This is how you get my business.
Biosynthetic® Motor Oil 5W-30
Let me know what is in that bottle I'm pouring into my motor and I will!
Figure 27.25 from the previous link provided (credit) shows a few points of interest.
Estolides are NOT Group III+++ fluids. No such thing. It ends at Group III+.
Like any other ester they are Group V and in this case a large part of the product is an Estolide ester. Which means the esters made come from natural oils  such as Soya and Castor Bean and not chemical feed stocks from crude refining such as ethane/ethylene.
Conformation that the mineral portion is a Group III is a plus as is the very low percent of VIM.
Infineum is a joint venture of Exxon/Mobil and Royal Dutch Shell. Very top shelf....
The formula Biosynthetic received it's API certification on. This is good news. If they change the formula they would have to resubmit the testing and that cost more than this start up wishes to speed at present. In fact the reason they went with a "off the self' add package. That is to assure first pass certification. @customboss put up a video on this not long ago.
Interesting because when I first queried them the petroleum base was GRP II+. So they must have improved it.  Thanks for sharing. I THINK the video said it was GRP II+ from Chevron world of hydrocracked bases oils....LOL  I can't hear so I might have misheard.
If you can find that video can you repost it here please?
I misheard because I can't hear.  Just being careful not to mislead.....LOL
At $10 a quart I will use Amsoil OE.
Found it.......
Hydrocarbons from Plants
One of the players in this area is Novvi, whose NovaSpec products meet the APIs Group III criteria and are produced from sugarcane cellulose. As they are biodegradable, use of these hydrocarbons in the appropriate amounts allows formulators to produce environmentally acceptable lubricants that meet the specifications for hydraulic environmental polyalphaolefins and related products, according to ASTM D15380. (Novvi did not respond to requests for comments at the time of publication.)
https://www.lubesngreases.com/magazine-emea/3/a-new-way-forward/
My dog has four limbs, brown eyes and hair. So does my son. Can I conclude my dog is my son?
 :crackup:
Lubes and Greases is WRONG. The criteria for a Group III starts with being derived from a MINERAL OIL. It isn't. It is derived from plant oils. Oh it may meet the API specs for sulfur, minimum saturation and viscosity index but it does not and can not meet the CRITERIA. Lubes and Grease is not the organization who is doing the certifications nor making the rules. Neither is BT or RLI or EVOLVE or some quality lab or Tribologist or  anyone else. The API is the standard. Writes the standards and no one gets a Cert without their approval with REQUIRES conformity to the RULES. Some may not like it but some people don't like allot of things they have little say in. Absent such finality you are left with chaos.
POA's also meet the specs for a Group III and yet they are not a Group III. Why? Not a mineral oil based material and synthetically produced.
Review API doc 1509  Appendix E below:
API Base Oil Categories
Esters, ALL Esters are Group V
Thought we had the nails in this coffin lid hammered down
  • Haha 1
Why I'm interested in Estolides. A personal note.
Aniline point and oxidative/hydrolytic degradation resistance. But mostly Aniline point.
PCMO's contain detergents but those Adpack chemistries can only inhibit deposits. They can not clean existing deposits. Detergents are not solvents. Estolides are HUGE solvents. The lower the aniline point of the finished product the better it's solvency. Aniline point is blendable. Biosynthetic is 35% Estolide base oil. About double the the polyol ester content of Red Line at half the aniline point. Major upgrade in solvency.
A motor oil detergent is a surfactant that envelopes a particle and the dispersant package keeps those particles from finding each other preventing precipitation as sludge. The base oil has a resistance to those particles forming and antioxidants to increase that tendency/ability. Each has limits of saturation that once exceeded leave behind deposits that are hard to remove.
A solvent dissolves those particles into solution even after they have amalgamated and precipitated. It too has a limit of saturation and why we change oil even with the best chemistries. Dilution trumps them all. 😉
But there is a practical $$$$ limit. In problem motors such as the GM 2.4 this ability to clean and not just prevent is HUGE. Same principle used in CUMMINS Restore. I don't know how they compare in finished aniline point but it matters not if I can no longer source a steady supply of Restore.
 :crackup:
WE! who’s we kimosabe? 🤩
Youz.
All in good fun of course.
Night.
    DM22
    DM22
  • Who's Online   2 Members, 0 Anonymous, 2,978 Guests (See full list)
    • I thought I would use your thread and add to it as I just did my first longer drive with my truck in the last couple of days. I drove from the Grande Prairie area of Alberta down to Edmonton and most of where I drove in the city was the ring road so fairly free flowing but a bit of stop and go as well in the city. Stayed the night and returned home and not too many stops along the way each way but every restart and certainly every cold start sets it back for fuel mileage. Why I say that is I see some people will cherry pick a fuel mileage leg after the vehicle had been warmed up driveline wise before hand and its a forgiving ( easy rolling drive leg for example ) and call that their fuel mileage which can give a false perception of reality. I was not heavily loaded at all but never the less the flip bak cover, rubber bed mat, various tools etc and extra jerry cans of fuel all way up to a few hundred pounds of dead weight so its not an empty truck. The cold inflation tire pressures are set more near the freezing point so once they are warmed up driving I was showing 45 front and over 40 rear and realize high inflation pressures would help a little in fuel mileage but certainly not the ride on our crap sections of highway. The weather was good so was not raining as that can really drag mileage down, in fact I had a bit of a tail wind on average driving home. Most people on here would never have driven on that freeway to visualize it but its got a fair bit of rolling type of landscape with numerous river valleys. For the most part I had it on cruise set to 62 although kicking it off if I caught it in time before it started down shifting and self braking going down the grades. Most of the more substantial grades its shifting into 7th I believe as 8th just doesn't have it. Total distance round trip was 643 miles and my overall average and I did refuel three times in all, figured out to 17.65 miles per US gallon. My best fuel mileage section refuel within all of this figured out to 18.46 and these are all hand calculated figures. I find if anything that the trucks computer can be over optimistic, sometimes its pretty close but other times its stretching it. On paper persay in theory the truck would have just about made it on fumes for that whole drive without refueling once.    Which made me think of the topic thread of the wonder if these trucks could do 20 mpg and that is a good question, certainly would have to be on an easy going flat highway, no head wind, the right temperature, not packing around a bunch of dead weight and puttering along even slower than I was I would suspect and going steady and not stopping to smell the flowers or take a piss !. It probably is possible but not without effort to attain that with the wind resistance and weight of these trucks. Of course on my drive most people are passing me if they have the power as per loaded highway tractors, never mind a lot of speedy vehicles but the speed limit is 68 and most are at or well over that.
