11 minutes ago, lennybg said:
Source for the " its a lot higher than that" number?
Most people only join a forum when they have an issue. Last time i checked there was only like 333K people on this board. Out of that number, how many had lifter failures? Between 2019 and March of 2024 there were 2,906,782 Silverado's sold(in the US, NOT INCLUDING GMC SIERRAS)  So using those numbers alone, ONLY 11.46% of SILVERADO owners are even on this board, and out of that number, how many have had lifter failures?? SO 1% is a totally plausible number.
Just type in your little browser problem years for GM. Lifter and transmission problems are well represented. Even some class action lawsuits. So it’s not all peachy. I joined the website in 2014 because I hadn’t bought a new GM truck in a while. My ex son in law was a salesman. He gave me a killer deal. For the first time I did no research, didn’t have time. On the way home the V-4 light came on. I’m like what the hell is this? The following Monday I’m getting exhaust on. I’m driving back to my shop and it sounds awful. So I found this website and order a programmer like always. Now I’m learning. So now I start my research. My first trip I’m playing with my programmer. I gained only 1/2 mile per gallon with it on. After finding out all that’s involved with cylinder deactivation I dumped the truck before the warranty is up. It’s a shame. As far as ride and wind noise it was awesome. On E-85 with a tune it ran really well. If you do just a little research the model year I had was one of the worst for GM. More than 1 percent, I think so.
I never said there wasn't an issue, we all know there is. But all makes including Toyota have their issues. But people on here make it sound like every GM truck is going to have lifter issues and that's simply not the case. Like i said before, if every single person on this forum had lifter issues it would only account for 11.46% of total sales, that percentage gets even smaller if we add in the number of Sierras sold to the total. My original count only included Silverados.
Edit:
I went ahead and added those numbers in....
There was 1,340,119 Sierras sold in the same time frame for a total of 4,246,901 Silverados and Sierras. There are 333K members.... So if every single member of this forum had lifter failure, it will only be a  7.84% failure rate. So how many people on this forum have had lifter issues vs those that have not?
Edited by lennybg
Edit:
Right...no source.  That's what I figured.
What's crazy about your numbers is that you correctly point out that the membership of this forum is only a small fraction of total number of trucks sold...but then you go on to assume that every single owner who has had a lifter failure has logged onto the forum here to let us know about it.  Strange thinking.
YES the membership here is only a tiny sampling of the total ownership of our trucks...but also, the owners who have posted here about their lifter failures are a similar tiny fraction of the total lifter failures that have occurred.
I don't have a real number for the DFM-equipped trucks but when a class-action suit was being organized for the AFM trucks, the analyst firm that was contracted for data came up with a number around 12%.  The DFM trucks are, without question, worse than that.  So it's a lot more than 1%.
I have to agree with this. I know my example is small sample size garbage, but to claim that because only "11%" of gm owners use the forum seems like a very half hearted answer to "source for 1%" claim. Also, it seems to dismiss the fact that 5.3's and 6.2's don't make up the entire population of 1500 owners.
That seems like a more reasonable answer just based on the small sample size of people I know IRL that have had the issue. Which is quite a lot.
Edit:
Where did anyone claim that "Toyota" or whatever didn't have any issues? This seems like a very fanboy response. No offense.
18 minutes ago, The Raven said:
................ for the AFM trucks, the analyst firm that was contracted for data came up with a number around 12%.
So, 120,000 per million units. That isn't Good. That's Terrible. Literally. 😱
Where did you ask for a source?
Here's the post where you quoted, and replied to, me asking for a source...
Correct. I asked YOU for a source.     Your post was "Right...no source. Thats what i figured"
Not correct.  As shown in that link, I asked YOU for a source.  You replied by asking me for a source, without providing one yourself.  That's why I replied "no source".
