3 hours ago, GETGONE said:
I tried several runs in 2wd and played with air pressure in the tires. It just spun the tires and was even worse because the G80 didn't kick in for a second so you had one wheel spin before the other caught then both spun. I didn't run any in 4 high, only 4 auto. I don't know if the transfer case actually disengaged after launch or not.
Try 4wd and mash the pedal, then switch to 2wd asap.  It’s actually hard to reach and press the button.
Where in Michigan?  What track do you go to?
This is from the draggy, the .48 run and the history of runs.
The number 3 and number 2 runs were back to back. #3 in sport mode and #2 in tow/haul mode.
Edited by SILVER SLED
I'd rather not blow up the system trying to switch while under full throttle!
I'm just East of Grand Rapids. I run at US 131 Motorsports Park in Martin, MI.
  • Haha 1
I forgot I did replace the muffler with a $50 aftermarket straight through bullet muffler.  Not saying it helped any, just forgot to mention it in the original post.  Sorry.
Ain't gonna happen.
On 11/24/2022 at 8:40 AM, SILVER SLED said:
I’m sure there is some power loss, but the advantage of the limitless traction in 4wd and just mashing the gas pedal from a stop, seems to out weighs the loss of power.
If you mash the gas pedal in 2wd you would sit there and spin the tires.  So to get a good launch in two wheel drive you would have to cut the power on launch (feather the gas pedal) a lot more than is lost in being in 4wd.  So in this stock truck launching in 4wd would win the race.  I do quickly shift out of 4wd after moving.   Now a modded 2wd truck that has less weight in front, and some suspension work done, with slicks and skinnies would start to overcome the 4wd advantage.
Interesting that yours will shift from 4 to 2wd while under power,  I have tried this a dozen or more times and mine will not until I let off the throttle and even then it takes at least 8 to 10 seconds to do it so by the time you launch the truck and reach down and push the button the race is over.  Not doubting your word, just find it interesting
That seems strange.  What engine/transmission/transfer case do you have? I have the two speed transfer case.
I have the 8 speed transmission,  maybe that's the difference
I don’t know.  I had an 18 6.2 8 speed and a 15 5.3 6 speed and they would also shift out of 4wd hi to 2wd at full throttle.
I wish I had run my 2020 6.2 Max tow 4WD on the strip.  I had the GM performance intake and exhaust.  The truck had 3.42 gears.
I have owned a lot of different pickups, and have had three tuned 2500 Duramaxes.  I now have a 2022 2500 HD with the l5p Duramax.  I think my 6.2 would beat all the DMaxes handily when they were stock.
    • The truck is a 1995 Chevrolet S10 Blazer, 4.3 VIN "W" engine. :cracks knuckles:   On a whim - because I needed a headache - this truck was for sale so I stopped to take a look. Doesn't run. Well, it does, but barely. Long crank, choppy idle, bad misfire(s), it REEKS of fuel. I can DO this..I'm thinking. Diamond in the rough. One owner until last year. A young guy is selling it, he bought it 6 months ago. It stranded him more than once, he's got a newborn. It was in the shop 10 days ago and he "thinks" they said it needs a new fuel injection system. He can't put any more money into it, needs it gone. I was thinking of upgrading my Macbook, which is a total want, not a need. For less than the price of a new laptop I can have fun for months tinkering on this truck and enjoying it. I'm taking this truck home. The guy was beyond thrilled, his wife was there, she thanked me profusely, I could tell they were hurting. They seemed like good people in a bind.   Some parts, a wash, maybe a set of tires, and I can have a few months of fun and then turn it for beer money (or the next project).   Sure enough, there's a work order from a shop last week in the INCHES of paperwork on this truck dating back to when the first owner bought it. They put a new distributor in it, fuel injection work describes basically opening the plenum and putting it back together. He said he couldn't afford any more work so he had them button it up and that's when he put it up for sale.   I'm not well versed in 4.3. I did discover 1995 uses the 1992-1995 SCPI "Spider" injector which is riddled with issues from splitting lines, clogged or cracked poppet valves and plastic spider legs that crumble over time. Cool. I'll just order me a ne---. Oh, the auto parts store doesn't have it? Rock Auto doesn't have it. eBay? $$$$$$ for used. These are UNAVAILABLE period end of story unless you know "a guy" who's still got one in a box somewhere.   Can't upgrade to the '96-'04 injector, it's a different plenum, wiring/pinout and sensor config.   There are a few kinda "know a guy" -guy rebuild services for these injectors out there for about $350. Okay, Okay... I'd like to know if anyone has used them? Anyone got a lead on these crappy 92-95 spiders?   I also don't want to send MY spider to Narnia and back without knowing if that's truly the problem. I guess I'll need to pull apart the plenum and do some digging.   I was also thrown for a loop. This 1995 model year truck has an OBD-II connector. The interface is decidedly not OBD-II. I can read and reset trouble codes and view live data, but there's not a lot of data. Like misfire count and on what cylinder, that's not there. It's OBD-1.5.   Nothing is ever easy. Now it makes sense why this guy wanted to disappear this thing for cheap. I'm guessing the shop told him the injector is toast, the part is unobtainable and they're not going to sort sending the thing to a rando offering rebuild service on craigslist, and the kid likely can't be without a working car for 3 weeks even if they'd facilitate that.   Experience with these early SCPI's? Stories? Things to check? Sympathy? (..Nah...)   This can sit until I sort it. But I haven't had a problem with a vehicle I couldn't easily solve in a long time.
    • I have four that read by the dash 8 to 10% better than miles/pump calculations and I have one that is spot on.
    • The average lifespan of automobiles on the road is increasing - here's why
    • Typically it is the Torque Converter, I have a 2.7L Trail Boss and between 25-65 MPH at 1300-1500 rpms under light throttle it has a shudder which I almost consider and bobble or a gargle sound. They replaced my TC but it did not help any, others say it has fixed their issues. It has been back twice now with no fix after.
