It looks possible to put a block between the axle and the plate under the mono leaf. Just need to size the u bolts. They seam to be 9/16" but it's measuring 3 3/8" between which is not a common width.
IMG_0216.HEICIMG_0216.HEIC
IMG_0216.thumb.jpg.bf2270cce45c723f55a14ef0834355e6.jpgIMG_0217.thumb.jpg.849faa47daeeeb30605410bcd06228cc.jpg
Edited by latreille89
Wonder if it’s a taper block or if I could just use the one that comes with a 6 inch lift kit? Anyone try it on a mono leaf?
  • 6 months later...
Has anyone found a solution to this yet?
Would like to go with a block.
Also will the TB/AT4 leaf springs bolt right up to the shackles on these?
I'm just going to drop these right here because I think they might help somebody.  Find them about 2 weeks ago while playing on ReadyLift's website.  I remembered them while reading this thread.
https://www.readylift.com/rear-u-bolts-for-monoleaf-applications-only-gm-silverado-sierra-1500-2019-2023.html
https://www.readylift.com/mono-leaf-rear-block-kit-6-lift-kit-gm-silverado-sierra-1500-2019-2023.html
You can keep your leafs. There’s a few kits now. Rough country also sells rounded ubolts at 3.25” wide which fit perfect. There’s a 1/4” plate under the leaf that’s 3” wide to give the leafs full bearing for the axle. Keep that. Put a block under it. RC nylon blocks seem to fit well. Yes I know you shouldn’t stack blocks but I’m not considering that plate a block. It has lips and groves to hold it in place. Without it, the blocks are only 2.5” wide which I’m sure isn’t good for the leaf. Do at your own risk.
    DM22
    DM22
  • Who's Online   6 Members, 1 Anonymous, 2,240 Guests (See full list)
