Anyone replace their negative battery cable on a 2015 2500 with 6.0?  I have a intermittent no power issue and have narrowed it to the cable (Known problem).  I would need to do it in the parking lot of my condo, no lifts or ramps.  Thanks
I recently replaced the battery for the first time in my 2017 3500HD with 6.0 and while doing this noticed that the battery post was a little bit wiggly on the battery. I’ve seen this happen on cheap batteries before especially if there was a long battery lead that wasn’t tied down well in the engine bay, but I was surprised because this is a AGM battery and they aren’t cheap. I wasn’t having any problems but noticed a lower voltage under load so I just went ahead and replaced it. Problem solved for me. I checked all the connections when I did this. There are 5 positive and the one ground connection on mine. The ground connection is very substantial. It was the longest time taking battery replacement I’ve ever done.
