Is this an easy fix for a do it yourself mechanic?  Replaced many before...but my boss did new pads on his 2019 and it messed all up due to the sensors, he had to take it to the dealership, to have it computer re calibrated, and ended up having to replace calipers, roters, sensors and everything, cost him $3300!  This is on my brothers 2017 1500.
This should be a pretty simple job. You may have to remove the caliper in order to remove the line & install new one. I'm not sure what your boss did on the '19 to require that. Maybe some else will chime in here to verify
Sounds like he didn't know what he was doing to cost himself $3,300. You have to really ruin the calipers to cost that much to repair.
Installing a new brake hose is easy. Unbolt the line to the caliper and then use two wrenches to loosen the hose from the hardline by the frame. Connect the new hose in reverse order and bleed that line of air at the caliper with the bleeder screw. Shouldn't take more than 10-15min to be honest.
Newer vehicles can be a mystery even to do simple things. I had new tires put on the Odyssey. I spent 15 minutes trying to get the tire pressure light to calibrate. Frustrated I was just going to go to the dealer. Two minutes of driving the light went off on its own. My CRV and other vehicles you have to go through the menu and hit buttons. Several do it yourself jobs on vehicles I’ve done over the years the internet has saved me time and frustration. My experience with automobiles and equipment is vast. There’s not a thing I would do on a vehicle without checking the net first. Have you read the articles about farmers and John Deer tractors? Don’t assume anything is easy or straightforward.
    • when it's greyed out that is it's way of telling you that it's downloading the patch in the background. Eventually it will be fully downloaded and then it will prompt you at ignition shut down to run the update. I highly recommend doing the update once you get home and can run it a few times. I've had several issues with updates not going the first time around and I had to retry the update multiple times in my driveway before it was successful.   Some updates are huge and take awhile to download. You can help it by connecting to your home WiFi and keep the truck on service mode for the ignition and keep it alive for awhile on a battery charger too. There are specs it needs to be in for updating such as a full enough battery charge, no running ignition, etc.
    • I am not techy at all but wondered if you have the truck running but sitting still in park as some functions gray out as soon as the truck is moving. I believe in the settings for updates you can choose for it NOT to update and I wonder by chance if maybe that was chosen before and now it won't allow you to chose to press update, I think that is back in the settings menu where it has all the items one wants on or off etc. Also I assume you have a wifi connection and checked that it has some signal strength, not that it would have anything to do with the grayed out updates choice in that case. What I am thinking out loud of here may be be of no value but thought I would suggest it, sometimes it can be the simplest thing that resolves an issue.
