2025 1500 sierra
RPO codes for each tri level
Seats listed by RPO code
2025 1500 Silverado
RPO codes for trim levels
Seat for each trim level
Full Grain is the actual full leather hide vs the bonded leather previously talked about. Bonded leather doesn't last as well as full grain. I bought some aftermarket Alea seat covers and they claim they are Italian leather. They don't feel like it. I haven't gotten them installed yet either.
As for leather care, I was told the BEST treatment for leather is mink oil. Some cleaners I have bought have it in it, but I was at my local Menards in the cleaning products section and they had leather cleaners and conditioners and actually had mink oil bottles there.