Yeah well. I have to eat my own words now, and crow, and ******. My lifters took a dump yesterday morning. Was at a stop light, gave it gas, heard a loud pop sound, motor started shaking, dash lit up like a xmas tree, and you could hear the lifter(s) clacking.....  🤬
    • Can it still be Assembled I?    Stribeck says that we need a certain amount of viscosity under conditions of load and velocity to prevent two surfaces of a know roughness from tearing each other asunder. And we have marketing trying to tell the masses that those two surfaced require less of that commodity due to more exact limits being placed on the same old clearances. We also know that there are limits to how hard something can before it becomes to brittle to be viable and to smooth to 'wet' the surface and that both of those conditions have been known and met since about the Second World War.    That viscosity value shook out at 10 centistokes at 212 F just under a hundred years ago.  Give this a look: [Anton Parr]     What is advertised is the Kinematic viscosity (mm2/s) or that which has been density adjusted but the value we are after is the dynamic viscosity (mPa.s) or true viscosity. You can see that this number is dependent on density thus base stock and temperature. You can also see that an SAE 30 doesn't reach that value in this example. However an SAE 30 that is at the upper end of the SAE 30 range; 12.5 cSt (mm2/s), might. 12.5 * .83 = 10.375 (mm2/s). If you could find an SAE 30 at the upper end these days.   Then there is the complication of viscosity modifiers or VII or VM, whatever you wish to call them. Polymers added to very thin base oils, perhaps 3 to 6 cP oils, that will meet the SAE *W30 spec at 'tested' shear rates and 100 C/212F  target temperature. So a polymer fortified base that is a fraction of the 10 cP requirement Stribeck insist upon.   This could be all well and good if those polymers didn't have two very problematic 'features'. They shear or loose viscosity both 1.) permanently and 2.) temporality. And they do both omitted in the advertised data with the distinct  purpose of deceiving the consumer of the actual operating state of the fluid. I've shown the example of Warren Oils COSTCO 10.91 cSt 5W30 formuation several times where the 100 C HTHS value is 6.9 cP!! That's the temporary shear down and with and SSI or shear stability index of 9.4 cSt. Note the intentional deception in using mixed units?    After a short while that 9.4 cSt oil has a viscosity corrected dynamic value of 7.8 cP. But as the SSI is still within the range of an SAE *W30 whose lower value is 9.3 cSt.    This allows them to continue to call this SAE 16 weight oil a 30 weight, the cake, and still meet the API requirements for fuel efficiency IMPROVEMENT mandated by the EPA. The eating of the cake. By the time you've worn out your motor doing the responsible thing by adhering to the warranty requirements, (the stick), you get deprived of the carrot, wear control. So sad, to bad.   So what can be done? Do I need actually say? [Anton Parr]       Even this must be monitored if the oil is on the low side and the VII an organic or you opt for a 0W40 with an even lighter base oil and more / higher MW VII. (Note the lower density of the 40 weight versus the SAE 30 mono-weight?)    There is another workaround. Temperature. An SAE *W30 run at a bulk temperature of between 180 and 195 F.    Being the belt and suspenders sort I am I do both. Run it cook and run it heavy.    In Part II I'll work the AW package.
