Hi guys. I own a 2019 Sierra AT4. My dilemma is the optional factory 'assist steps' (#84630474) I've seen on AT4's later than mine...mostly on 21's and above. Pretty sure I've seen them on a 2020 AT4 as well. Will they fit a '19? Everywhere I ask people tell me they're "pretty sure" they'll fit but I'd like to know for certain as most places offer no refund, so I'd be stuck with them. Some fitment charts say they won't fit. My guess is that they do, but weren't even an option until 2020 and kicking me a "won't fit" because of this. Much appreciation in advance.
Edited by wrexx
misspell
I don't either. They are pretty sharp looking IMO I'm surprised nobody has tried this before. $1k  is hard to drop on a chance (however slight) they won't work. Thanks for the reply.
I have these on my Silverado and people ask me all the time where i got them from. I bought mine at a Chevy dealer and got the ones for the extended cab but I have a double cab so they exchanged them with no problems or questions asked. Buy them from a dealer and not mail order and you should have no problems if they don't fit.
Same generation, no changes to the underside, should bolt right up.
My wife and I like wide steps, we're getting old!
This guy got them for his 2020 which is also listed as not compatible.
No idea why they say not compatible unless it's because GM didn't bother to go back and bolt them on to older trucks. The cabs are the same for the T1's and all the threaded inserts are already in the cab floor. You just have to pop the plastic plugs off the ones you need to use and thread the bolts into them to bolt the brackets up. I wanted a set of those steps until I saw the price! I went with a $260 set that tuck up high but have drop down bars to protect the body. They're aluminum so they're light as well.
Thanks for the info guys. I think the collective thought in the thread is that there's no reason why they shouldn't. I will most likely get a set but be on the lookout to score some a little cheaper.
The only thing I thought of is if your truck is a diesel. I know the DEF tank is on the driver side and I saw something about different brackets for the diesel.
I was at the dealership this morning and there was one at4 on the lot with those wide steps and they look better than I thought on the truck not bad at al all, I might keep mine after all
Ok so if anyone reads this my question has been answered. They do fit. I have a pair on my 2019 Sierra AT4. Bolted up no problem.
I removed the wide style on my '20 AT4 and installed the factory "high clearance" steps posted above with no issue.  I picked them up for $300 locally removed from a brand new at4.
be the guinea pig man, 98%+ they will work and you'll sell em real easy if not as there's nothing better, I've now seen mine in snow, mud, combined frozen etc. and they are awesome, the grippy stuff and how solid these are, combined with their fitment to body and clearance makes them in a different league and worth the money imo, they happen to look incredible too, they aren't lightweight, I'd have to guess 25-30 lbs a side, quality stuff, best side step I've seen outside of some custom aluminum extruded grip strut type steps I've seen on oilfield trucks, anything works if there's no snow/mud etc. but most are slippery hazards in that stuff, these can play for real work, and don't forget they are there when jumping out, that grip stuff can give good road rash to the back of your calf, it's a self trainer and you learn the lesson just after you put them on 😉
also, there's multiple locations on the board for the 3 brackets to move to, to align with different trucks frame points etc., so they designed them to fit several trucks
Edited by 4banger
Frame points? Do these actually bolt to the frame and not the underside of the cab?
    B07
    B07
  • Who's Online   2 Members, 0 Anonymous, 877 Guests (See full list)
    • Missing pieces of the Assembly   Detergency vs Solvency   Not the same thing. Detergency is the mechanism that surrounds solid particulates preventing amalgamation. Usually accompanied by a Dispersant whose job it is to keep those encapsulated particles in Suspension. Solvency keeps things that can be dissolved in solution.    Salt is a solid that can be dissolved. Pepper is a solid that cannot be dissolved. A detergent/dispersant is effective on pepper but a solvent is more effective on salt. As long as the solids remain in either state, dissolved or dispersed then they can be be removed with the oil upon change.    How many wranglers does it take to herd cats? Depends on how many cats your herding. How much sponge does it take to soak up water? How much water is there to soak up? Point is most oil blends start with some herding ability and next to zero sponge and recently even fewer wranglers are being sent to do the same job.    So you start with a dozen cowboys and zero cows but at the drive progresses you pick up cows along the way, but not cowboys. At some point you have more cows that the wranglers can handle and some leave the herd. Deposits. And the API has an acceptable number of cows they are willing to let loose. In the ideal world zero is the right number for he rancher but to the butcher....a few lost is fine. This cow is beat to death. Let's move on....   Solvency isn't something oils on the Walmart shelf care about AT ALL. Problem is, you motor does. Fuels driven varnish sticks rings and only a solvent can keep them in check. The bet is that the solids driven portion that plug the expander rings and the oil drain backs and VVT screens and AFM screens will be an issue long before varnish is. Not that it wont be but if they market well enough the consumer can be kept ignorant enough to either believe it is "normal" (A quart in 1 or 2K is normal) OR is kept at bay longer than the first owner is likely to hang on to the unit. Solvency cost money.    Now the OEM's have John Q. Public buffaloed into the belief that the number cows accumulated along the trail is a known and predictable CONSTANT. It isn't. Nor is the rate at which they crossed paths with them. Only the number of wrangles is constant. Or was. Each new generation of oil sees fewer and fewer of them.    So what happens when the number of cowboys is lower (lower TBN) with each seasons trail but the trial is longer (OCI) and the number of cows along that trail continues increase? (Conditions that promote deposits).    For awhile the blenders were on to something. Better bases are harder to degrade (fewer cows) but that was overtaken by a longer trail (OCI) and improved breeding (More cows) while continuing to reduce the cowboy staffing levels (TBN/Aniline #).    Marketing has been successful. We've fired most of the staff, cows breed line bunnies, the trail is ten times longer and we've convinced the boss his ranch is in better shape that it ever was.    That kids is just the cleaning side. The side few pay attention to.
    • Looking for this part for my truck. They don't sell just that one piece and to get it you have to pay over $100 even used for the whole air tube. The piece the hose clamp snaps into that is held on by the screw and nut. If anyone has access to one please let me know.
