My truck is 2007 Chevy Silverado LT, 5.3L with 2WD. For almost two weeks now, I have had some knocking, thudding from what seems to be my front driver side tire. I can feel it under my foot while I'm driving. It almost sounds like something is hitting or knocking against something with each rotation. It is consistent with accelerating and decelerating. My two front tires were in VERY bad shape and so I'm assumed it was that. I had two new tires installed a couple days ago (Nitto Terra Grapplers 305/60/R18), but still have the same sound and feel. So today, I jacked up the truck, took the brake pads and rotors off to look at them, and on the driver side the inside of the rotor was wore very unevenly so I assumed that was the issue now. Changed that rotor and the brake pads and I am STILL having the issue. I don't know much about the front end past the wheel hub, but from what I do know, the ball joints, control arm, and struts seem ok for now. They don't seem to be in terrible terrible bad shape, nor do they seem to be making that noise. The wheel hubs seemed ok as well, I spun them and did not get any sounds like I was hearing while driving. The inside of the rim looks good as well, nothing at all seems to be hitting the rim once I put everything back on so I'm just lost right now. I'm going to take it to a mechanic somewhere this week or next, but I thought I'd post this first and see if any of you would have any ideas. Thank you in advance for anyone that replies!
If the rotor was worn unevenly then that suggests a stuck brake pad? I usually go to the caliper pins 1st in that scenario. Did you take the pins out of the caliper to inspect that they were not frozen up and/or still had adequate grease on them?
When he says to grease them, you're going to be looking to use grease designed for brake work.
Good call on the that brand of grease. There are lots of options but that is a solid choice.
If you are in the area you should also take a good look at the rubber boots on the caliper pins. Make sure they are still reasonably pliable and not torn etc. If torn the grease can escape and contaminants can get in.
They make replacement kits if you have an issue.
Defiantly DON"T use chassis grease/wheel bearing grease! You can get a plastic jar with an integrated brush, it's prolly last you 10 or 15 years unless you do a LOT of brake jobs, I was for a while and bought the jar. Get some "acid" brushes and use that to apply the grease SPARINGLY to the necessary areas. You should be able to locate these areas on the internet, but I lube all surfaces that rub another surface and the guide pins/bolts. You should see SOME residue of where it was grease in the past but then again most of the guys I knew even in retail shops I worked in DIDN'T properly lube the brake system; if there was any sign of grease they didn't take the time because they thought the 2 minutes it took to lube it was time the could be spent on the next job, the bad side of flat rate shops. When I do a bake job I use a wire (tooth brush style) brush and hit all the rusty/crusty areas I'm going to lube. You don't want to use a wire brush of any kind on the caliper pins/bolts; they have a plating or coating that resists rust so I clean those with a parts brush and lacquer thinner in a shallow pan 2' X 7" X 10" baking pans (measurements are approx) make great parts cleaning pans. I get them clean, apply the proper lube and put lock tight on the threads, a drop is all that's needed. Be sure to use a torque wrench on all the fasteners; nuts, bolts/pins. I might get some comments on this stating that;s not critical, well what's MORE critical than your ability to stop? That factory uses torque wrenches, the dealers use then as do the truly pro shops; it's legally required to do it because the OEM says so in the OEM service manual, it's the correct way to it and because not doing In Accordance With (IAW)  leaves the mechanic and the shop liable for at least illegal service practices and if there's a collision and it's found that the brake job was done incorrectly it gets really ugly.
I still feel that you have an issue elsewhere. What you do is jack up the truck firmly grasp the top of tire and pull in and out.  If you have movement you have a bad wheel hub/bearing.  This also could of been the cause of your rotor uneven wear no doubt.  So check the wheel for play if you have then you most definitely have a bad hub.  Easy enough to replace there is tons of YT videos on doing so.  Depending on rust and longevity that hub can be a PITA to break free and get off.  A few different methods to get it done though.
You may only get the noise when under pressure and why you may not when you just free spin it.  I am pretty sure it is your wheel hub.
Edited by Brenden Burnham
    RyGuy43
    RyGuy43
  • Who's Online   3 Members, 1 Anonymous, 559 Guests (See full list)
    • consider doing electrical testing?  I would guess some power or ground wire/connection has a problem.   alldata.com has wiring diagrams, connector pinouts and diagnostic procedures you can use to find where the problem is.
