Wondering if anyone here has used the Hellwig Helper Springs (either the pro or the ez990 series) or other helper springs?
will it increase the rake on the truck? ive read people have had up to 2 inches of increase height after install... ?
We are going to buy a larger travel trailer (30-32' overall length, around 7000 lbs with around 800 tongue weight), the current trailer is about 25' overall and 5000lbs.
Im towing with a 2021 TrailBoss w/6.2L with a 1.75" level kit on the front. im looking for some helper springs with the sag and more control while towing the larger trailer.
thanks for any info/help
Edited by Flyboygt
I just installed the Roadmaster suspension setup in the rear of my AT4 for towing our 30' travel trailer. It functions similarly to a helper spring, but maybe a bit more dynamic. It, like all helper springs, will increase the ride height in the rear. The Roadmaster is adjustable, at my setting it lifted the rear a little over an inch. Helper springs specifically will stiffen it up back there as well. Helper springs working in conjunction with a good weight distribution hitch makes a HUGE difference in towing feel and riding level. Worth it imho!
Thanks I appreciate the info. I've been comparing the roadmaster vs the hellwig. great to know that the ride height is adjustable. I didnt know that
def getting a weight distribution hitch.
These kill the ride quality overall. I would highly recommend doing what I did. Buy the airlift airbags with the wireless compressor. You lose no quality and get zero squat out of the truck. In addition, it raises it when you need it.
Thanks man. Ya I think I'm headed the way of airbags. I don't want to have an active spring when I'm not towing.
    • Because single shot injectors are ancient and multi hole injectors provide smoother running engines and sharper throttle response due to the fuel being atomized better..the best lead I have is a 24lb blue top injector almost everything matches up but the injector will put out about 26lb/hr which is just outside the gm threshold.figured id ask here to see if there was an absolute answer
    • Why is my question?   Any change in injectors requires a tune. Unless you are going back with the OEM part number or a newer part number of that same injector.   Any size difference or type difference like the EV6 style injectors all have different injector data for them. And there is no EV6 injector that matches the factory 25 lb/hr size that your truck comes with. I've been messing with these trucks and tuning them for a long time and what you trying to do doesn't exactly make sense to me.
    • My 6.6 gas lt8 had lifter noise with 28000 miles bought new 2026 and while driven to dealer it threw #1 rod bearing “HD my ass” good luck with yours i hope it don’t turn a rod bearing!
    • When a condition becomes a business model.    https://www.gm-trucks.com/gm-truck-suv-incentives-pricing-2026/   Zane posted this in "Latest Articles".    The honest bottom line   Truck buyers have spent three years assuming this is a temporary condition that will break once inventories normalize. GM just presented it to investors as a durable strategy, on a chart, as evidence of good management.   Inventory did normalize. GM is at 511,000 units and squarely inside its own 50 to 60 day target. The discounts still did not come back, because the low incentive number is the goal rather than a symptom of shortage.   Plan your purchase around that reality instead of waiting for it to change. Follow our ongoing GM News coverage for pricing and incentive changes as the next-generation trucks land.
    • Thought it was raining this morning when we woke. Nope. Dew point was over 80 F and humidity 98%. Zero visibility distance. Everything was 'sweating'. I've seen rain come out of clouds but never out of Pepper or the tree trunks.    Wicked storms just missed us sliding off to the east but by blocks. Heat index about 110 F with air temp in the 90's.    This is  our third wave this month of multiple days of this type of weather. And yet the grass is going dormant and the ground is cracking this side of the street and water up the the hood opposite. Just weird stuff going on.
