Evening Gents
Seeking advice, guidance and knowledge. I currently have installed the Rough County 6” kit on my 2021 chevy 1500 trail boss. I have the extended struts in the front and blocks in the rear. I’m looking for a tad bit more height without breaking the bank. I have been looking at various 1.5” and 2” add-a-leafs for the 19-22 rados. I’m curious if this is a good route to go for a little more lift in the rear that is cost effective. If this is okay to do will I need longer u-bolts or as most aal kits state you would not need longer u-bolt if applying to factory stock truck. I plan on doing a 2” lower strut spacer in the front to level it and gain around 8” overall lift. Seen guys do similar combination on fords and Tacoma’s but haven’t heard anyone run that kinda set up on the new silverados. Any advice or incites would be much appreciated.
Thanks in advance
It is recommended NOT  to reuse u-bolts.
Not being familiar with the lift - but it might already include some amount of height gain through spacing in the strut assembly. Adding an additional spacer might over extend suspension geometry angles either ball joints or CV's.
Cognito has a Deaver pack add on that can gain 1-3". The bonus is it makes your leaf spring a progressive rate (replaces the overload leaf) and better ride. Add a leaf usually makes for a more harsh experience unless under load. It's $500. Cheaper than new leafs but probably more reliable than a taller block or a stiffer add a leaf.
BDS' is also releasing a coilover conversion for the rear end under project Velocity this year. Lot of room for lift.
I appreciate y’all responding, I have already found several leafs I’m looking at. Biggest question I have is it okay to stack a aal on a 6” lift block? If any what concerns are there to go with it? I have all the drop brackets for all the lines and have plenty of slack for a 2” lift gain.
    Greg3160
    Greg3160
  • Who's Online   5 Members, 0 Anonymous, 501 Guests (See full list)
    • Late reply, but yes—it works on the SLT trim. Compatibility comes down to the plastic shroud shape behind your mirror, not the trim badge itself. On the SLT with auto-dimming, it uses a plug-and-play Y-harness off the mirror/rain sensor power, so no need to run wires down to the OBD port. If anyone's ever unsure about fitment, just drop a photo of your mirror housing and we can double-check it.   Appreciate the detailed feedback on the install! On the windshield glare—we actually took feedback like yours and developed a dedicated CPL (polarizer) filter to cut down dash reflections on sunny days. If you're still running the cam, shoot me a DM. I'd be happy to send a CPL filter over for you to test out—no charge.
    • There are no stickers in your glovebox?
    • Look at the numbers on the stickers in the door jam...
    • Yes, every time the developer updates his code, you must recompile. I will private message you with the latest because it changes pretty much with every version.
    • After I wrote that reply I went for a ride. 85 F out. So trans started at 85 F and it shifted the same as it did an hour latter at 168 F. I've never actually recorded the to cold to shift point but it is under 32 F before they start hanging on to a lower gear or leaving the converter unlocked. Both intended to heat fluid.    Yes, brake or bake. Absolutely.      Your welcome. True research ended decades ago. Field trials are still in play.    There is a thing called oxidation onset temperature. This is the heat related oxidation not the O2 exposure kind. For mineral oil that starts at 140 F. So what happens after 140 F? Each 20 F cuts fluid life in half! Does using a Full Synthetic improve that? Yes! By how much? Depends on the base oil type and a few other factors. But enough to notice. Some esters are even higher. There are even synergies between types the will raise it higher than any one component is alone.    Then there is "Hindered" oils. Antioxidant additives. Hindered Polyol Esters can sit at 500 F for years in a turbine.   When a blender brags his oil will 'take 500 F" in service he doesn't specify for how long. Water will dance on a 500 F hot plate for several seconds. @newdude put up a chart showing the relationship between fluid temperature and it's life in an automatic transmission. Here's a version of that chart for Group III based oils. These temperatures are those in the pan as observed as 'normal'. that is you drive as you do for as long as you do under what load you ask of it and whatever that temperature is this graph applies to. Flash temperatures of a few minutes isn't what his means.    Note that fluids held at a constant 240 F have a service life of only 20K miles. 220 F explains the factory exchange limit, eh? My equipment I keep under 180 F and I'm good if the cooler will hold it as low as 140 F. But that's me.
