Just got my front and back bumpers, grille and hood vent all wrapped to match the paint color of my truck, got rid of the chrome, but they didn't wrap the parking sensors on the front and back bumpers. I'm just wondering if there's a way to paint over the chrome on them without messing them up and making them just go off constantly? Or if there's any way to replace them with white ones?
Thanks and God Bless!
Those are already painted silver.  All the park sensors come bare primed and must be painted.
Refinishing those in white "might" be a challenge beacuse there are limitations on how much paint can be applied to the sensors.
So I assume they come from factory with that chrome finish to match the factory chrome bumpers? Have you ever heard of a way to paint over chrome? I always hear its hard to do, I wonder if there's a way to strip the chrome off (assuming its "plated" in chrome)
I'm not sure how they apply the chrome to bumpers and sensors, but my old 04 2500HD grille the chrome started peeling off and it was a weird white color almost cream color plastic was under the chrome "plating". I then stripped it all off and sanded a bit and repainted it black and had no issues. But that was a lot less technology on those trucks, I'm scared to mess with something that can just ring through my speakers 24/7 if I mess it up lol
Previous owner re-painted over mine. They acted weird - I was able to peel/sand off the extra coat/layer of paint, they resumed working correctly.
You can also get painted ones on Ebay, make sure the part numbers are otherwise the same as yours or they won't work.
if they are anything like the Ram sensors, they come black and are painted silver to match the chrome bumpers.
I had to replace 2 of them on my Ram and had to paint them
    jaszr2
    jaszr2
  • Who's Online   6 Members, 0 Anonymous, 550 Guests (See full list)
    • No such thing as regenerative braking on a pure ICE vehicle.     Regenerative braking is the re-capture of energy from electric motors and stores it in the battery pack.  So hybrids, PHEV and EVs have regenerative braking.     What you are seeing is the charging system changing modes is all.  Its likely entering charge mode for some sort of reason is all.  All of the charging modes will be listed below.   As for L10 vs D.  L10 turns off automatic grade braking.  L10 puts you in control of grade downshifts where in D it will automatically do it based on brake pedal position and other factors.  Otherwise L10 and D drive exactly the same aside from that one aspect.    Battery Sulfation Mode The BCM will enter this mode when the interpreted Generator output voltage is less than 13.2 V for 45 minutes. When this condition exists the BCM will enter Charge Mode for 2–3 minutes. The BCM will then determine which mode to enter depending on voltage requirements.   Charge Mode The BCM will enter Charge Mode when ever one of the following conditions are met:   Windshield wipers are ON for more than 3 s. Climate Control Voltage Boost Mode Request is true, as sensed by the HVAC control module via serial data. High speed cooling fan, rear defogger, and HVAC high speed blower operation can cause the BCM to enter the Charge Mode. The estimated battery temperature is less than 0°C (32°F). Battery State of Charge is less than 80%. Vehicle speed is greater than 145 km/h (90 mph) A current sensor malfunction exists. System voltage is determined to be below 12.56 V When any one of these conditions is met, the system will set targeted generator output voltage to a charging voltage between 13.9–15.5 V, depending on the battery state of charge and estimated battery temperature.   Fuel Economy Mode The BCM will enter Fuel Economy Mode when the estimated battery temperature is at least 0°C (32°F) but less than or equal to 80°C (176°F), the calculated battery current is less than 15 A and greater than −8 A, and the battery state-of-charge is greater than or equal to 80%. Its targeted generator output voltage is the open circuit voltage of the battery and can be between 12.5–13.1 V. When fuel economy mode is active, the generator is not charging, only maintaining open circuit battery voltage. The BCM will exit this mode and enter Charge Mode when any of the conditions described above are present.   Headlamp Mode The BCM will enter Headlamp Mode when ever the head lamps are ON (high or low beams). Voltage will be regulated between 13.9–14.5 V.   Start Up Mode When the engine is started the BCM sets a targeted generator output voltage of 14.5 V for 30 s.   Tow/Haul Mode (if applicable) Pressing the Tow/Haul Mode button located on the center stack, the vehicle system voltage is raised and the remote (non-vehicle) battery will be charged. Having the headlamps on will raise the system voltage and if the Tow/Haul button is applied it will not serve any purpose. The voltage is regulated between 13.9-14.5 V.
