I recently purchased a used, 2020 GMC Sierra. The top of the plastic cover over the two tailgate buttons has a crack in it, and I have looked and looked and haven’t been able to find a part number or even what it is supposed to be called. Does anyone know or can point me in the right direction?
Also, has anyone ever replaced one of these? Is it difficult?
I love this truck. There have been a few things that I have had to fix, or chose to upgrade, but this one bugs me every time I open the tailgate. Pics attached of the part I am referring to in case I have not been clear with my explanation.
Thanks!
10 minutes ago, CamGTP said:
He has the multipro gate.
Looks like that one hit the hitch ball. Be sure to remove the hitch when opening the small section of the tail gate.
Yes, that was my thought also. I fall into the “I don’t drive around with my hitch in place when I’m not towing” category. Although I understand how someone could accidentally hit the wrong button. It took me a few times to remember which button is which. I didn’t realize for two weeks that the handle actually has a diagram to help us slow learners.
      🤣   Had mine almost a year and never noticed that. Thanks   👍
Look at the pic posted at the top, You can see the outline under the top button of the upper section. At least that's what I see!!
Edited by WeGone
Well, I'll be. I saw that and visualized a design. Now that it is spelled out, I see what would be considered a pictograph of the inner gate.
I went by...top botton...top gate. Bottom button...bottom gate.
Thanks for pointing it out to a non-see'er.
Evidently the original owner couldn't read pictographs any better, than the rest of us.
I would agree with you, he definitely did not!
I didn’t notice the outline of the inner gate until the first time I looked at picture of the rear of the truck I had taken to send to a friend. That’s when I had the “well I’ll be” moment. I had to walk outside to look at it just to confirm that I wasn’t seeing things. Sure enough, it had been right there in front of me for two weeks.
There are a few things that are minor annoyances with the truck, but overall I really do love it! The last truck I had was a 1993 Chevy (which I had until 2013), so this is definitely a huge leap in pretty much every category. Been driving an SUV for the past 8 years, so it is really nice to be in a truck again.
This forum has been a huge help in tracking down info and learning things “the easy way” instead of the hard way! Thanks again to all who responded, and thanks gemarsh for the link and part name. Now I just have to find a GMC service department around here who is as competent as you guys!
Its an easy DYI the black panels you see after lowering the step (inner two) snap off you will see two 10mm bolts remove, the handle snaps off top first. the cameras are held on by small torx screws.
    Whit.the.COB
    Whit.the.COB
  • Who's Online   3 Members, 0 Anonymous, 1,260 Guests (See full list)
    • Yep! This should be a pin somewhere as @pgamboa really dives into all of this. Thanks for reposting the link!
    • I did the new thermostat after doing a 'flip' for a year. Runs as cool one way as the other in the summer but in the winter there is a bit of a floor. Yellow with the new 70 C thermostat. My data over the life of the unit to date. Still need more cooler. Anyway that floor helped both winter fuel economy and shift quality in the winter. I found it a good balance.
    • Evan Williams Bottled in Bond   So pouring the last of a bottle of Evan Williams Black label last night I set off the the state store for a refill only to be denied the by an empty shelf. Rats.    What the did have was a bottle of Evan Williams Bottled in Bond. 100 proof. Hum, a few bucks more but a known distiller. Lets have a swing at it. ( I have before )    Cracked it open and pour a serving over ice. Hum.... more heat, yes. More alcohol naturally. But the barreling not the proof brings the taste and this one came up short.    Oh is was familiar but the heat ran the barrel over like a Peterbilt runs over a squirrel. Could use a heavier toasting of the oak me thinks or perhaps a longer barreling. Who knows. But what I can say is ice or a water back isn't the answer. What kills one kills them both. Sad. It is a pleasant drink....if you have little to compare it to.
    • I've had exactly one set of Bridgestone. Lasted five year and 125,000 miles and had I known better 15oK would have been a cake walk. I would have bought a like set had they not tripled in price since the first set. I removed them at said mileage with 5/32" remaining in dead even wear all four. They were fuel efficient, quite, comfortable and predictable.    Early on I got a very good alignment checked at least once a year, sometimes twice; kept the tires properly inflated, balanced and rotated. And I've found that many a tire issue can be avoided with great maintenance practices. Lot's of tire dealers will do rotation and balance (simple) for free for as long as you own the tire they sold you so no excuse not to.    Bead prep, alloy integrity and stem health have a huge impact on inflation stability. There are more mountings done poorly that perfectly. Finding a good tire guy is gold and as important as finding a tire you like.    That 3X price increase now two sets of "other tires' later is starting look like a bargain.      Bad maintenance kills more tires than bad tires.
    • Atlas, you kill me As aggravating as a project like this can be you have been unable to hide your fascination with learning and using that angst against this beast like a Ninjitsu Master. It amuses you, admit it now.      BTW, love your writing style. 😉
