very weird the other day, the monitor on my programmer had tranny running about 50 degrees higher than the dash showed...almost 200 while at idle.
Going to do some digging and see which was right
Just towed my sons car on a UHaul trailer, so about 5000 lb. Total of about 350 miles mostly around 70 MPH. 2019 6.2 w/10 speed. Was between 163-169 deg the whole trip.
Damn those are good temps!! What was your mpg along the way?  5.3 or 6.2?
Did you ever find out which was right?  Im assuming the programmer was glitched.
6.2 averaged 12.5
My 5.3 gets tranny fluid every 60k miles. I do run the BG synthetic fluid. Best I have seen in years.
    ShowMeShooter1332
    ShowMeShooter1332
  • Who's Online   1 Member, 0 Anonymous, 6,762 Guests (See full list)
