Does anyone know the offset for the 20" 10 spoke aluminum wheels? I believe they are either a 20x9" or a 20x8.5". Can anyone validate? Anyone know the offset? On chevy's build side and accessory side of the web, they just state 20"
Edited by Mass2500HD
That's a good question.  Here's what I found on google... I hope this helps.  This actually educated me too because I thought it was 20x9.  I was wrong.  It's 20x8
This Factory OEM CHEVROLET rim comes equipped on a 2020 - 2022 CHEVROLET SILVERADO 2500 . This is a ALLOY wheel with a diameter of 20" width of 8 ". This CHEVROLET SILVERADO 2500 wheel has 8 lug holes and a bolt pattern of 8-180. The offset of this CHEVROLET SILVERADO 2500 rim is 47mm.
Edited by Jettech1
I liked those wheels when I first got my truck; thought they were different.  Now that I've had the truck for a year I'm already growing tired of them and want something that actually has a little bit of lip.  Going to stick it out until it's time to replace tires.
I actually love those wheels.  In all my years of owning vehicles, I've only had one that I put different wheels on and that was my beloved 71 Chevy Biscayne that I bought back in 1982.  The poor mans Impala back then lol...I put on some Cragar mags on a 4 door Chevy Biscayne.  But it looked great!!  No really it did...lol....
6 hours ago, Another JR said:
No, I do not like those wheels.
In 2020 the center portion of the wheel was black.  I didn't like that.  It was too contrasting with the aluminum in my opinion.  They went to gray either in 21 or 22.  Now I like them, actually love them.
Factory 17x7.5 Wheel Offset = +44 mm - Back Space = 5.98" Inches
Factory 18x8.0 Wheel Offset = +44 mm - Back Space = 6.20" Inches
Factory 20x8.5 Wheel Offset = +47 mm - Back Space = 6.60" Inches
Lug Pattern= 8 x 180 - Single Rear Wheel Trucks Only
I just wish they weren't so narrow.  If they were an inch or two wider and maybe had a lip on them, they'd be much better.  But as they are, they remind me of pizza cutters.  I'll probably keep them as I don't feel like messing with aftermarket wheels though.
Homewrecker, thanks for providing the specs that OP asked for.  Sorry I distracted from the original post.
4 minutes ago, Maninthesea said:
Wait.  There is a 17” option?   I thought 18’s were min. To fit over brakes.
17" is standard on 2500hd for two trims.  Steel on WT, aluminum on LT.
All 1 ton minimum is 18" because of the higher load rated tires to go with the higher GVWRs.
    B07
    B07
  • Who's Online   0 Members, 0 Anonymous, 774 Guests (See full list)
    • Missing pieces of the Assembly   Detergency vs Solvency   Not the same thing. Detergency is the mechanism that surrounds solid particulates preventing amalgamation. Usually accompanied by a Dispersant whose job it is to keep those encapsulated particles in Suspension. Solvency keeps things that can be dissolved in solution.    Salt is a solid that can be dissolved. Pepper is a solid that cannot be dissolved. A detergent/dispersant is effective on pepper but a solvent is more effective on salt. As long as the solids remain in either state, dissolved or dispersed then they can be be removed with the oil upon change.    How many wranglers does it take to herd cats? Depends on how many cats your herding. How much sponge does it take to soak up water? How much water is there to soak up? Point is most oil blends start with some herding ability and next to zero sponge and recently even fewer wranglers are being sent to do the same job.    So you start with a dozen cowboys and zero cows but at the drive progresses you pick up cows along the way, but not cowboys. At some point you have more cows that the wranglers can handle and some leave the herd. Deposits. And the API has an acceptable number of cows they are willing to let loose. In the ideal world zero is the right number for he rancher but to the butcher....a few lost is fine. This cow is beat to death. Let's move on....   Solvency isn't something oils on the Walmart shelf care about AT ALL. Problem is, you motor does. Fuels driven varnish sticks rings and only a solvent can keep them in check. The bet is that the solids driven portion that plug the expander rings and the oil drain backs and VVT screens and AFM screens will be an issue long before varnish is. Not that it wont be but if they market well enough the consumer can be kept ignorant enough to either believe it is "normal" (A quart in 1 or 2K is normal) OR is kept at bay longer than the first owner is likely to hang on to the unit. Solvency cost money.    Now the OEM's have John Q. Public buffaloed into the belief that the number cows accumulated along the trail is a known and predictable CONSTANT. It isn't. Nor is the rate at which they crossed paths with them. Only the number of wrangles is constant. Or was. Each new generation of oil sees fewer and fewer of them.    So what happens when the number of cowboys is lower (lower TBN) with each seasons trail but the trial is longer (OCI) and the number of cows along that trail continues increase? (Conditions that promote deposits).    For awhile the blenders were on to something. Better bases are harder to degrade (fewer cows) but that was overtaken by a longer trail (OCI) and improved breeding (More cows) while continuing to reduce the cowboy staffing levels (TBN/Aniline #).    Marketing has been successful. We've fired most of the staff, cows breed line bunnies, the trail is ten times longer and we've convinced the boss his ranch is in better shape that it ever was.    That kids is just the cleaning side. The side few pay attention to.
    • Looking for this part for my truck. They don't sell just that one piece and to get it you have to pay over $100 even used for the whole air tube. The piece the hose clamp snaps into that is held on by the screw and nut. If anyone has access to one please let me know.
