I'm looking at a 2022 1500 that's allegedly "built and on the way".
It's equipped with: "L84-Engine: 5.3L, EcoTec3 V-8, DI, Dynamic Fuel Mgt, V V T"
The build sheet shows Option Code "YK9-CREDIT - NOT EQUIPPED WITH DYNAMIC FUEL MANAGEMENT"
Is this deletion a chip shortage issue, or is Chevy deleting the Dynamic Fuel Management due to engine/lifter issues?
Thanks
I recall its due to the chip shortage. And it's one of those where it's welcomed to be not equipped with 🤣
Correct.  YK9 is not equipped with DOD.  Hardware is still in the engine, ECM is missing the ability to run it.  It is not an item that will be retrofitted either so its always off.
With the hardware still present in the engine, what is the reasoning behind the YK9 modification? Is it being done to reduce the chances of engine issues believed to be tied to DFM?
Its possible, but GM's line was for semiconductor allocation.  Delete DFM to re-allocate those for other vehicles.
According to GM:
    Internal components related to AFM or DFM function will be present in engines; wiring, connectors, and fuses will be present in vehicles with RPO YK9. The ECM will not be capable of activating the cylinder deactivation technology.
    When diagnosing and repairing concerns with base engine or electrical function which may be related to AFM or DFM related hardware; utilize appropriate diagnostics within SI and replace any needed components as directed by the Electronic Parts Catalog; no changes will occur to AFM or DFM related components.
    Important: Any truck designated with RPO YK9 CANNOT be reprogrammed and changed to “Turn on” the AFM/DFM functionality.
53 minutes ago, elcamino said:
According to GM:
It can still grenade like all the rest of them.
IMHO, I find it hard to believe that Chevy would turn off an engine's DFM to reallocate its chip. Especially because no DFM equals less MPG, and GM is very concerned with CAFE Standards.
On the other hand, the cam, lifters, and other DFM (DOD) specific parts are still present in the engine. If there is a reliability issue with these parts, will disabling DFM lessen failures?
Edited by AlDAngle
Just bought a new Silverado last week. How do I know if it has DFM? Sticker did not mention any credit for DFM, so safe to assume it has it?
Here is a snip from a sticker with the YK9 option on Build Sheet:
Thanks. Looks like my truck does have DFM enabled.
    Sothpaw27
    Sothpaw27
  • Who's Online   3 Members, 0 Anonymous, 479 Guests (See full list)
    • Can it still be Assembled II?   Viscosity on the decline by various means. Heat on the rise making that worse. Engine RPM in the tank. Smaller motors with more boost trying to emulate an electric motor. Full torque, zero rpm. Then we will triple the OCI. Argh.    But wait....there is more. LSPI has pushed a shift from Ca to Mg and as that cost more PLUS the run to lower sulfur compounds the TBN is moving in the wrong direction for the increased OCI's demanded.    That not being enough to placate a demand for a parameter they can't measure the other sulfur bearing compounds are also under attack. That would be zinc and phosphorus sulfonate compounds. To some degree those are being replaced with boron esters and others, i.e. titanium ect. All of which have shorter service lives. And there there is the "Secrete Sauce" marketing for AW adds that 'Can't be detected by UOA's" but trust me because I (the blenders) never ever lie.    Spoiler alert; ALL additives are sacrificial! Smaller amounts of the old blended with less robust versions of the new do not equal longer service lives. So what are the blenders recommending? Wait for it.......   MOVING THE GOAL POSTS! OMG      Let's declare the long standing TAN/TBN crossover irrelevant and tell people that soot is a great 'graphite' based lubricant which can aid tribo films. Wait, what? Let's declare that the standards used for oxidation and nitration were to conservative and can be expanded. Let's tell them that because GDI fuel dilution, although being a VISCOSITY KILLER and an acid generator is actually okay because we have better base oils that limit viscosity failure limits. (Said knowing this is measured in fractions of a centipoise and in bases not commonly used in shelf oils)   Lying from the heart is not just the new normal but we have a public, a very young public, that is so ignorant of the facts and so sure of their "RESEARCH" into AI driven models base in regurgitated  instead of scientific research based unvarnished, peer reviewed FACTS that the incoming guard is loosing their grip on reality and the OEM's are tickled pink while the blends bend the knee.    You have an ever limited set of tools to work with. And sooner or later those will be taken from you as the API and the EPA strangle the last remaining fluids from the system. What you have left is your wits. If you care to use them.    At some point in the very near future it will not longer be possible to do "What is best for the machine", and be replaced with "The best you have access too". You WILL be rewarded with half the life and twice the cost. That isn't that hard to predict.
