This is the system I'm putting in.  The buttons on the controller don't work anymore and can't get a replacement.  So I'm going to cut the controller off and add a digital bag pressure guage and a switch to air up and down the bags.  I can't figure out how to add the switch.  The switch I guess is a 3 position momentary switch that defaults in the middle and you have to hold it to either side.  I assumed that one way will inflate  and the other will deflate as it came with the guage package.    I got the guage to work.
i am not familiar with your system.
Will the compressor run only when you want to increase the bag pressure?
Where/how is the air exhausted to lower bag pressure?
Does the solenoid allow the pressure into the bag, or is it there to exhaust air?
Is there a check valve on the compressor discharge to prevent air leakage back through the compressor?
Yes the compressor only runs when you increase the bag pressure.  The air is exhausted from the air solenoid.   It is to exhaust the air pressure.  The check valve for air is that block.  The air from the compressor comes from the bottom and into the left and right ports atbthe top to the airbags.  The others a pressure sensor that tells it when to shut off at the set pressure.  But that all doesn't work anymore.  I need to be able to control it via the switch, thaya whatbi need help wiring it up.
Edited by tweeder01
There may be other ways of doing this, but this is what I would do.
A DPDT switch is available in toggle-switch style or rocker-switch style.    ...There will be six terminals and they may be screw terminals or push-on or solder type.
The reason for using a Double Pole Double Throw switch instead of a Single Pole Double Throw Switch (SPDT) is by wiring it as shown, you increase the life of the switch and add durability.
The switch needs to be DPDT  MOMENTARY (it returns to the center position when you release it) CENTER-OFF (no continuity to either pole).   ....There are lots of sources online.  ....Look for at least a 15 or 20 amp rating.  .....Price will be anywhere from $5 - $20 depending on what you choose.
Moving the switch one direction will activate the compressor.  ...Moving the switch the opposite direction will activate the solenoid valve.
Edited by cwtech
added info
yes that looks to be it.  But the guage came with a i guess a single pole double throw switch that i would need to use as its integrated in the guage mount.
i left everything plugged in as it was in the previous truck that was working for reference.  the solenoid has two wires, which is which?  I know the diagram shows one to ground and the other to the switch, right now the volt meter shows both have 12 volt power.
EDIT:  both wires show power when they're plugged in making a loop.  only one has power when both wires disconnected.
Edited by tweeder01
On 8/13/2022 at 8:04 PM, tweeder01 said:
i left everything plugged in as it was in the previous truck that was working for referenceThat is your problem!  ....I don't believe you can use your present gauge or switch, as they are part of the control panel.
....The white wire from the solenoid needs to be separated from the old wiring and connected to ground.
8 minutes ago, cwtech said:
i'm using the wiring harness for ease of use as its all there with connectors.  i cut off the controll unit and was using those wires to add in the new guage and switch.  ok so ill figure out a way to ground that white wire.  Any reason it wasn't grounded from the get go?
Edited by tweeder01
It was grounded through the old connections somewhere - possibly in the controller.
Your original wiring schematic was not detailed enough to know.
Well I made the air compressor turn on with the momentary switch but couldn't figure out how to air it back down by pressing the switch the other way.  Come to find out that the digital air guage I bought is off.  I tried wiring it to the existing pressure switch there but it wouldn't read it.  So I installed the one that came with it but it was quite off.  At 10 psi the guage read 0.  At 30 it was 21.
Can I piggyback on your thread with a question?
I have an ARB dual compressor that I would like to use for my airbag setup. Would it be easier/more cost effective to just buy the purpose built system rather than try to adapt my current compressor? Wiring is my thing, solenoids and all that is not.
    • Can it still be Assembled II?   Viscosity on the decline by various means. Heat on the rise making that worse. Engine RPM in the tank. Smaller motors with more boost trying to emulate an electric motor. Full torque, zero rpm. Then we will triple the OCI. Argh.    But wait....there is more. LSPI has pushed a shift from Ca to Mg and as that cost more PLUS the run to lower sulfur compounds the TBN is moving in the wrong direction for the increased OCI's demanded.    That not being enough to placate a demand for a parameter they can't measure the other sulfur bearing compounds are also under attack. That would be zinc and phosphorus sulfonate compounds. To some degree those are being replaced with boron esters and others, i.e. titanium ect. All of which have shorter service lives. And there there is the "Secrete Sauce" marketing for AW adds that 'Can't be detected by UOA's" but trust me because I (the blenders) never ever lie.    Spoiler alert; ALL additives are sacrificial! Smaller amounts of the old blended with less robust versions of the new do not equal longer service lives. So what are the blenders recommending? Wait for it.......   MOVING THE GOAL POSTS! OMG      Let's declare the long standing TAN/TBN crossover irrelevant and tell people that soot is a great 'graphite' based lubricant which can aid tribo films. Wait, what? Let's declare that the standards used for oxidation and nitration were to conservative and can be expanded. Let's tell them that because GDI fuel dilution, although being a VISCOSITY KILLER and an acid generator is actually okay because we have better base oils that limit viscosity failure limits. (Said knowing this is measured in fractions of a centipoise and in bases not commonly used in shelf oils)   Lying from the heart is not just the new normal but we have a public, a very young public, that is so ignorant of the facts and so sure of their "RESEARCH" into AI driven models base in regurgitated  instead of scientific research based unvarnished, peer reviewed FACTS that the incoming guard is loosing their grip on reality and the OEM's are tickled pink while the blends bend the knee.    You have an ever limited set of tools to work with. And sooner or later those will be taken from you as the API and the EPA strangle the last remaining fluids from the system. What you have left is your wits. If you care to use them.    At some point in the very near future it will not longer be possible to do "What is best for the machine", and be replaced with "The best you have access too". You WILL be rewarded with half the life and twice the cost. That isn't that hard to predict.
