I've been pulling my hair out trying to figure this out. My '22 6.2L has a very loud but very specific whining sound.
What I know about the sound so far:
  • Only occurs at 1600-1900RPM
  • The sound cannot be heard when outside the above RPM range
  • 100% dependent on engine speed
  • 0% dependent on wheel speed
  • Higher throttle angle makes the sound louder but the pitch remains the same
  • The sound does not occur in Park
  • The sound does not occur at speed, within the RPM range above, but with the transmission in neutral
  • 4WD mode has no effect on the sound
The sound itself is what I would expect to hear with a bad alternator or a worn ring/pinion. I've seen the bulletins on the 10L80/10R80 and I do understand that some whining noise is expected but my specific example is loud enough to overpower the radio, road noise, and Max Defrost with the windows up. It's slowly driving me insane. Enough so that I've started thinking about looking for something else.
My dealer said it's a normal sound for the 6.2L but unfortunately I can't test that theory because 6.2L trucks are impossible to find on the lot without a name attached to them. I'm hoping someone here can chime in with their experience.
This is certainly not what we like to hear, Anthony Bessel.  Please know, customer satisfaction is extremely important to us. Our team would be more than happy to take a closer look into the concerns with your truck. To do so, please send an email to [email protected] with ATTN: Anthony Bessel/GM Trucks in the subject line.
Please include your contact information, VIN, a brief description of your concern, and the name of your preferred dealership. We look forward to hearing from you. To learn more about GM’s Privacy Policy, please visit https://www.gm.com/privacy-statement.html. The information you provide may be monitored and recorded and is subject to the GM Privacy Statement.
Privacy Statement | General Motors
Your privacy is important to General Motors. This Privacy Statement addresses the personal information GM collects and how GM handles that personal information.
www.gm.com
I found a Youtube video that demonstrates the sound. The link should take you to the 7:10 mark. As he pulls out you can see the tach. As the needle sweeps past 1500 to 2000 you can hear precisely what I'm talking about:
The difference is he only briefly enters that RPM range but for my style of driving I end up there often.
Does anyone else have this sound in their truck? I understand the 10L80 is going to exhibit some whining sound due to the nature of the design but in my case, the sound can overpower the defroster, radio, and road noise. I'm trying to understand if my case is normal or if there's something that needs looking at.
i can't hear anything over his yapping in the video.  What exact second do you hear it?
I have something coming in too.  def not a belt or from the front of the truck.
seems to be behind me (rear drivers side).  high-pitched wine-like sound, but it's not rpm fluctuating.  it's either making it or it's not and it seems to be TPS controlled/activated.
i can only reproduce it when i'm driving slow (eg, with my wife and kids in the truck).  when i'm romping around solo, i never hear it because i'm in the throttle a lot heavier.
It's really 5% throttle, in the 20-50 mph range (observed)
same pitch regardless of speed or rpm (which tells me it might not be gear or diff wine at all).
When i park the truck i hear a similar high pitched noise for 20 seconds after turning it off.   I assume this is the fuel pump primer or something still running, but it's not the same sound.
I dont notice that specific whine in my 2022 Trailboss 6.2.  I do notice that it is not a smooth quiet idle compared to the multiple 5.3 litres I've had.  I do like the engine though.  But seems a little noisy.  The issue that is driving me crazy.  I am having a couple of strange issues.  I hear a prominent whine when dow shifting into lower gears and when down shifting it hunts for gears and have had it lurch and buck really bad. Especially if just driving normal or slowly.  Also happens if I have to stop quickly in traffic or if turning into another road and starting to accelerate etc.  It did it so bad the other day.  I thought someone hit me in traffic.  Is there a programming change for this.  Thinking torque converter to transmission issue.  The transmission to me got hotter than normal cruising in a car show this past summer.  It was like 95 degrees and high humidity.  Tranmission got to like 215 and was not towing.  Truck just hit 17,000 miles as time of this post.  Had 14k on it when transmission was a little warm.
Edited by joshpen
Stock air intake?  Check that all the clamps for all the air intake tubes/filter are tight.  I had a whine on my old Silverado that turned out to be from my new K&N FIPK.  I have a AFE momentum CAI and filter on my 6.2 but I don't get any noise.
    • "Increase"?   You want to "increase" your turning radius?     What is your truck?  What kind of cab and bed do you have currently?  Is it stock?  Modified?  Lifted?
    • OP's quote is parts and labor.  Not just parts.     The # you found isn't the right one.  But besides that, the right # is the same price within a couple bucks.  $5802.01.    Now, factor in labor and fluids.  Book time is 17.1 hours for a Colorado 8 speed.  At $200/hr for a dealer average rate, its $3420 just in labor.  We are already at $9222.  Fluid and other necessary items, there's your $400-500 more.      Also.  Your "discounted" transmission.  Which is 99% likely quoted off of GM Parts Direct as that's the MSRP I found on their site.    You failed to note the $597 in shipping charges.  So we are right back almost to MSRP.  $5794.  Oh.  AND, you better have the $4000 for the core charge which you'd have to pay and get refunded, AND you gotta pay to SHIP THE CORE BACK.    So now you'd have paid MORE to buy that one online yourself, even after you get your core refunded.
    • I would like to know if I can increase my 2025 Silverado 2500 HD
    • Length/amount of data capture will be important to consider, sifting through 5 minutes of a data log can be enormous when it is stored in milliseconds. Being able to find the 'event' let alone decipher it.   Presumably the driver would notice something and hit a button to capture the 'window' of data. That window has to be large enough for the operator to recognize the event and react accordingly.    The data has to be able to be retrieved easily.   The data has to be able to be understood. Which is the biggest challenge, dealer techs won't even know what most of it is and would likely not even look at it if an owner brought it to them. Meaning the owner, the least educated/qualified, trying to understand it.    How will the data be presented? Could specific PIDs be selected and a timelapse graph be watched? How will a specific value be noted as abnormal? Additionally, a good data logger would be able to 'learn' normal values for a specific vehicle and flag abnormalities automatically. It could in theory watch parameters degrade over time and suggest maintenance as needed. (If the MAF reading begins tapering off for a given set of other readings - MAP, throttle position, Ambient, etc.. a flag to check air filter.) With the amount of data available, a device (really the vehicle rather than an additional accessory) should be able to do more than issue a DTC. It should be able to run the full diagnostic suite automatically and present a solution rather than a code. (It's not the 90's anymore). The technology is available for the vehicle to not just say "P0087", it should know low fuel pressure, check other PIDs to narrow down the problem itself, and determine if it is a lift pump, high pressure pump, regulator, leak in the fuel line, clogged filter, etc. Even if it can't narrow it down, it should be able to guide the user to the likely problems.   This would be a major problem for dealer service departments, which are the manufacturers customers it is in their collective best interest to NOT have this available to the consumer.   Further, if the owner is going to be the primary consumer of the data, it's got to be at a consumer price point vs. dealer only specialty tool price.   This group is more 'involved' in their vehicle than general public/consumer and will have knowledge, experience, needs and desires that are quite different from the market at large.
    • I put the prof up. If you read what I posted. You can see that housing, cars and income are in line with the era we were talking about. It’s harder in some places easier in others. Let’s agree to disagree and put this back on track, OK? We both are pretty stubborn and hard headed. But I bring receipts. If you wish I will not respond to you in the future.
