1 hour ago, NaturallyAspirated said:
Who’s got construction photos?
Not me but I love that truck in the front!!  Looks like mine lol
I lied, actually I just remembered I have a pic of a house my son is having built in Byron, GA.  It's coming along nicely.  3/2, 1400sq/ft, 2 car garage.  All for a 25 year old single male...lol....he's doing amazing for himself thank the lord!!  He followed in my footsteps for a career and is now a commercial aircraft mechanic...actually a lead mechanic for Embraer in Warner Robbins, GA.  I'm a proud dad for sure!!
Edited by Jettech1
  • Like 4
This was 19/20 before the refresh.
Edited by gemarsh
Add pics
  • 9 months later...
