I have a '08 Sierra with the 5.3.  The motor has 231,000 miles on it.  The check engine light has been on for awhile with no drivability issues.  Yesterday it started blinking and the truck starting running rough.  After a few minutes it stopped blinking and the truck ran ok again.  It stumbles at idle now.  I pulled the codes and here is what came up:  P0606, P0300, P0521 & P069E.  Any idea what might cause this concoction of codes?
Please  ALWAYS post the code definitions, There are over 18000 possible codes and no one knows them all. PO300 is random misfire and caused the light to blink before setting a hard code. Start with the basics for that 1, check the plugs, wires and coils first then the injectors if all that is a-ok. A scan tool that does live data may show you which cylinder has the misfire
The first and last are related to your fuel pump.  The P0606 says that your fuel pump control module has failed.  A replacement has to be programmed to your truck.  It's above your spare tire.
The P0521 is related to your oil pressure sensor.  As long as the wiring is good, the usual culprit for this code is that your ECM has gone bad but it could be the sensor.
I would replace the sensor first if you don't have the proper diagnostic tools and for me, I like to remove the intake and change the sensor.  It takes a little longer but I don't have to do the job blindly and kill my back being a contortionist to get back there.
    • First of all sorry, I know there are a ton of transmission temperature threads...   My truck is a 2025 LZ0 High (10l89 10-speed) High Country with NHT max trailering package. The NHT package is supposed to have "enhanced cooling."   Normally the trans temp sits around 200. It seems like with any real stress it quickly jumps into the 220s (for example climbing a grade unloaded at lower speeds). I haven't towed much with this truck, but I'm concerned if it gets this hot unloaded.    I've tried a few different things to keep the temps down (tow/haul mode, sport mode, low range when that makes sense) and nothing seems to affect it.    I'm curious if others are the same behavior or if anyone has found techniques to keep the temps down. It seems like it just can't handle reduced airflow at lower speeds, even with relatively light loading.    Thanks!
    • I'm at 105,000 miles on my baby Duramax. No issues yet. I hit 31 mpg's traveling through hilly terrain to a project in Colorado. I will buy another 3.0. I'm not concerned.
    • I'm glad you have 14,000 trouble free miles. Frankly though, that's a really low bar. A bare minimum of 80,000 trouble free miles as the norm (rare exceptions always exist) across the whole model year should be a starting point. Good maintenance habits should push these past the 100,000 mile mark with only the most minor of issues. Let's hope GM truly leveled up the quality game with these new engines and exploding engines under 50,000 miles are gone.
    • This is exactly the reason our EV has consumed so much of my driving. I don't want to fire up a cold diesel or gas engine just to drive 2 miles up to the store. It's arguably terrible for an engine. If I'm not driving at least 10 miles and don't need to do truck things, the truck stays parked.   Enter the EV. It's immediately heating or cooling the cabin as needed (heat pump). An engine doesn't need to warm up or be driven gently. I can tear off in it with ZERO guilt. Move the car 1/4 mile from store to store and not think "gee, I'm short-cycling a lukewarm engine".   It doesn't idle in a drive-through. Doesn't idle at stop lights. (OK, neither would the diesel, if I let stop-start have its way, but I don't).   Even moving it out of the garage to wash it... HA! It doesn't need to be started just to move 40 feet. I have cars that I will actually put in neutral and push (no start) in/out of the garage or shop if they absolutely HAVE to be moved. My nice Camaros.
    • Some trailer plugs don't work. This one worked for me. Been using it for two years no issues. Amazon.com: Reese Trailer Plug Adapter, 7-Way Male Plug to 7-Way Female Plug, LED Lamp Out By-Pass, Plastic, Black, Each : Automotive
