Does anyone know if/how it’s possible to retrofit bigger rotors/calipers on 2014-2019 Silverado/Sierra?
Maybe from the 2020-2022?
Otherwise, are the rotors and calipers on the 2014-2019 Silverado/Sierra the same on both the 1500 and 2500? If bigger, would they fit?
(btw on my 2001 Yukon, I easily bolted on bigger front rotors and calipers from a 2007-2013 Tahoe/Yukon/Suburban, and it made a HUGE difference, especially with bigger tires).
Okay, after doing some digging… I see that the 1500 has 330mm/345mm (front/rear) rotors, while the 2500HD used 350mm/360mm (front/rear) rotors.
Just need to figure out if the bolt pattern is the same, the caliper size and mounting bracket specs.
There are a few options (listing from $ to $$$):
1. 2019+ rotors and calipers. (Can run 17” wheels)
2. 2019+ Tahoe PPV. They are basically the Brembo’s 6 pistons kit but without the logos and paint and it’s a lot cheaper. (Will need 20” wheels or bigger)
3. C6 ZR1 calipers and big 16.1” rotors. (Will need 20” wheels or bigger).
4. Wilwood or Brembo BBK kit.
Im running the C6 ZR1 setup currently and it’s awesome.
On 11/8/2022 at 7:02 PM, CajunFries said:
Wheels are 20x9.5.
@CajunFries What was involved in this conversion, mainly regarding the caliper?  Does the ZR1 caliper bolt right on?  Obviously need the corresponding rotor & pad size, but not sure what else is needed.
Thanks in advance.
Where did you pick up the calipers at?
