First off, I'm going to say this has to be the worst forum EVER to try to search for a common issue! WTF is with all the pop-ups??? It didn't seem to be this bad back when I was more active on this site in the past. Anyway, my new HC with auto retract running boards will not always deploy the boards. They'll start to come out when I open my door to get out, then they'll retract midway. I'll have to open and close the door 2-3 times sometimes to make them deploy all the way. I've tried to figure out some kind of a pattern to it, but it just seems so random. Anyone else having this issue??
  • Thanks 1
This is certainly not what we like to hear, mtbadbob.  Please know, customer satisfaction is extremely important to us. Our team would be more than happy to take a closer look into the concerns with your truck. To do so, please send an email to [email protected] with ATTN: mtbadbob/GM Trucks in the subject line.
Please include your contact information, VIN, a brief description of your concern, and the name of your preferred dealership. We look forward to hearing from you. To learn more about GM’s privacy policy, please visit https://www.gm.com/privacy-statement.html.
Privacy Statement | General Motors
Your privacy is important to General Motors. This Privacy Statement addresses the personal information GM collects and how GM handles that personal information.
www.gm.com
15 hours ago, suzannedalton said:
It sounds as though something is binding or blocking drift boss
Talked to the local GM Tech & he said that more than likely a small rock(s) get lodged in the hinges, which makes sense as it's random & I live up a gravel road. I guess I'll just have to deal with it!
  • 3 weeks later...
i am having the exact same problem and I do not believe for one second it is a rock...the day i brought the truck it acted up when i got home...the dealership is trying to get a replacement motor for the driver side.  the passenger side acts up to but not as much...been just a crap experience with these running boards and I have a whole 2000 miles on the truck
Yeah, I debunked the rock theory myself and recently told that same tech it wasn't a rock causing them to do that. I just did a GM factory survey and let them know about it. Some days they work flawlessly, others I have to open and close the doors a few times before the deploy all the way. I'm sure there are others beside us having this issue. My truck started doing this on the second day I got it home, now approaching 4k miles
This is certainly not what we like to hear, hotairgypsy.  Please know, customer satisfaction is extremely important to us. Our team would be more than happy to take a closer look into the concerns with your 2022 High Country. To do so, please send an email to [email protected] with ATTN: hotairgypsy/GM Trucks in the subject line.
www.gm.com
This is certainly not what we like to hear, mtbadbob.  Please know, customer satisfaction is extremely important to us. Our team would be more than happy to take a closer look into the concerns with your 2022 High Country 2500 HD. To do so, please send an email to [email protected] with ATTN: mtbadbob/GM Trucks in the subject line.
www.gm.com
there is a new bulletin that just came out for this issue. it is to reprogram them. wonder if it will help. my passenger side has acted up 1 time in the 350 miles i have owned it.
my other issue with them, is they are slow as sh*t. amp and ford boards are way faster.
wonder if the bulletin speeds them up??
Thanks for the info! It seems every time I mention something like this to a dealership, they act all surprised like I'm the first guy on the planet to have these problems! Anyway, this new truck purchase is the first vehicle I've ever bought the extended warranty for as I figured with all this electronic BS, that'll be what fails after the normal warranty period.
www.gm.com
i just sent the email as per your instructions...This crap is so aggravating...we should not have any issues with this expensive of a vehicle...
On 8/27/2022 at 5:44 PM, hotairgypsy said:
here is one a bunch of examples i can show
Yep, exact same thing I'm dealing with! So, hopefully it'll get fixed with a computer flash then!
This is certainly not what we like to hear, kylant.  Please know, customer satisfaction is extremely important to us. Our team would be more than happy to take a closer look into the concerns with your 2022 3500 High Country. To do so, please send an email to [email protected] with ATTN: kylant/GM Trucks in the subject line.
www.gm.com
    • Thanks newdude!  By the time manual selection is needed, I'm probably too much of a control-freak to depend on the transmission sensing braking to activate automatic downshifting.  I would be anticipating the situation and already be manually downshifting.   This truck replaced a 2004.5 LLY diesel with the Allison 5-speed.  Putting it in T/H made noticeable differences (when the torque converter locked, upshift points, downshift behavior).  On this 2024 gasser with the 10L1000 I haven't been able to detect much, if any, difference.  Ok, I can never tell now when the torque converter locks up.  But I also don't notice differences in shifting.  For downhills, I've probably already manually downshifted by then anyway.  Since it's also more awkward (than the 2004.5) to engage/disengage I don't even bother.  Or maybe it doesn't really matter with just a 3k lb. camper in the bed?   Thanks also for the list of reasons the charging system might select various voltages.  However, what I am seeing doesn't fall into any of those categories.  It very definitely, and very consistently, rises after coasting/braking.  Maybe not immediately, but not very long after coasting/braking.  Very consistently drops voltage when no longer coasting/braking.  It might also be interacting with the camper battery charging (I might disconnect the camper and see if it changes the charging behavior).  I also need to recheck turning on headlights for when I want to force it to charge the camper.   Another JR, in June I converted the camper to LiFePO4.  Since it's not a good idea to try to charge lithiums directly using truck, I installed a Victron Orion XS DC-DC charger (which BTW is AMAZING!!).  Being cheap, I only had to buy that one item (besides the battery, of course) to do the conversion.  The camper OEM 120v battery charger (only 19 years old and works perfectly) and the truck feed the input to the DC-DC charger (not at the same time).  But I didn't want the camper charger feeding back to the truck so I kept the old separator.  I considered replacing the separator with a 30amp diode but that means more work and might add another 1/2 volt drop.  One thing that surprised me was the voltage drop over the long 10awg wire run, so I can only charge smoothly at 8 amps (because the DC-DC charger is completely configurable).  Another reason I don't want an added voltage drop with the diode.  I might also be a little lazy but all this work is being done under the sink with a small cabinet opening.
