GOAL POSTS! OMG      Let's declare the long standing TAN/TBN crossover irrelevant and tell people that soot is a great 'graphite' based lubricant which can aid tribo films. Wait, what? Let's declare that the standards used for oxidation and nitration were to conservative and can be expanded. Let's tell them that because GDI fuel dilution, although being a VISCOSITY KILLER and an acid generator is actually okay because we have better base oils that limit viscosity failure limits. (Said knowing this is measured in fractions of a centipoise and in bases not commonly used in shelf oils)   Lying from the heart is not just the new normal but we have a public, a very young public, that is so ignorant of the facts and so sure of their "RESEARCH" into AI driven models base in regurgitated  instead of scientific research based unvarnished, peer reviewed FACTS that the incoming guard is loosing their grip on reality and the OEM's are tickled pink while the blends bend the knee.    You have an ever limited set of tools to work with. And sooner or later those will be taken from you as the API and the EPA strangle the last remaining fluids from the system. What you have left is your wits. If you care to use them.    At some point in the very near future it will not longer be possible to do "What is best for the machine", and be replaced with "The best you have access too". You WILL be rewarded with half the life and twice the cost. That isn't that hard to predict.
