I just replaced the door hinge pins and bushings on the driver’s door because the door was sagging. After doing that, I adjusted the striker because it was sitting a little too low. I got the door aligned with the striker so it actually closes without force, but now the door is sitting too high. The top of the door is above the upper body line, which is causing air to whistle in through the door seal. Is there a way to fix that, or do I have to bend the hinges? I’ve tried googling and all I can come up with is how to replace the hinge pins and bushings. Thanks for any help.
Rick
is it possible someone bent the hinges trying to make up for the worn bushings? I know the body side is welded to the pillar, is the door side welded to the door or is it adjustable? you might want to have an autobody guy take a look if it's welded too, they know all the tricks to line stuff up
I’m pretty sure the hinges aren’t bent. I had them out and took a look when I had it apart. It was sagging pretty bad before I put the new pins and bushings in. It just lifted it up a pretty good amount. I thought it was kind of odd, but I’ve never replaced these before, so I wasn’t sure if this has happened to anyone else or not.
Oh, and I’m pretty sure they’re welded on. Edit: I almost forgot…they’ve been replaced at least once before. They weren’t the originals.
Edited by Rick C.
Forgot info.
so if they are welded both sides the only way to adjust the door is by bending the hinges . if you drop the striker does it help? the latch may have a little bit of adjustment but may not either. a well equipped body shop should have the tools to align the door by bending the hinges. seems to me I saw a tool for that in 1 of the tool catalogs
I know I had to adjust the striker up because it wouldn’t latch without slamming it after I replaced the parts. I’ll double-check the hinges when I get home in the morning. I’m pretty sure they’re welded. If they are, I’ll do some searching to see if I can find a tool like the one you’re talking about.
I believe I found the tool you were talking about. My wife left before I could look at the hinges, though. I’ll look at them tonight after she gets home. Hopefully I can get that tool and see if it’ll align the door better. If not, then it’ll be going to a body shop. You’re right. The whistling will drive me crazy. Lol
If the holes in the hinges where the pins go are worn bad then the doors will sag.
That’s the thing. It was sagging to begin with. So I changed the hinge pins and bushings, and it actually lifted the door HIGHER than it’s supposed to be.
What are we driving? What model vehicle? If either side of the hinge has bolts there should be some adjustment possible by loosening the bolts and lowering/lifting the door accordingly, you'll need a floor jack with a 2 x 4 between the jack and the door to hold the door at the right height. If the door side of the hing has bolts there may be shims between the hinge and the door. If so remove the shims. Back in the day  I have seen hammers put in the hinge area and the door pressed towards the vehicle. This BENT the door UPWARDS to correct for a sagging door. I don't recommend this as the hinge area of the door will start to "oil can" Shims are best on bolted hinges. Keeping the hinge pins and bushings in good repair and lubed is essential to good door action. Other than the weight of the door causing the hinges to wear and lack of lube causing the door to drag pulling on the door when getting in/out of the truck bends the hinge face of the door; this weakens the metal. So when getting in/out don't hand or pull or use the door in any way to get in or out of the truck. Get a A pillar handle or one above the door inside the vehicle.
they are welded both sides , no adjustment so ...the only option is bend the hinges I think ,but the auto body guys know. You said they had been replaced before, the doors or the pins?
    • Two interesting tidbits of information which are NOT related were just released.   One, regarding the possible thrust bearing issues / engine failures with the 3.0. Demonworks just did a segment in which they believe they may have found "a" or "the" cause of thrust bearing failures: A missing thrust bearing. If the engine doesn't have all its thrust bearings from the factory, the missing bearing can cause extra play which ends up destroying a nearby thrust bearing which then sends metal through the engine.       Of other importance, Lake Speed Jr released some interest information regarding oil weight selection for the 3.0. Comparisons of:   AcDelco 0w20 Dexos D Mobil 1 ESP x2 0w20 Dexos D Mobil 1 ESP x2 0w30 Mobil 1 ESP x4 0w40. Mobil Delvac 5w40   Spoiler alert: The Mobils are PAO Ester -base and the ACDelco is a Group III base. Mobil shows lower wear in their tests for similar weights. Additive packages between 20-30-40 weight ESP's appear to be the same, but only 0w20 is Dexos D licensed. Wear is even more reduced with 30 and 40 weight ESP although all perform very well and resist shear and provide very similar viscosities within temperature operating ranges in the 3.0.   There are even more surprises, so just go watch it.
    • Hello Guys I'm new to the form,         I just put a 7-inch Rough Country lift on my 2016 GMC Sierra 1500 with the 5.3 and I also put a Borla exhaust on it. But I noticed when I'm in park or in neutral and then I rev my truck up really quick there is a bad click noise and I think it's coming from the motor somewhere. Anyways I got a video of it I will attach below I was just wondering if you guys think its rod knock or lifter tick or something like that because I know the AFM kind of made the lifters weak on these trucks.       Thanks!!!!! RIP - Chevy 5.3 IMG_6043.mov
    • We’ll have to agree to disagree. I didn’t experience or know anyone who had a decent car after 100K miles in the 60s through the 80s that were daily commuter vehicles. Unless they were collector vehicles. Of course things cost more due to inflation. But we also make more money. The biggest money drains these days are things people think they need today versus what we require back in the day. Like cell phones and internet as examples. Another example is where you live. Cost of living varies from state to state. I would need twice the money to live in NJ vs Texas in retirement. The car you recently purchased was less than my first car with inflation at 3000$ in 1973. I didn’t have air, electric windows, cruise etc. Purchasing power is equivalent, you just have to do the research.
    • Sierra HD Pro:   - If you want a power driver's seat on the Pro, you can't get it.  You have to go to SLE.   - Factory remote start?  Can't get it on any of the Sierra Pro trim (1500 or HD).  You have to go SLE.     - 7 inch radio has limitations for replacement if you wanted to upgrade the screen, etc.    - Steering wheel radio controls?  Nope.  Can you add them?  Yes.  NOT CHEAP.  Requires a new instrument cluster, steering wheel and wiring harness mod kit.     - Fog lights?  Nope.  And no factory path to install them.    Sierra HD SLE:   - IMO, the larger radio screen is a much better interface.   - Fog lights?  You can get them.  Steering wheel controls?  Has them.  Remote start?  Yep.  Power driver seat?  Available.       Silverado WT:   - Same as the Pro above however you CAN get factory remote start installed at the dealer for the WT Chevy.     Silverado Custom:   - Comes with 20" wheels only.  Can you swap later?  Sure.  But.  Truck is calibrated for the stock 20s (34" tire) and no path to properly recalibrate.     - Power seat?  Yes.   - Steering wheel controls?  Same as the Pro above.  No but can be done and not cheap.     Silverado LT:   - Same as the SLE.  You can get or it comes with many features you can't do on the lower trims.       I'd say its all going to come down to what you NEED and what you WANT to have that you'd benefit from.  For me, things like power seat is a must (I hate the WT/Pro seating position), so I'd have to go Custom, LT or SLE right out of the gate.  Steering wheel controls?  Should be standard in 2026 across the board IMO, so again, puts me to LT or SLE.
    • I have a 1500 but the Custom trim. I bought it solely for the simplicity meaning less electronics. I also love the old school gauges. The only thing that I like about the LT better than my Custom is the front grill. Otherwise, absolutely no regrets choosing this trim.
