I recently bought a 2020 1500 RST with the 3.0 Duramax. When I try to use the trailering app, it stays stuck on the light test screen. It won’t do anything else. I’ve reset everything to factory default and erased all user settings and it still doesn’t work. Am I missing something? Can this even be fixed? So far a little over a month of ownership and already had the rear window leak that had it at the dealership for a week and now this… I’m really starting to wonder how big of a mistake it was buying a GM.
Jarhead, as a Marine veteran myself I know that you are really happy with your purchase because you're complaining. After all, a Marine isn't happy unless they are complaining. Secondly, like all things when there's a technical glitch, call the Chair Force. Seriously though, turn off truck, open door, close door, restart truck, access trailer app.  Did that fix it?
Negative. I’ve tried it everytime I’ve turned the truck off and back on. Always stuck on the light test screen. The light test does function as it’s supposed to on my trailer. But that’s it. And yes, if Marines aren’t bitching then you have to worry 😂
Try running and turning off the light test with the myChevrolet app on phone, no cost for that app. That's how I run the light test from behind travel trailer. My problem is that the Trailering app will not always start, I get a blank screen a lot and have to use the turn off, open/close door, wait 10 mins, try again routine. Trailering app is great when working.
Edited by EddDe
I’ve tried using the app as well. Can run the light test from my phone and it works fine. But is still the only thing that comes up on the screen in the cab. Haven’t actually towed with it yet, but it does seem like the trailer brake controller and gain functions work properly. The trailering app does look nice from the videos I’ve watched. Wish this thing would work!
This is certainly not what we like to hear, 03Jarhead.  Please know, customer satisfaction is extremely important to us. Our team would be more than happy to take a closer look into the concerns with your 2020 Silverado 1500. To do so, please send an email to [email protected] with ATTN: 03Jarhead/GM Trucks in the subject line.
Please include your contact information, VIN, a brief description of your concern, and the name of your preferred dealership. We look forward to hearing from you. To learn more about GM’s Privacy Policy, please visit https://www.gm.com/privacy-statement.html. The information you provide may be monitored and recorded and is subject to the GM Privacy Statement.
Privacy Statement | General Motors
Your privacy is important to General Motors. This Privacy Statement addresses the personal information GM collects and how GM handles that personal information.
www.gm.com
    • Long Term Cold Cycle Limited Testing   Back to the 1990's and XOM's million mile test. Since then there have been others and there will be more. Schaeffer's, AMSOIL to name two. Of these Schaeffer's is the stand alone which I will explain in a bit later.    http://papers.sae.org/600190/:   http://papers.sae.org/850215/:   Up to 75% of  engine wear occurs on cold starts. These two links (above) provide the technical reasons for engine wear. In a nut shell, and by a large margin, cylinder wear is what takes out most motors and even with a pre-oiling system that part of the engine is dry enough on cold starts and cold warm up to pierce Stribeck.   So when you put a motor, or a car, on a dyno for a million miles stopping only for oil changes, (yes fuel is uninterrupted) or break down maintenance, you are depriving the test of the most important part of it's wear cycle. Yes a million is then a pretty easy walk even for a mineral oil under those conditions.    How about cleanliness during the long test cycles? Same thing. Varnishes that stick rings and insulate parts are laid down by repetitive 'heat cycles'. It's the cool down the precipitates the varnishes. These long runs also hinder acidic attack caused by cold start richness and less than optimal cold start ring sealing. They hinder water formation and enhance breathing of the crankcase; the petri dish of acid formation, the first step in sludge formation, amalgamation and precipitation. These motors are also monitored and controlled for water and oil temperatures to within the "normal operating range".      https://www.swri.org/sites/default/files/sequence-iiih-test.pdf Note the test sequence in some boutique oils literature for testing, API IIIH, is not the standard used for the ILSAC G7 testing. Does that mean it is irrelevant? No, not as used. As used as a 'visual guide' it makes it's point. The G7 weighted piston deposit minimum is lower.      Back to Schaeffer's. That was a cyclical test of an engine in fleet service and not a dyno mule and if you saw the video it was not mirror clean but wear was low.    There are oils like BioSyn and other 'Renewable" source oils that taught cleanliness and have proven themselves in fleet testing. Havoline an other example.    The newest ILSAC G-7 test prioritize cleanliness, LSPI mitigation and fuel economy OVER WEAR. In comparison Porsche C30 Specification Verses ILSAC G-7 Specification below:      Some will balk that this graph isn't apples to apples and I will challenge that in that this graph represent the SPECIFICATION and not the any One Oil Performance.   It is absolutely possible to minimize wear, maximize cleanliness and mitigate LSPI etc., It just isn't cheap and currently I see none that are not walking toward profit over performance.
    • It has happened to me a few times. I carry a jumpstart-tire inflator with me.