    • So, do I go elbow-deep on this thing or list it for sale and play dumb? Seems to "runs good."   I'm about $1200 away from having: -a rebuilt injector ($300) -a new cat ($250) -a new cat back exhaust (OE style) ($300) -a new AC compressor ($200) -AC refrigerant charge ($150)   In theory, this should rectify the obvious detracting issues from its value and operability. Cold AC with a non-squeaking AC pulley both sounds and feels good. An exhaust that isn't cut/hacked in 17 different places and doesn't vibrate on a crossmember would make it sound and feel less janky. A working cat would help the stink, and will save the earth, but *if and only if* the fuel system is working properly, which would also address the intermittent "rich" CEL.   Heard a good one... CEL for "Rich condition" means you haven't spent enough money on the truck lately, and it's letting you know.   Rebuilding the injector would seem to be the most important part. Replacing the cat would be secondary. I don't think mine is plugged or overly restricted, but it might be a little restricted? I have no good way to tell other than seat of the pants feel. I hate the smell.   The current theory is I have a rich idle problem: A bad fuel pressure regulator, or a leaking injector(s) being the highest probabilities. I already replaced the FPR but that doesn't mean its replacement isn't also bad. It was a new part from Dorman, but the packaging looked like it had been sitting on a shelf for 20 years.   This is the (single) upstream O2 sensor shown at idle. I'm getting a lot of "rich" it seems. Sometimes it stays high like that and doesn't drop down. That makes me think it's processing injector leaks or a partially stuck open injector.     Other times it looks like this. Nice oscillations between rich and lean, which is what I think it should be. Under load and at speed, the oscillations are nice and tight and uniform looking, high and low.     Fuel trims suggest the PCM is compensating pretty hard at idle to pull fuel out. But it's not enough to trip a CEL. Something about slowing to a stop: brake vaccum booster, EGR, or the EVAP purge is delayed, or there's pooled fuel in the intake again that's draining into a cylinder is enough to set the CEL. Of course, in two days of driving, it hasn't set. I was hoping to actually look at the freeze-frame data when it sets. IAT is high because it's idling on an 83 degree day here.
    • No such thing as regenerative braking on a pure ICE vehicle.     Regenerative braking is the re-capture of energy from electric motors and stores it in the battery pack.  So hybrids, PHEV and EVs have regenerative braking.     What you are seeing is the charging system changing modes is all.  Its likely entering charge mode for some sort of reason is all.  All of the charging modes will be listed below.   As for L10 vs D.  L10 turns off automatic grade braking.  L10 puts you in control of grade downshifts where in D it will automatically do it based on brake pedal position and other factors.  Otherwise L10 and D drive exactly the same aside from that one aspect.    Battery Sulfation Mode The BCM will enter this mode when the interpreted Generator output voltage is less than 13.2 V for 45 minutes. When this condition exists the BCM will enter Charge Mode for 2–3 minutes. The BCM will then determine which mode to enter depending on voltage requirements.   Charge Mode The BCM will enter Charge Mode when ever one of the following conditions are met:   Windshield wipers are ON for more than 3 s. Climate Control Voltage Boost Mode Request is true, as sensed by the HVAC control module via serial data. High speed cooling fan, rear defogger, and HVAC high speed blower operation can cause the BCM to enter the Charge Mode. The estimated battery temperature is less than 0°C (32°F). Battery State of Charge is less than 80%. Vehicle speed is greater than 145 km/h (90 mph) A current sensor malfunction exists. System voltage is determined to be below 12.56 V When any one of these conditions is met, the system will set targeted generator output voltage to a charging voltage between 13.9–15.5 V, depending on the battery state of charge and estimated battery temperature.   Fuel Economy Mode The BCM will enter Fuel Economy Mode when the estimated battery temperature is at least 0°C (32°F) but less than or equal to 80°C (176°F), the calculated battery current is less than 15 A and greater than −8 A, and the battery state-of-charge is greater than or equal to 80%. Its targeted generator output voltage is the open circuit voltage of the battery and can be between 12.5–13.1 V. When fuel economy mode is active, the generator is not charging, only maintaining open circuit battery voltage. The BCM will exit this mode and enter Charge Mode when any of the conditions described above are present.   Headlamp Mode The BCM will enter Headlamp Mode when ever the head lamps are ON (high or low beams). Voltage will be regulated between 13.9–14.5 V.   Start Up Mode When the engine is started the BCM sets a targeted generator output voltage of 14.5 V for 30 s.   Tow/Haul Mode (if applicable) Pressing the Tow/Haul Mode button located on the center stack, the vehicle system voltage is raised and the remote (non-vehicle) battery will be charged. Having the headlamps on will raise the system voltage and if the Tow/Haul button is applied it will not serve any purpose. The voltage is regulated between 13.9-14.5 V.
