I have a 2019 GMC sierra SLT 5.3.
After installing a k/n 63 series cold air intake and a j&l 3.0 catch can, the truck is running lean. I capped the fitting on the tube and put a breather on the passenger pcv . In other words, I deleted the hose from the passenger side valve cover going to the intake tube.
Check engine light came on, so I used a code reader and it shows the truck is running lean.
Do anyone have an idea what is causing this code?
Any thoughts would be appreciated!
Thanks
The dealer claims that you need to reflash your MAF (mass air flow sensor) to use a CAI.  I bought the GM CAI that came with the flash (so they said) and have no issues but many folks with newer vehicles have tossed codes after a CAI install.  It is not even close to being as nice as the competitors CIA's but it was part of the deal at the time.   Your truck may "learn" as you drive it but they claim no power increase without a flash.  I highly doubt that the K&N system is causing a lean condition, your A/F mixture may be on the edge and just upsetting the computer.  Why did you cap your passenger side vent?  I too am using the JLT that was a plug and play for the 6.2L and did not cap any breathers.
I put a breather on the passenger side and capped the fitting on the tube. I did this because I didn't want the intake tube to suck any fumes. I have done the same process on other vehicles with no issues. I did it on my 2021 camaro ss and no check engine light came on.
I’ve got the Corsa CAI which is a Volant, the Corsa catch can, and Corsa exhaust and have had no check engine lights come on. Just unhooked the battery during install and the truck relearned the new CAI. My truck is a 2021 with the 6.2.
Edited by Blue5.3l
Got it!
Well after installing the CAI and catch can, no lights came on until 2 days of running my truck. I disconnected the negative on battery and it took about 40 miles before the light came back on.
I have read that in some cases the vehicle needs to run from 70 to 100 miles so that the computer can relearn. I have not driven the truck 70 at one time.🤔
Maybe that's what I need to do🤔
    TopBo
    TopBo
  • Who's Online   4 Members, 0 Anonymous, 965 Guests (See full list)
    • First off, I'm not trying to just get easy advice/fixes for the issues I've noticed so far.  I'll be combing through the site via searches and such, and if past experiences are any indication, should find what I need.  For the sake of conversation, though, I figured I'd post the handful of things I've noticed in the 12 hours since buying my 2010 SLE CCSB.     Indicator lights: Airbag and TPMS.  The tire pressures aren't reading for any of the wheels, so I'm pretty certain the sensors were either removed, are damaged, or are otherwise inoperable.  I used to mount and balance tires 25 years ago but am pretty much ignorant when it comes to TPMS.  My 2006 didn't have the sensors and this might be the fourth vehicle I've owned that does.     Radio: Rear speakers aren't working.  I removed the driver's side rear door panel and checked the speaker and wiring.  I also removed the sill and b-pillar covers to check the wiring.  A few minutes of Google Fu showed that this is potentially a head unit issue.    Switches: Power mirrors don't turn left/right.  I ordered replacement driver's door switches that should arrive tomorrow.  The windows and locks work but it was only about $20 for all of them.  The driver's side rear window switch lets the window down but won't put it back up.  I think the passenger rear doesn't work at all.  In the coming days/weeks, I'll break out my multimeter to check all of that.   Unknown wiring harness: There's a box attached to the front driver's side of the engine compartment, right where the second battery shelf is located.  There are three plugs, one of which looks like it fits a standard headlight-style bulb (9007 or similar).  It doesn't look like it's plugged into anything.  I'll do some digging and if I don't see anything elsewhere on the site, post some pictures here.   Unknown plugs on brake booster: There are at least two female plugs on the brake booster that aren't being used.  I think it might be a replacement/aftermarket, so maybe those are used for a different application, as there don't seem to be any unplugged harnesses and no indicator lights are on.   Little squeaks when turning: Sounds almost like a bushing around the bed of the truck.  I'll have to pay close attention as I get more familiar with the truck.   Clunk on acceleration: possibly the infamous drivetrain clunk.  My 2006 had it and I'm just not familiar enough with this truck yet to fully grasp what it is.   Anyway, my apologies for the vague and all over the place post.  This truck is new to me, and it's been four years since I drove my 2006.  With 200k miles, I know I'll need to learn this truck quickly to avoid having any major issues, despite being confident it's got much more life to it.  My 2006 had nearly 320k on it when I parked it (nearly 300k of which I put on the truck), and it was still drivable then, though I suspected the head gasket might have blown.  I'd hoped to have that truck back by now, but it's gone forever, as I detailed in my reintroduction thread.
