I know this topic has been posted about a thousand times but I need to ask. If I disable my AFM with a DiabloSport i3 Tuner do I also have to change the camshaft, lifters etc etc? I am worried about damaging my engine as this truck is very special to me. Thank you everyone in advance.
No, you don't have to change anything physical. The programmer re-programs the ecu, telling it not to engage afm. From then on it will stay in v8 full time.
Awesome! I have read people installing an Oil Catch Can. Do I need to install this? Also I have a K&N aftermarket intake pipe and filter installed. Will that affect anything?
No you don't need a catch can to disable afm. Your air intake will not affect anything.
I Have a 2017 6.2L that was modified by Hennessey Performance. Which includes a Whipple supercharger. After 3 or 4 months, my oil catch can is dry.
Agreed, all that you need to do is program the computer not to use AFM anymore. That alone will greatly reduce the likelihood of lifter failure. If you want to take it a step further, you can pull the valley cover, and drive a metal plug down into the oil pathway that supplies oil to the VLOOM, and then cut sections of the gasket out of the oil pathways between the VLOOM and the head. That will insure that oil pressure doesn't build up in that area (from the opposite direction) and trigger a lifter pin to get jammed in the wrong spot, causing a collapsed AFM lifter. I did all of these steps on mine when I replaced #7 AFM intake lifter. Note, the VLOOM can not be removed from the engine, and you want to leave it plugged in as well - even though its not in use anymore.
I do the AFM delete, as listed above.
I also put on Wheel spacers, and lift spacers.
I always add a cattle guard and rain gutters.
Gotta have the backup cam and in dash DVD of course.
I have a hidden kill switch to prevent theft.
I also rewire the power outlets so they turn off with the key.
And so on...
And so on...
Where do you put the kill switch.
That's impressive! I'm assuming you do plenty of wot too?
I have installed them on every rig I have owned for the last.... 30+ years.
I install them on other people's rigs too.
It really depends on your personal preference and the amount of time you want to spend installing it.
All you have to do, is make it very convenient and easy for you to operate, and "not obvious" to the car thief.
Basically you "break" the truck. So even with the keys it wont start. As long as the thief doesn't find the kill switch, then they would need to use a tow truck to steal the rig.
Disguise it as an OEM fog light switch, or a switch under the seat. You can put them under the sun visor mirror cover, or in the glove box. Next to the seat, under the dash, or it can be done with a remote control using a relay. You can tap into the fuel pump, ECU, starter, etc.
The most famous bank robbery in Hollywood was foiled by a hidden fuel pump kill switch on some old crappy pickup truck. One of the robbers tried to car-jack a truck during the escape. The driver said no problem, take it - and he flipped the fuel pump kill switch off on his way out of the rig.
That robber got caught.
After suffering a leg injury from police gunshots, the other guy blew his own brains out with a 9mm before capture.
Out of curiosity, what year is your current truck?
The K2's are pretty easy to do that "mod", you just move a 50-amp fuse one spot.
The current vehicle that I'm working on is a 2008 Chevy Suburban. I don't think moving the fuse is an option on my rigm but it might be. What do your sources indicate?
    • I would have to read back to get a better picture in my mind of some of the other comments and what they were using for a driving scenario they based the fuel mileage off of. That is why the fuel mileage conversation is extremely difficult to make fair comparisons from. If I was to be living in town and only driving around town, light to light and some longer stretches that doesn't have a light every block, and the usual stop at a grocery store and the bank and so on and so forth, my fuel mileage even during the summer time would be so bad with my truck I don't even want to know how bad it would be !. Then add in winter time and idling to warm it up to clear the windows and driving through snowy streets etc, large heavy trucks with gas engines have NEVER been worth crap for fuel mileage and why some little pot licker of a car with wheelbarrow tires and a 1300 cc four cylinder non turbo engine was the ticket to using a mere fraction of the fuel over a full size pickup.    By the way my truck has the 34" tires as its a HC but not the BFG KO3 tires ( that was an option for my truck but the sales guy couldn't figure out what the tires actually were so that never got on the order until it was too late to change the truck order ). So what fuel mileage your getting actually sounds good for "town driving" and with my truck when I go to town the fuel mileage keeps increasing as I get closer to town because it takes quite a while to get the driveline oils warmed up ( and why it always shows better fuel mileage on the return trip from town because its already warmed up ) but once I am in town that fuel mileage average just keeps dropping the more I mess around town and then has to recover back to something reasonable again by the time I get home for an over all average.    I'd be curious what your sticker says for the factory weight of your truck, mine is close around that 7700 lb due to the options it has. But anyway the long and short is, vehicle weight, higher rolling resistance heavy tires and a hefty driveline and a relatively large gas engine make for crap fuel mileage in stop and go scenarios, all one can do is drive it easy off the line at each stop and as my dad had said over the years, drive like a raw egg is under your foot and that's the best one can do. Years back with a carbed engine and if the carb was getting a bit out of tune etc as would the ignition system, the fuel mileage on pickups with larger engines was just awful compared to what your getting. We pay the fuel price penalty for driving HD trucks over some little vehicle, that is the reality.
    • We had two Toyota’s with that engine in the mid 80s. We had 50 gallon fuel tanks, a toolbox full of tools, an air compressor and assorted parts for our equipment. We beat those up and down pipeline ROWs until we started buying diesel trucks. Then they became parts runners and first vehicles for our teenagers first cars. Our shop Forman wrecked them both two years apart when we hired him out of high school as an apprentice. Good thing he’s an excellent mechanic. It took awhile before he could be called a good driver.
    • I have a 2025 GMC Canyon Denali.   On a trip recently the engine failed.  The dealership diagnosed a bent valve and says there is a service bulletin that indicates to 'relace the engine'.  The truck only has about 14K miles and is under warranty.   The failure occurred 5/11/2026.   So far I have worked with GM Customer Assistance and Roadside Assistance.  Evidently no engines are available and nobody will offer a date when a new one will be.   Coming up on two months with no repair or timeline and no loaner from the dealership.   GMC Customer Assistance is 'ghosting' me and keeps closing the cases I've opened with no resolution.   Hoping someone can help me on how to escalate this issue.