    • Any joy with this truck seems to be short-lived.   The CEL for P0172 ("bank 1" too rich) is now "intermittent".   I'm not sure where to check, or re-check, and my energy to keep chasing problems with junk is wearing thin. The P0172 seems to set as I'm coming to a stop, completely off the throttle, when fully warm. At least, that's what it's done the 3? times it's set.   Everything appears normal on the scanner EXCEPT long term fuel trim. There's only one bank on this vehicle because it's an OBD 1.5 with only one upstream O2 sensor. At idle, it's around -16.4% and will dip to -18% occasionally at idle or off-throttle. LTFT approaches 0 when throttle is held at 2500rpm. Short term appears normal, much closer to zero all the time. The LTFT tells me the engine is running rich at idle but compensating at higher load. But, why?   The EVAP purge valve doesn't appear to be leaking/sucking fuel vapor continuously. Is it sticking just as I come to a stop and the engine is choking on fuel vapor and sets the P0172? But that doesn't explain the persistently negative LTFT. Disconnecting the purge valve doesn't seem to make any difference.   I suppose that leaves another dang issue with the fuel injector. A leaking fuel pressure regulator, a new leak in the spider, or a leaking fuel injector/poppet valve I didn't see, or a small crack in one of the spider legs.   The vacuum line leading to the fuel pressure regulator doesn't have raw fuel in it. It doesn't even smell like fuel when it's pulled off, not until you suck air through it, then you can tell it leads to a fuel component. I'd consider that normal? Nothing is signaling this is a FPR issue from the outside, at least.   The oil smells like fuel but it's not building volume. I've noticed most oil in most engines smells like fuel to some degree so it's hard to say if the smell is an issue or not. Or if the engine just still smells like fuel because the crankcase was full of it a few hundred miles ago. But it's been changed twice since that original issue of the leaking fuel line dumping fuel into the intake.   Patience is running very thin. Every win seems to be accompanied by two steps backwards, or another issue that leads to removing at least the top half of the intake manifold. Enough! LOL
    • First off you mentioned "Toyo Says" and then gave the pressures 45/50, was this some person at the tire shop that pulled those numbers out of his head ?   Now of course I can't know your exact axle weights front and rear, however I have much the same pickup as yourself other than not knowing your starting weight as per the pounds the truck rolled out of the factory at due to the options yours did or didn't come with or what you have added beyond the extra tire weight. The correct way to know 100% where a person is at is by weighing each axle with the typical weight the vehicle is driven with and that means taking into account passengers and making sure you figure in a full tank of fuel and a little grace for whatever you may put in the bed "groceries" !    I am looking at and not that it really matters as all the tire companies use the same charts anyway, but I am looking at the comprehensive Toyo tire chart in the section that your tire falls under and I know it sounds confusing but your tire is not an LT metric tire like your factory tire but instead because its a standard inch measured tire its under a different category called an LT floatation series tire. That makes a difference as LT metric tires they don't want to see run below 35 psi at highway speed where as with the LT floatation series it can be run down to 25 psi on the highway as long as the weight on the said size of tire is agreeable with or less than that minimum 25 psi. It blows many people away that how is this physically possible, an empty truck for one thing and larger tires with the same size wheel diameter have a lot more air volume so they can carry the same weight as the smaller tire with less air pressure.    So my truck, I have the stock 275/65R20 wheels and tires and I have a bit of weight in the box with a bak flip cover and a rubber bed mat and some tools and spare gas. The front of my gas truck weighs a bit more than some trucks of the similar spec due to double batteries and alternators. However with full fuel and just me in the truck I am weighted such that I can run 40 front and 35 rear and so that is what I have done since day one.    If I base your truck at or slightly below the weight of my truck, in theory with your tires going by the tire chart you might be right around a minimum of 30 pounds front and 25 pounds rear. Of course that would hit pretty much minimum cold inflation pressure one could run with that tire size and a near empty truck. If you have access to an accurate weigh scale to do individual front and rear axle weights I would suggest you do that and make sure your topped up with fuel and whatever else in the truck before you weigh it and then you will have a great starting point to work off of and figure out what your bare minimum pressures are you can safely run. If you do much in the way of hot weather high speed driving, bumping up a bit for a safety margin is never a bad idea but just depends on what type of driving you do. I will include the Toyo chart and the floatation series sizes start on page 31. Without a doubt at these pressures I am speculating at minimum wise for your truck, it would most certainly ride very different then it did when you were using 55 lb front and rear.     https://www.toyotires.com/media/pxcjubjs/application_of_load_inflation_tables_20200723.pdf
    • Take an automotive stethoscope to the vacuum pump. Iirc those tick as well.
