4 minutes ago, richard wysong said:
codes don't mean replace the part, they are to help with diagnosing the malfunction
I would agree with that.
Although that would make things easier.
P0300 Engine random misfire .... So...replace the engine?
Yeah i got a backfire with starting fluid earlier today . It seems like the the MAF or TPS weren't telling the computer to give fuel . I agree the codes don't mean ya have to replace parts but they are factory 260K miles on it . And autozone is 5 mins away . I have a Hypertech programmer and cleared the codes unhooked the battery for the night and will try it again in the morning . I will also try cleaning the intake ( butterfly ) at the TPS and check pressure in the fuel rail again .
Backfiring out of the intake indicates that the engine is getting too much fuel. For instance, if your fuel system is working properly, and you add more fuel - its too rich and will pop out of the intake. A 5.3 that wont run can be frustrating, but its also very interesting to mechanics, because it can be easily solved if you eliminate the possible issues. Normally the problems that mechanics face are not usually so strait forward.
You do not need a throttle body to make an engine run. You do not need an exhaust system either.
Don't bother replacing any of that stuff until you find the problem.
Does it have compression?
Does it have spark?
Is it getting air?
Is it getting fuel?
A non running motor falls back to the very basics of engine diagnostics.
as with any diagnostics start with the basics, good fuel pressure and volume, compression, spark, vacuum. codes may give you a clue on what the problem is  but don't put parts in unless you know the parts ng. could be timing, vacuum leak, cam or crank sensors , injector wiring and on and on. try unplugging the maf  and try it. you may need a scan tool with data stream and  scope capabilities if the basics check out
could be timing chain. vacuum gauge may help diagnose that. if it is you may have valve damage. again basics. whats the compression? at least the parts stores close to borrow the tools if you don't have them
extended crank may set maf code. They are very likely false codes and wait til its running to address them
crank sensor will cause no start but it wont have spark more than likely. cam sensor will throw the timing off but it should still run even with it unplugged
The jar came out of the truck , the glass on the right is year old gas for the snow blower from last year . The new gas ( 20 gals ) was what i topped off with and had to drain . Truck is back to normal .
that will do it! NEVER buy gas when they are refilling the tanks, it stirs up any water or crud in the tanks and most dispensers/ pumps don't have filters. almost ALL storage tanks have some water in them
    • It was never mandated.  Ever.    Automakers were incentivized to install it by getting CAFE credits to help with their vehicle fleet fuel economy scores.  They were being handed money/CAFE credits to install it.  Which is NOT a mandate.       The current admin removed the incentives that were behind them installing it.
    • I went another direction after losing a trailer tire, thanks to not being able to access air at ANY of the 5 gas stations and garages I stopped at prior, with a Toyota Tacoma onboard, 50 miles from the Canadian border. They were either out of order, access was blocked, or the hose a few feet too short and I couldn't get any closer without risking damage to someone's property.   https://postimg.cc/gallery/X5QJ55w
