I am the proud owner of a 2004 Silverado Crew Cab truck with 210276 miles on the clock and no check in light or trouble codes...  truck has been really great since I bought it new.  I now have a problem where I get an extremely rough idle after driving at highway speeds and stopping at a ramp light when exiting.  I am worried because a few times the truck backfired and nearly died on me.  I have replaced the O2 sensors (All of them)at the start of these issues as they were original to the truck. I have also cleaned the throttle body and replaced the spark plugs.  Using my data logger I can see that the throttle is at 4 to 5% at idle in the driveway at 525-560 rpms (fluctuating rapidly).  I have looked for vacuum leaks and found none.  I am thinking that my Throttle Position Sensor may be about to give up the ghost.  What do you guys think based off of the information I have provided here?  If you need more let me know please.
List of new parts installed in order before and after trouble started:
battery (Just before issues started)
O2 sensors (all after issues started)
Plugs (After)
Plug wires inspected, no apparent damage and less than 1 year old
Throttle body removed and cleaned on the bench (After and last thing I have done before this post).
Thank you in advance!
Edited by DDGLDO
Add to title
  • DDGLDO changed the title to 2004 Silverado 5.3L Vin T Idles low
try doing the idle relearn procedure. when you changed the bat you lost memory. it sometimes has to be done after a throttle clean as well. also try cleaning the idle air control and make sure the pintle moves. did you check with a scan tool or just a code reader?
as it all started when you changed the bat make sure any wiring, grounds in that area didn't get damaged
Richard,
Thank you for the reply!  I used my handheld scanner to check for the DTCs.  I did disconnect the battery again, let the truck idle for 5 minutes, turned it off for about a minute and then started it again to idle for another five.  After turning it off for about 20 minutes (Long enough to change my pants and grab my wallet) I took it on a thirty mile drive at highway speeds.  As for the IAC, I don't think my truck has that...   I thought the problem may have been resolved until I was on my way home and noticed it doing it again.  Call me crazy but I think it even did while under acceleration up a hill.
I will go out and take a closer look for anything amiss around the battery and let you know if there is anything going on there.
Thanks again!
Edited by DDGLDO
Answered question about IAC
it has an IAC somewhere in the area of the throttle. thats how the pcm controls idle speed. has a 3 wire connector and 2 screws holding it to the throttle body. the way it works is it screws the pintle in and out to control basicly a vacuum leak that raises and lowers the rpm to the pcm command. they get stuck occasionly and may not set a code. if your scanner does data you should see the counts start high when you start it and slowly decrease. when you take it out to clean it and the passages it sits in you will probably find it fully extended, clean it and then screw/push the pintle in before reinstalling. when you start it the idle should be higher than normal but quickly decrease, if it doesn't its probably NG
Trucks with electronic throttle bodies do not have an IAC. The idle it controlled by the blade itself.
Off hand I don't know what the throttle percent should be at idle but I thought it should be at 5% or more.
A throttle relearn is still a good idea. I'd double check fuel pressure at idle as well. Clean the MAF too.
And see what your fuel trims are doing while at idle and driving. Lots of negative trims means it's pulling fuel and positive trims means it's having to add in fuel to make it happy.
learn something new everyday. thank you for correcting me. what year did they start electronic throttle control?
Depends on what trim you have.
They used it in as early as 2001 in the trucks like the Denali. Some Silverado/Sierra's have it in 2001-2002 as well if they have the advanced traction control system in them but not many had that. They went full time drive by wire in 2003 with the 4.8/5.3/6.0 in all trucks. The 4.3 stayed cable driven for a few years yet and same with the commercial vans like the express.
Corvettes have been DBW since 1997.
CamGTP,
Thanks for the info!  I will take a look on my way to work tomorrow how the fuel trim looks.  Just at idle both were at 2.  Just redid the throttle relearn tonight.
Thanks again!
Ya know Richard, I don't understand why it takes repeated tries to get the ECM to relearn. It's a bunch of chips fercryinoutloud!
