Hey y’all!
I’m about to purchase an 18 1500 LTZ.
The goal is to do the following on it fairly soon.
Light bar behind grill, rock lights (wheel wheels and running boards, separate switch), rear pod lights of some sort for backing up, bed lights (led strips?) and finally an outlet in the bed.
My questions are, can the battery safety handle all this? Or do I need to consider adding a second battery. I’m not opposed to spending decent money to do this right.
-The rock lights under running boards will be tied into the dome light so they kick on when I unlock the truck. Can I do that but also provide a switch to it if I want to turn them on?
-Has anyone done a nice light bar behind the grill that is $800?
-If I put bed lights in, what’s involved in putting a switch in the bed so I can turn them on and off?
-The most important thing to me is finding a nice switch panel for all this. If I need to get something custom cut I will but would love it to be backlit. Again not opposed to spending some money so I can have a place for all of this to terminate.
Thanks so much for the help!
59 minutes ago, probablyflying said:
Hey y’all!
An 18 LTZ should be equipped with factory bed lighting. My 16 LT has it. As for lightbar I would recommend to get a nice push bar or brush guard to mount to. It's asthetically pleasing.
Checl out Rough County - Led Light Bar /w Brackets . i have a 32" mounted behind grill - Lower part of grill , under Z71 grill badge.
My 2016 LT did not have the factory bed lighting. I did buy the OEM kit and install it though.
14 hours ago, probablyflying said:
Hey y’all!
       I would think the factory battery should handle that setup.  If you tie your rock lights into the Dome Lights....you might consider wiring the power for Rock Lights through a Relay, and trigger the relay from the Dome Light wire at the BCM.   (Adding too many watts/amps through the BCM computer may overload it. Relay would solve that).
      Re: the behind-the-grill light bar, this is possible and has been done many times.  But a Light Bar will likely interfere with any Active Grill Shutters that may be present.   There are some YouTube videos that show how to modify your shutters to fit the light bar.
      In my Bed Lights.....I tied +12V power to the constant power at my trailer wiring plug.   Wired a bed light pushbutton switch in series to that +12V power....and drilled a hole in the side of my Bed sheetmetal to mount the switch.
      For your backup light pods....did you want them to come on automatically when you are in Reverse?    Or would you control manually from a separate switch?
     If you're buying an LTZ, I believe this means you already have the Upfitter switch panel, below the radio.  Correct?
     Overall, your setup is similar to mine.   I'll try to find the wiring diagrams I drew for my system, and paste them in this thread...
Edited by Dresari702
10 hours ago, Dresari702 said:
Thanks so much for the help! I would prefer the rear pods to be switched.
What did you for a switch? I’m looking for something that’s super clean and can have everything in one.
16 hours ago, probablyflying said:
For the Bed pushbutton to control the bed lights.....I just used a latched pushbutton.  Push on, push off.  You can find illuminated ones, and also ones made in stainless steel.    For the other switches....I put them in a blank area in my overhead console.
I may have rushed it a bit.....but can you open the attached PDF?     I mocked up a wiring diagram that you can follow.    I also included pics where I could, showing devices you asked about.
Lights Wiring.pdf
Dude you’re the best! Thank you so much! It opened fine. Looks great. Really appreciate the help.
No prob!   I checked over the drawing and it looked right (assuming you get typical automotive relays).   But if you have questions, feel welcome to shoot me a PM message.   A guy on here, Phil, with screenname "Pgamboa" is also VERY good with automotive wiring.   Could shoot him a message too.
I used Rigid flush mounted LEDs as backup lights on my truck. They fit perfectly inside the rear foot steps on the bumper and are super bright. I would highly recommend these. These would also work great for your rock lights... depending on where and how you want to mount them.
Rigid flush mounted LED lights.
https://www.amazon.com/gp/product/B01HJ4G9QI/ref=ppx_yo_dt_b_search_asin_title?ie=UTF8&psc=1
Any Photo's of your setup ?
     I imagine he is used Rigid Ignite Flush Mount pods.....that's about the only size of Rigid LED light that will fit in there.    I attached a pic of what one looks like.
Correct, these are the ones that I used and I mounted them the same way.
    • Google converting 98 4.3 spider injection to carburetor if all else fails.
    • The truck is a 1995 Chevrolet S10 Blazer, 4.3 VIN "W" engine. :cracks knuckles:   On a whim - because I needed a headache - this truck was for sale so I stopped to take a look. Doesn't run. Well, it does, but barely. Long crank, choppy idle, bad misfire(s), it REEKS of fuel. I can DO this..I'm thinking. Diamond in the rough. One owner until last year. A young guy is selling it, he bought it 6 months ago. It stranded him more than once, he's got a newborn. It was in the shop 10 days ago and he "thinks" they said it needs a new fuel injection system. He can't put any more money into it, needs it gone. I was thinking of upgrading my Macbook, which is a total want, not a need. For less than the price of a new laptop I can have fun for months tinkering on this truck and enjoying it. I'm taking this truck home. The guy was beyond thrilled, his wife was there, she thanked me profusely, I could tell they were hurting. They seemed like good people in a bind.   Some parts, a wash, maybe a set of tires, and I can have a few months of fun and then turn it for beer money (or the next project).   Sure enough, there's a work order from a shop last week in the INCHES of paperwork on this truck dating back to when the first owner bought it. They put a new distributor in it, fuel injection work describes basically opening the plenum and putting it back together. He said he couldn't afford any more work so he had them button it up and that's when he put it up for sale.   I'm not well versed in 4.3. I did discover 1995 uses the 1992-1995 SCPI "Spider" injector which is riddled with issues from splitting lines, clogged or cracked poppet valves and plastic spider legs that crumble over time. Cool. I'll just order me a ne---. Oh, the auto parts store doesn't have it? Rock Auto doesn't have it. eBay? $$$$$$ for used. These are UNAVAILABLE period end of story unless you know "a guy" who's still got one in a box somewhere.   Can't upgrade to the '96-'04 injector, it's a different plenum, wiring/pinout and sensor config.   There are a few kinda "know a guy" -guy rebuild services for these injectors out there for about $350. Okay, Okay... I'd like to know if anyone has used them? Anyone got a lead on these crappy 92-95 spiders?   I also don't want to send MY spider to Narnia and back without knowing if that's truly the problem. I guess I'll need to pull apart the plenum and do some digging.   I was also thrown for a loop. This 1995 model year truck has an OBD-II connector. The interface is decidedly not OBD-II. I can read and reset trouble codes and view live data, but there's not a lot of data. Like misfire count and on what cylinder, that's not there. It's OBD-1.5.   Nothing is ever easy. Now it makes sense why this guy wanted to disappear this thing for cheap. I'm guessing the shop told him the injector is toast, the part is unobtainable and they're not going to sort sending the thing to a rando offering rebuild service on craigslist, and the kid likely can't be without a working car for 3 weeks even if they'd facilitate that.   Experience with these early SCPI's? Stories? Things to check? Sympathy? (..Nah...)   This can sit until I sort it. But I haven't had a problem with a vehicle I couldn't easily solve in a long time.
    • I have four that read by the dash 8 to 10% better than miles/pump calculations and I have one that is spot on.
