I purchased and installed the kicker sub from the chevy accessories site.  It adds a lot, but makes the fronts unbalanced.  I need to reduce the base otherwise it overpowers the system, and by reducing the base the fronts become a tinny mess.  There are only 4 wires to connect it:  power, ground and 2 leads from a wiring harness in the drivers side kick panel.  Is it possible to bridge the 2 leads with a volume control knob to essentially control the signal strength to the sub?  I'm almost regretting my purchase as it took me ~4 hours to install it and it's not the greatest.  I would rather have purchased a few separate components for the independent controls.  Hoping there's a solution.
btw, it is in no way "plug and play".
Thanks.
I just installed my kicker sub in my Silverado. I bought the kicker bass knob from Amazon. It plugs into the amp and then you can run the wire up to your dash and set the knob wherever you want. That way you can control the equalizer and your sub output. Also on the back of the sub actually on the back of the amp or six dip switches. First three are input levels. I set mine first two up third down four and five up six down.
14 hours ago, newbcakes said:
Hey guys, thanks for the replies.  I don't think the sub I purchased has any plugs or dip switches on the onboard amp.
The two leads are tapped into two wires (not RCA).
I have the same sub as you. When I had a problem with my amp, I called the number below. They were super helpful.
Kicker Customer service
(800) 256-0808
(800) 256-0808
What did you have a problem with and how did they help?
@truckguy82 this may be the first.
Here is what Kicker support said in an email reply to me:  "you must use the bass control or equalizer on the OEM headunit to adjust that product. If you have any further questions let me know. Have a great day."
Edited by newbcakes
too quick on the enter key.
There are controls in the OE head unit; however, by reducing the bass to satisfy the subwoofer, you also reduce the bass to the rest of the system.  This makes the fronts and door speakers sound very tinny and base muddy.
The Amp wouldn't power on. Over the phone we tested voltage on a couple of wires and came to the conclusion the amp was internally shorted out. I found them very helpful over the phone.
Edited by UrbanRage
    • Yes.   Yes.   We might be intermingling ideas with the term 'severity', in one of my past vehicles it could pull up DTC via the vehicles own user interface, at any given time when one would do this there would be an assortment of codes that were 'trivial' including 'communication' issues. This would generate a bunch of, potentially false alerts or some many that they would get ignored. Which you mentioned earlier.    You also mention several things that might be redundant with the vehicles own systems or indicators: The truck has an oil pressure gauge, monitoring it via this other system wouldn't be a priority except in comparison to other values or if there is an actual oil pressure problem.   Same thing for miss-fires or other problems, the MIL already signals the operator to an issue...   ...to the point about what one wants to see first, if there is a miss fire detected, I want to see miss fire counts or fuel trims first, if I have an oil pressure problem I want to see the oil pressure first. So, perhaps the 'systems' that are showing abnormalities are what gets displayed first.   I think your device is what connects at the OBD port, ease of use for the consumer, it could still have a 'pass-through' port for a second scanner, computer, etc.   Yes.   Based on my comment above, if an error appears, the report would be more specific to the system having an error.
    • Saturday 87 was 2.98 at the local meijer when I filled up my car with 93.
    • I like the idea.  I thought about putting a deposit a few years ago when they first dropped.  I still want to drive one and have inquired about doing this with them, like a ride and drive event they said they are coming but it hasnt happened even with them built in Indiana.
    • That's a tough spot to be in, I personally would question spending 1/2 the book value on a repair vs. selling it as-is.    Presuming you own it out right, sell it for 10k and have a down payment for a replacement truck, or spend 10k on the one you already have...   I still think there is a cheaper transmission out there via recyclers, aftermarket or rebuild. (Cheaper than 5k for the unit)
    • Sadly, there's a drought of good 92-95 4.3 cars at junkyards in the area otherwise I would have gone fishing for parts. Not that they don't come up, there's just nothing good in the yards right now.   I tore into the intake yesterday evening, easier than I thought, and I might have this problem licked for cheap. Two of the intake studs came up with the bolt on removal, no big deal but that's why it looks funny with studs only on one side.   There's pooled gas on both sides of the plenum. Highlights boxed in green. Picture-right side has an obviously split pressure line from rubbing on the #5 injector nylon line. #5's line is worn in that spot but not all the way through. Passenger side intake (picture left), not sure, but I think the pressure regulator is hosed. Rebuilt spiders don't come with the pressure and return hoses so I'll need to replace those no matter what. A pressure regulator is $30 so I'll try that and if I end up having to swap the whole spider, it was $30. I'll be grinning ear to ear if that's all I need.   Parts arrive Tuesday.   Sure enough the shop was here before. That's a new gasket. Vacuum lines and wiring are a tangled mess, I sorted that out last night as well. Spent about an hour just picking up general slack and shoddy reassembly around the engine bay. Cheek-pokered the battery tray, got it all cleaned up. Sometimes things just need a little elbow grease and a few minutes of time to be right again.
