I have a 2500 HD with the push button tail gate drop. It is now opening when I open the drivers side front door and closing it.  How do I remove the tail gate until the dealer can look at it?
Just like any other tailgate but you will have to climb underneath  and unplug the wire harness that goes into the bottom center of the tailgate. its right behind the spare tire.
    • It really is comical when people don’t agree or see the reason some people prefer the older vehicles. They become condescending. All the while they may be busting their knuckles on old vehicles. I have found memories of swapping out engines in my old GM cars in a weekend without much hassle. Unlike today. One wrong move a computer will shut you down. Even on something as easy as a brake job. There’s a pretty comical YouTuber called the car wizard. A garage owner who puts it all in perspective. Another Vicegrip garage that’s shows just how tough the old stuff is.
