6 hours ago, Shithead said:
No the icon is no longer lite up on the cluster
It used to work before?
Are your fog lights on?  The automatic high beam feature (intellibeam) does not function if the fog lamps are enabled.
1 hour ago, Jac365 said:
I don't think the dash icon comes on in daylight if the lights are set to auto.
No.  Only if the headlights are on (and fog lights are off.)
And once the headlight icon with the A is turned on (indicating the feature is enabled), the vehicle needs to be moving fast enough before it will activate the high beams (they aren't going to come on with the truck sitting still)
For Intellibeam to enable, it must be dark out, and the headlamp switch needs to be in Auto position , or Headlight position when the button is pushed.
Edited by redwngr
    250.6k
    Aries68
    Aries68
  • Who's Online   5 Members, 0 Anonymous, 458 Guests (See full list)
