On 6/9/2023 at 7:33 AM, lsttype said:
Finally towed my 9k camper with my 2020 6.6 gasser. Not trying to hijack thread. I just got rid of my diesel because of all the issues they currently have. Anyways I was very pleased with the power and I liked the 6 speed. I bet the 10 speed is even better. My wife has a 22 F250 with the 7.3 Godzilla but we are scared to tow with it because of all the lifter failures. We are so concerned we're tempted to trade it on a new GMC 6.6 gas with the 10 speed.
I loved my 21 gmc gasser as well! I'd hate to own an HD truck like your wife's ford and afraid to tow with it 😕
Get her a 10 speed!!!
On 6/8/2023 at 9:31 PM, UWSkier said:
wondering if you stayed in 7th or 8th gear at 65 MPH.  On my 8 speed half ton, I run in 6th gear at that speed and feel I could most benefit from another gear between between 3 and 5.
I just towed a decent load with my 24 today.  It was only like 11,000 lbs but it was the first thing I've towed.  At 65 mph it was pretty much staying locked into 7th/8th.  Running about 2100 rpms.  It would drop to 9th every once in a while, but wouldn't stay there long. In comparison my 23 with the 6-speed would pretty much stay locked into 5th running about 1800-2000ish from my memory.  I really wish GM would let us know what gear we are in.  It's very annoying.  The Allison is so smooth shifting that unless you are watching the rpms's you don't really know it's shifting.  The 10 speed is "busier" than the 6 speed but not annoyingly so.  It does keep it in the power band.  To be honest with you if felt like maybe I was being held back a little on power. I wonder if GM has some programming in the ECU for the first few thousand miles on towing.  I only have 800 miles on at this point and I know as my 23 got more miles on it performance and mileage got better.  I just feel like at times it could have easily ran in 8/9th gear but kept it up more in 7-8.  Reason I say this is my 23 would hold 5th almost all the time unless encountering a hill when towing weight like this.  It will be interesting to see how this pans out.  I watched a few videos on YouTube of JB Reviews and he kind of mentioned the same thing.  He felt like performance was getting better with more miles on his 24 gas.  There is no doubt the 10 speed is helping keep the gas engine in a tighter power band though.  I can't believe how smooth this transmission is.  GM did a great job with the tuning.  Not clunky at all.  My 6 speed was a little clunky at times when slowing down but did shift very smooth as well.
If you ever had a tune, even a hand held. You wouldn’t believe how much performance is held back. So absolutely there’s constraints.
I once put a Blackbear tune on my 2005 6.0 gas.  It woke it up significantly.  That was with a 300 hp 4 speed!
I test drove a gasser/Allison combo this morning and was surprised how un-peppy it felt compared to my 2016 5.3L 8 speed, which doesn't exactly press you back in your seat either.  I imagine the transmission would learn how I drive over time and respond a bit more.  It felt like it needed a little more coaxing to scoot than the half ton.
Neither hold a candle to my programmed 2006 Titan though.  Man, I miss driving that truck some days.
I went from a 2018 1500 5.3 6spd to a 2021 3500 6.6 6spd to a 2024 3500 6.6 10 spd and I can say that every one was a step up as far as performance. While the 5.3 was okay it lacked throttle response (dead pedal) and the DOD/AFM was a PITA. Both my 6.6 gassers were more responsive. The best thing they did for the 6.6 gas was leave the DOD/AFM crap off of it.
  • Like 3
    ncleg
    ncleg
  • Who's Online   5 Members, 0 Anonymous, 781 Guests (See full list)
    • I have a Retrax pro that I first had on my 2020 chevy and transferred it to my current GMC.  It stays in the garage most of the time, so hard for me to judge it's long term weather resistance.  It still works perfectly, been very durable.  It doesn't see oil patch usage, but it's not a mall queen.  It keeps most things mostly dry (small leaks) and the security of it is enough to slow someone down but not keep them out for long.  I would buy one again, it works for me.
    • Thanks to the convenience of Amazon, I was able to get a few things done to the truck today.  I installed Carquest Premium oil and air filters with five quarts of Mobil1 High Mileage 10-30 along with a quart of Pennzoil Platinum 5w-30 I already had.  The latch for the flip up center console lid was broken so I replaced it along with the power mirror switch.  I found my push retainer assortment this morning and reattached the plastic under the bumper and it was only held on with a few screws and retainers.  Then I programmed a new remote keyless entry fob so I can lock my dog in the truck when I take her out with me (I've got to keep the air going for her since it's been in the 100s).  Finally, I ordered some LED interior bulbs and replaced the reading lamps.  The front lights are working fine while one of the back lights only works intermittently and the other not at all.   While under the truck, I found the source of at least one of the noises: the sway bar links need replacing.  I ordered a set of Suspension Dudes links with Code Red bushings.  Never heard of them, but they're made in the USA and have decent reviews.  While making yet another Amazon order, I went ahead and added a set of front tow hooks.  I went with red, since that's the color of the sway bar link and bushings and it should look decent enough on a black and chrome truck.  Speaking of which, it doesn't bug me much, but the passenger side mirror has a chrome cap while the driver side doesn't, so eventually I'll make them match one way or another.  Oh, and I ordered a $20 TPMS reset tool.  No idea if it will do anything for my sensors but it was cheap and will work for the Ford Transit Connect as well.     For tradition's sake, I ordered a new oil change wrench.  I kept the Snap-On 9/16"x15mm GM wrench I bought when I was 18 in the 2006 GMC from the time I bought that truck until the truck was lost.  While I was tempted, there's no need to spend $80 for a new SO wrench, or even $50 with shipping for a used one on Ebay.  I just bought a Duratech 15mm extra-long ratcheting wrench to do the job as needed.  It works, and if I like that wrench enough, I'll buy the set.
    • The recall is for exactly this issue - those drain holes combined with the limited environmental capability of the tailgate electronics card inside the tailgate were a problem. The “safety issue” was the potential for the tailgate to spontaneously open, but all kinds of tailgate misbehavior can occur from water contamination of that control card.    There is no real fix yet. The initial recall just disabled the tailgate. Later, when parts became available, they would replace bad parts with new parts of the same bad design. My dealer is going nuts because the few times I let them get their hands on my truck, my tailgate is off due to a slide-in camper installation. They really want to cut my tailgate wires, but I won’t give them the chance. I will let them get their dirty hands on it when a real fix (redesign) is available.  My tailgate, which works just fine with sealant plugging the drain holes, will remain safe in a dry storage crate until then.
    • Yes your absolutely right, I been looking at the 4 inch BDS one and it acutely states you can use the stock 20’s just not the 17’s or 18’s, I also didn’t realize that with my 275/60r20 stock wheels I’m already running 33 inch diameter wheel setup lol so I can just run my stock wheels and tires atleast to start.
    • I would expect that to be lift-kit dependent.  If the kit has interference issues w stock wheels, then the kit/manufacturer should indicate that somewhere.