Edited by dna9656
  • Haha 1
ya got me, could be it doesn't see all the data parameters on the first pass? Im not saying everytime it has to be done twice but from experience if it doesn't fix it the first time try it again before moving up the tree
    MASONV88888888
    MASONV88888888
  • Who's Online   5 Members, 0 Anonymous, 1,664 Guests (See full list)
    • I’m definitely interested to hear the end result here.
    • My 2025 Silverado 1500 had to receive a brand-new engine (long block) under warranty last month at only around 16,500 miles. Before the replacement, the truck repeatedly displayed "Engine Oil Level Low" warnings, even though the Oil Life Monitor still showed around 50% remaining after about 6,000 miles since my last oil change. After seeing the warning several times, I checked the dipstick with the engine cold, and the oil level was completely normal. The next day, the message escalated to "Add Engine Oil." At first, I assumed it was just a faulty oil level sensor, so I brought the truck to the dealership. After inspecting the engine, they found internal cylinder wall scoring and ultimately replaced the entire long block under warranty. Before this happened, I was planning to install a 4-inch lift and suspension upgrade on my truck. After needing a new engine at just 16,500 miles, I honestly don't see the point anymore. I also contacted GM to ask whether my vehicle qualified for a buyback, but I was informed that it does not at this time. Anyway, this experience has left me with serious concerns about the long-term reliability of this engine. I sincerely hope NHTSA expands the current investigation or recall to include 2025 model and performs a thorough inspection of affected vehicles. My biggest concern is that these engines may fail shortly after the powertrain warranty expires. If GM truly stands behind this engine, then at the very least, please consider extending the powertrain warranty to 10 years for affected owners. That would go a long way toward restoring customer confidence.
    • Without exception but then I'm the odd duck, right? I know what goes into that test, how it is calculated and thus how to beat it. But EPA values are often not beaten by the general public and the government has in past years adjusted the means and methods to come to those values to more closely approximate "Joe Average".    The only real trick to beating that EPA average is don't drive like "Joe Average".    It's the same method you used to profit from "Economic Migration" and in doing so beat the 'stats'. But you, like me, are not "Joe Average".     The thing you don't seem to grasp is this "Purchasing Power Index" isn't forward looking. It doesn't predict what it going to be but looks backward and states what it was. They are not telling us what the THINK, they are telling us what they MEASURED. Example:    Wife says "I'm going to lose 40 pounds by Christmas". May she does, maybe she doesn't but the doctors office who weighed her when she made that statement and again at Christmas only REPORTS what the RESULT was. You and I can banter about what was possible and what aunt Tilly did till the cows come home but the result is the result. Arguing otherwise is.....irrational. That's all I'm saying. This isn't about:      What you are calling a 'Statistic' is a RESULT not a CALCUATION and as a result the RULE. Like gravity as a rule, it can not be broken.
    • Just wanted to say thank you for posting this. Years later, your thread is still helping Silverado owners.   I bought my 2025 Silverado 1500 in January 2025, and I've had what feels like the exact same rattle since day one. After reading your findings, I believe my truck has the same issue with the cable carrier contacting the rear sliding window. To be honest, I had pretty much given up on pursuing the issue. It wasn't until I recently drove another brand's pickup that I realized just how quiet their cabin was—and how noisy mine has been all along. On my truck, the rattle happens on almost any paved road, gets even worse on rougher pavement, and I can even hear it during braking and acceleration.   I actually referenced your thread when submitting my case to GM, hoping they'll recognize this as a recurring issue instead of treating it as an isolated incident. The reason I reached out to GM first is because my dealership told me they would need to keep the truck for at least two days just to diagnose the problem. I was concerned that even after two days, they still might not be able to identify the source of the rattle before giving the truck back to me. I had also asked a few dealerships about this issue during previous service visits, but none of them seemed to know what was causing it or had a solution. That's why I decided to contact GM directly first, hoping they might already have an official repair procedure or guidance for this issue.   I also hope GM eventually comes up with an official fix for this problem. I have a feeling there are many Silverado owners experiencing the same rattle, but most either choose to live with it or simply don't know what the cause is.   Really appreciate you taking the time to document your diagnosis. Your post is still making a difference years later.
    • I have 2 choices.
