truck, 2008 3500hd LMM, LTZ, bought used
2 Separate issue.  throwing them in the same thread since I rarely get much help on this stuff.  Didn't want to waste the air space.
1.  Confirmed that BCM will not turn on fog lights on.  Switch confirmed to work, and BCM is required to switch a relay under hood.  It will not send output to relay.  Wondering if there is a way to reference the numbers on BCM to find a salvage piece?  I won't pay to reprogram because I don't know if that is really an issue.  I am in electronics but without the schematic, the PCB loses me fast so I can't trace the circuit otherwise to verify anything.  I do know for a fact the dash switch sends power requesting lights to turn on.
2.  For years I have fought with the vent selector actuator switching to default defrost.  If in AC dash vent mode, truck VERY consistently starts up with the correct vents, then switches to defrost within 1-10min of running.  If I stop the truck and restart it (drop power to climate unit), it will go back to the correct vent setting and will never change the rest of the trip.  In many cases, I just leave the truck running to avoid the hassle.  For this reason, I am sort of leaning towards the climate dash unit rather than actuator.   As an aside, climate unit many times will switch to 'fresh air' mode instead of 'recirc' even though cabin temp is no where near controlled.
I will say that even in heating mode, the vent selection issues continue.  I have not found anyone with similar symptoms to relate this issue.
Did you backprobe the pin on the bcm to verify that the bcm is getting the signal from the switch, and that pin going to the relay isn't switching?
And perhaps check ALL the bcm fuses, that they all are good.  The bcm gets multiple power and ground connections, and if they don't all get power/ground properly, the bcm may not operate properly.
I would suggest getting a knockoff tech ii, both to see what the bcm is doing (it can show what signal the bcm is getting from the switch, and can directly command bcm to turn the fog lights on/off.  And depending on how computerized the hvac hu is, it can get codes from the hu, and help with diagnosing what it's up to.
And a subscription to the full-service manual for your truck also would help, it'll have diagnostic procedures for figuring out both problems.
I will have to eat shi* on the BCM deal.  I determined the dash switch had issues and was not pulling logic power down to ground good enough.  I reworked the switch and the fog issue is considered 'fixed', or at least the dash switch was the confirmed issue.  Have had a LOT of switch problems in this truck.  I have had to tear down every door switch in the truck.
Anyway, this now leaves the HVAC.  I have never seen a knock off TechII, but would you have a link?  I would certainly be very open to just owning one.  I do have contacts to borrow a real techII, but always a hassle.  Obviously most OBD goodies don't work outside of emissions related stuff.
Here are some:
https://www.chinacardiags.com/wholesale/gm-tech2-gm-diagnostic-scannerworks-for-gm-saab-opel-suzuki-isuzu-holden-1011.html
They are also on ebay & amazon.
I can't recommend any particular setup, as I'm still researching it myself (I expect to soon get a second truck that would also work with a tech ii, and then I would get it, I currently use Autogenuity w gm enhancement which covers most diagnostic&testing stuff, just no programming).
    • 87 down as low as $5.14 here... winning!
    • Progress... sort of.   Intake is disassembled, spider is out, fuel lines removed. Used a torch on the stripped screw with the lower intake off, much easier when I've got the intake sitting on my workbench, I made it talk. Walked right out with a pair of vice grips once it was nice and toasty hot.   New parts are piling up on my service cart waiting to be installed. Distributor, temperature sensor, new gaskets, fuel line kit, themostat, water neck.   My new pickle is I don't want to spend $600 on a replacement spider. I'm not sure IT is bad. I'm probably splitting hairs. Or it's $300 to send mine away and another 3 weeks of the truck just sitting. I have half a mind to assemble everything with the old spider to see if I can get away with just replacing the fuel pressure regulator to be safe. The obvious issue was the gushing high pressure fuel line which will be replaced. Getting to the spider really isn't that hard, and now I know what I'm doing , swapping it would be a breeze should it absolutely need one. Stupid, or smart?   The part that gives me pause is replacing the distributor. Well, it's already out. And I didn't mark it, whoopsie! Engine was at TDC when I removed it, I know that, so upon correct reinstall the metal tip on the rotor should point to the TDC mark on the distributor because that's where it was pointing on the old distributor. Worst case I'm a tooth off and have to re-stab it.   But then, what? I assume the truck will start. It doesn't appear the timing can be set. Here's the problem: These distributors can't be rotated but a degree or two, by design. What I read is Cam ****** needs to be -2 to +2 degrees, ideally at 0 (and checked/set above 1000 rpm). There should be enough wiggle to get that properly set, but checking the reported value is another potential issue. My Actron 9185 scanner says it supports enhanced GM PIDs and Cam ****** is one of them but it's unclear that I'll be able to correctly see it over OBD 1.5. I can see why people end up junking these things with life left in them. They're an absolute nightmare with tweener-year diagnostics/electronics and unobtanium parts.   Fingers crossed it starts and idles nicely. There can be hope, right? I'ma buy a lottery ticket the same day just in case.   Next steps..DO IT. I have not installed an intake before so I've been reading and watching a lot. Some say NO RTV except on china walls, some say DO RTV on water ports but not fuel/air intake. 1/4 or 3/8 bead on China walls? I think my strategy will be, obviously, RTV china walls with overlap on the gasket corners. Chapstick-style RTV the water ports. Leave intake ports dry. The only set of intake gaskets I could find locally are Edelbrock performance gaskets (uh...for an asthmatic 190hp V6? LOL) so we'll see how they do.   #NoToolLeftBehind. It took an hour, but my recovery mission for my deep 10mm socket was successful. It had rolled down the bellhousing and wedged itself between what I think are the fuel lines? I couldn't see it at all, but with a junk antenna I had laying around, I blindly went poking/sweeping for it, heard it clink, raised the truck, and caught a sliver glimpse of chrome with a flashlight way up there in Narnia. I had pushed it farther along the lines holding it captive, but within access of severely improvised tools, poking and cursing at it to finally knock it free to where I could get a fingertip on it to bring it home.    Not much to see.
    • Thats crazy considering im right next door (Indiana)
    • For a limited time, retail and commercial accounts receive an AMSOIL Vinyl Tool Tray with their order of $500 or more when they use code TRAY726 at checkout. The promotion runs through July 21, 2026.   Order at https://syntheticadvantage.com   Want to use AMSOIL in your business or sell at your store, apply here.  https://www.amsoil.com/business-opportunities/?zo=521390
