Installed these recently on my 2015 Silverado 1500 CC, Standard Bed 2wd.
Previous suspension setup was stock shocks and struts with 109k miles!
Max Trac 3" lift Spindle
Rough Country 2" Level spacer that goes underneath the shock.
Rear OEM block Removed (i liked the small squat)
Image 2683 is how it sat before.
Now Its sitting on: Eibach 2.0 Coilover. Same Max Trac lift spindle, Removed the RC 2" level spacer, Added back in the rear OEM block, and the Eibach Rear Shocks. Also installed a pair of RC Extended stainless brake lines. Didn't touch the coilover out of the box at all for adjustment
The ride is defintely much better than 100k+ stock shocks, it is riding much stiffer now but in a good way. The truck doesn't bounce after hitting dips on the freeway it just settles quickly. The rear of the truck actually feels really good finally.
Yes I know the truck is even more squatted now, I am considering getting a larger block in the back to help with this.
Edited by mitchely03
5 hours ago, Truckboattruck said:
Put a rear block back in then come back so I can take this seriously.
Really?
I have a set of these on the way. Just curious if the longer coilovers made the installation any more difficult? If I recall correctly, the instructions have some steps that I wouldn’t normally do, that go past just disconnecting the tie rod, sway bar and upper control arm. Thanks
    • I had an 88 K1500 with a 5.7 that had those symptoms, I know totally different, it ended up being the ECM. Once you get the fuel system fixed if it still runs lousy you may want to investigate that. it didn't set any codes, stalled ,ran rough at times etc
    • Long Term Cold Cycle Limited Testing   Back to the 1990's and XOM's million mile test. Since then there have been others and there will be more. Schaeffer's, AMSOIL to name two. Of these Schaeffer's is the stand alone which I will explain in a bit later.    http://papers.sae.org/600190/:   http://papers.sae.org/850215/:   Up to 75% of  engine wear occurs on cold starts. These two links (above) provide the technical reasons for engine wear. In a nut shell, and by a large margin, cylinder wear is what takes out most motors and even with a pre-oiling system that part of the engine is dry enough on cold starts and cold warm up to pierce Stribeck.   So when you put a motor, or a car, on a dyno for a million miles stopping only for oil changes, (yes fuel is uninterrupted) or break down maintenance, you are depriving the test of the most important part of it's wear cycle. Yes a million is then a pretty easy walk even for a mineral oil under those conditions.    How about cleanliness during the long test cycles? Same thing. Varnishes that stick rings and insulate parts are laid down by repetitive 'heat cycles'. It's the cool down the precipitates the varnishes. These long runs also hinder acidic attack caused by cold start richness and less than optimal cold start ring sealing. They hinder water formation and enhance breathing of the crankcase; the petri dish of acid formation, the first step in sludge formation, amalgamation and precipitation. These motors are also monitored and controlled for water and oil temperatures to within the "normal operating range".      https://www.swri.org/sites/default/files/sequence-iiih-test.pdf Note the test sequence in some boutique oils literature for testing, API IIIH, is not the standard used for the ILSAC G7 testing. Does that mean it is irrelevant? No, not as used. As used as a 'visual guide' it makes it's point. The G7 weighted piston deposit minimum is lower.      Back to Schaeffer's. That was a cyclical test of an engine in fleet service and not a dyno mule and if you saw the video it was not mirror clean but wear was low.    There are oils like BioSyn and other 'Renewable" source oils that taught cleanliness and have proven themselves in fleet testing. Havoline an other example.    The newest ILSAC G-7 test prioritize cleanliness, LSPI mitigation and fuel economy OVER WEAR. In comparison Porsche C30 Specification Verses ILSAC G-7 Specification below:      Some will balk that this graph isn't apples to apples and I will challenge that in that this graph represent the SPECIFICATION and not the any One Oil Performance.   It is absolutely possible to minimize wear, maximize cleanliness and mitigate LSPI etc., It just isn't cheap and currently I see none that are not walking toward profit over performance.
