Ordered the High Idle Option with the L8T.  Trying to figure out how to make it work, and couldn't find anything in the Owner's Manual in this regard.  So I did a Google search, and found this excellent video that explains how to activate the function.
Basically the steps are:
* Engine Running
* Transmission in Park
* Parking Brake set
* Select the "Set" function of the Cruise control
This increases idle speed to approximately 1,200rpm.
To turn off the high idle, select the Set function, Cancel function or step on the foot brake.
Hope this is helpful.
https://www.youtube.com/watch?v=xxovWkmGFiI&ab_channel=FamilyAdventures
ETA: This is an optional feature, not standard.  So if you try this and it doesn't work, you may not have the option.  It may be something a dealer can initialize though, since it is all software.
Edited by sheath
* Engine Running
* Parking Brake set
The brake pedal must be off when you press the set button
foodle
14 hours ago, pokismoki said:
isnt it located in the infotainment system?
I haven't looked.  If you find it there, please post up.  The video and my explanation works though.
foodle
Yes, since the foot brake cancels the function, stepping on it would not allow it to set.
Increases alternator output and increases cycle pressures and temperatures, which makes the extended running easier on the engine.
14 hours ago, Flatus said:
What is this purpose of this?
I added the option for three reasons.
* Increase alternator output when I'm working the winch to clear brush and trees, repairing fence line, etc.
* Increase AC compressor rpm so that it cools better in the cab during extended idle times.
* Spend more money on gas, because the oil companies aren't making enough off me already. 😉
  • Haha 1
Does having that option bypass (turn off) the factory 15 min idle shut off? If so, that would be nice.
I haven't let it run for more than 15 minutes yet without moving the truck, so I can't tell you.  The 15 minute shut off can be deactivated by the dealership service department though.  I plan on having that done at the next service.
The 15 minute shutoff is after a remote start if you don’t do the steps to extend it. If the car is actually on, the shutdown time is longer, but I can’t remember exactly how long and didn’t find it immediately in the manual.
I think if the engine is running, and the key fob is used to lock the doors the engine will run for 30 minutes.  I can't find this in the Owner's Manual.  This can be turned off by the dealership service department (there is a thread on this forum discussing this).
If you remote start it is 15 minutes, with up to 30 minutes if remote start function is pushed again (page 21 of Owners Manual).
Curious, does the engine still shut off after 30 minutes when the high/fast idle is activated? I've read the manual, but it doesn't provide any details outside of operating the high idle function. I'm considering having the feature added to my truck at the dealer, but having the engine shut off would be a deal breaker.
From what I recall reading, the shutoff function operates regardless of whether you are in normal or high idle. Sheath says the dealer can turn off the auto shutoff. You can also defeat the auto shutoff at normal idle by running in neutral, but I don’t like the idea of that. I don’t believe you can use high idle in neutral.
    Tbhats2130
    Tbhats2130
  • Who's Online   3 Members, 0 Anonymous, 1,239 Guests (See full list)
    • You could try a used 1, they used that engine in the Astro vans, Plenty of them in the boneyard. Look for a wrecked or rotted 1 so the chance that it was scrapped for that reason and not a mechanical issue will be greater
    • Google converting 98 4.3 spider injection to carburetor if all else fails.
    • The truck is a 1995 Chevrolet S10 Blazer, 4.3 VIN "W" engine. :cracks knuckles:   On a whim - because I needed a headache - this truck was for sale so I stopped to take a look. Doesn't run. Well, it does, but barely. Long crank, choppy idle, bad misfire(s), it REEKS of fuel. I can DO this..I'm thinking. Diamond in the rough. One owner until last year. A young guy is selling it, he bought it 6 months ago. It stranded him more than once, he's got a newborn. It was in the shop 10 days ago and he "thinks" they said it needs a new fuel injection system. He can't put any more money into it, needs it gone. I was thinking of upgrading my Macbook, which is a total want, not a need. For less than the price of a new laptop I can have fun for months tinkering on this truck and enjoying it. I'm taking this truck home. The guy was beyond thrilled, his wife was there, she thanked me profusely, I could tell they were hurting. They seemed like good people in a bind.   Some parts, a wash, maybe a set of tires, and I can have a few months of fun and then turn it for beer money (or the next project).   Sure enough, there's a work order from a shop last week in the INCHES of paperwork on this truck dating back to when the first owner bought it. They put a new distributor in it, fuel injection work describes basically opening the plenum and putting it back together. He said he couldn't afford any more work so he had them button it up and that's when he put it up for sale.   I'm not well versed in 4.3. I did discover 1995 uses the 1992-1995 SCPI "Spider" injector which is riddled with issues from splitting lines, clogged or cracked poppet valves and plastic spider legs that crumble over time. Cool. I'll just order me a ne---. Oh, the auto parts store doesn't have it? Rock Auto doesn't have it. eBay? $$$$$$ for used. These are UNAVAILABLE period end of story unless you know "a guy" who's still got one in a box somewhere.   Can't upgrade to the '96-'04 injector, it's a different plenum, wiring/pinout and sensor config.   There are a few kinda "know a guy" -guy rebuild services for these injectors out there for about $350. Okay, Okay... I'd like to know if anyone has used them? Anyone got a lead on these crappy 92-95 spiders?   I also don't want to send MY spider to Narnia and back without knowing if that's truly the problem. I guess I'll need to pull apart the plenum and do some digging.   I was also thrown for a loop. This 1995 model year truck has an OBD-II connector. The interface is decidedly not OBD-II. I can read and reset trouble codes and view live data, but there's not a lot of data. Like misfire count and on what cylinder, that's not there. It's OBD-1.5.   Nothing is ever easy. Now it makes sense why this guy wanted to disappear this thing for cheap. I'm guessing the shop told him the injector is toast, the part is unobtainable and they're not going to sort sending the thing to a rando offering rebuild service on craigslist, and the kid likely can't be without a working car for 3 weeks even if they'd facilitate that.   Experience with these early SCPI's? Stories? Things to check? Sympathy? (..Nah...)   This can sit until I sort it. But I haven't had a problem with a vehicle I couldn't easily solve in a long time.
