I know it's probably too early from someone to try, but would anyone have a rough idea if the new 23' lights would work on the previous models? I know the older ones have 3 lighted areas compared to the 2 on the new ones, and the bottom turn signal is now integrated into the DTRL. I just hate how my LED lights would need a full headlight replacement if they went out compared to replacing a bulb. I'd be fine with some gaps, which also makes me wonder if the grill and or hood would work.
The hood is the same on all models except the Trail Boss and ZR2. The fenders are the same, just the front "sideburns" from the old models are different. The bumpers and grilles are different as well as the headlights. I don't know if the core supports are different or not. I have no idea on the light setups since the refresh trucks all went to a different global architecture for the electrical systems. So even if you could physically bolt them up, you might not be able to make them work properly electrically.
