The problem with using a screw extractor is the chance of breaking it.  If that happens, drilling will be impossible because screw extractors are made of extremely hard steel and won't drill.
The thing is I don’t have any of those tools available I’d have to go buy some but I’m honestly afraid I’d screw it up even more. My appointment with local dealership is Thursday but I’m starting to think they might not even be able to get it out or want to mess with it
I actually had a buddy I work with used an air chisel to get it out but I think it may have pushed the shaft down a little bit because once the new steering wheel was on it rubs against the plastic that goes around steering column and I took the steering wheel back off and put old one back on just to see if it would rub as well and it did so I’m kinda just dealing with it right now thinking of putting a washer on the shaft between the steering wheel to push it out so it won’t rub
  • Sad 1
In addition to an air bag, modern cars and trucks have crushable steering columns as a safety feature to prevent the driver from being "speared" in a head on collision.  Hopefully the use of an air chisel has not affected the column's ability to collapse in a wreck. Rather than using a washer to fix the problem, you might want to get the column checked out by a professional.
  • Like 4
On 11/29/2021 at 1:02 AM, Th3BobbyHill said:
New Philadelphia, Ohio
I was hoping to help, but you're too far away.  Sorry.
Check that the plastic pieces around the column are snapped in properly. When I replaced the cluster/wheel I had this same thing happen, but the plastic just needed to be seated better.
  • 2 months later...
I just got mine on and it also is rubbing. Not going to look at it tonight, but what did you end up doing about it?
Use a left hand drill bit, large enough so the point tip just fits in the hole , smaller than the tread diameter . use a slow speed 1/2 " drill in reverse mode with a lot of downward pressure . Make the bit "catch" and don't allow the drill to twist out of your grip. The bolt will pop free.
  • 11 months later...
A bit late to the conversation, but for anyone looking for answers, new Milwaukee hard metal bits and a Ryobi extractor worked just fine.
  • 4 weeks later...
So here's what I did - I had this problem on my CTS because they put far too much threadlocker on the steering wheel bolt (in addition to the dumb idea to change the bolt to a torx bolt at some point - older ones are hex).  I put a cutoff wheel on my dremel, covered the entire driver's side of the interior in towels, and cut the top and bottom edges off of the bolt head - I cut it down just enough to hammer a universal socket on.  Before I hammered the socket on I heated the crap out of the bolt with a heat gun.  Then I attached a 24" breaker bar, with another 24" extension, held the steering wheel in place with a 2x4 propped underneath the left spoke, and put all my weight on the bar while basically jumping up and down...after the fourth try it finally moved.  It was a fight but I finally got it off.  I then chiseled as much threadlocker off of the new bolt as possible...they REALLY cake it on there.
    ChristopherDobson
    ChristopherDobson
  • Who's Online   1 Member, 0 Anonymous, 1,249 Guests (See full list)
    • Thanks newdude!  By the time manual selection is needed, I'm probably too much of a control-freak to depend on the transmission sensing braking to activate automatic downshifting.  I would be anticipating the situation and already be manually downshifting.   This truck replaced a 2004.5 LLY diesel with the Allison 5-speed.  Putting it in T/H made noticeable differences (when the torque converter locked, upshift points, downshift behavior).  On this 2024 gasser with the 10L1000 I haven't been able to detect much, if any, difference.  Ok, I can never tell now when the torque converter locks up.  But I also don't notice differences in shifting.  For downhills, I've probably already manually downshifted by then anyway.  Since it's also more awkward (than the 2004.5) to engage/disengage I don't even bother.  Or maybe it doesn't really matter with just a 3k lb. camper in the bed?   Thanks also for the list of reasons the charging system might select various voltages.  However, what I am seeing doesn't fall into any of those categories.  It very definitely, and very consistently, rises after coasting/braking.  Maybe not immediately, but not very long after coasting/braking.  Very consistently drops voltage when no longer coasting/braking.  It might also be interacting with the camper battery charging (I might disconnect the camper and see if it changes the charging behavior).  I also need to recheck turning on headlights for when I want to force it to charge the camper.   Another JR, in June I converted the camper to LiFePO4.  Since it's not a good idea to try to charge lithiums directly using truck, I installed a Victron Orion XS DC-DC charger (which BTW is AMAZING!!).  Being cheap, I only had to buy that one item (besides the battery, of course) to do the conversion.  The camper OEM 120v battery charger (only 19 years old and works perfectly) and the truck feed the input to the DC-DC charger (not at the same time).  But I didn't want the camper charger feeding back to the truck so I kept the old separator.  I considered replacing the separator with a 30amp diode but that means more work and might add another 1/2 volt drop.  One thing that surprised me was the voltage drop over the long 10awg wire run, so I can only charge smoothly at 8 amps (because the DC-DC charger is completely configurable).  Another reason I don't want an added voltage drop with the diode.  I might also be a little lazy but all this work is being done under the sink with a small cabinet opening.
