I need to do a frame swap on my truck. I have a 2000 2500 extended cab with an 8ft bed. Vin is 1GCGK29U0YE350124
Can anyone tell me what the body mount measurement is? I see my wheel base is 143.5. Beyond that can anyone tell me what other frames would be compatible when I'm looking around. Does a crew cab short bed work or not other trucks like sierra or something and a year range? I'm having issues looking things up myself. Thank you all in advance
You'll need to find an extended cab, 8' box frame, at least from a 2500,3500 GMT800.  It'll need to be a 4wd frame if your truck has 4wd.
reg, extended cab and crew cabs all have different body mount locations.
I have no idea if/how the frames varied over time, or if they are different between gm & chev.  From replacing body panels on my '04, I've found that earlier parts may have missing holes, or braces, or welded on nuts, that the parts that came with my truck have & used, and that newer parts may have/use holes/braces/welded on nuts that were used on newer trucks, but were not used on my truck, but the part was backwards comnpatible (so if there was something used on my truck, it was present on newer parts, even if the truck they were originally from didn't use it).
You might hit up a dealer, or online used parts places, to see what they say about frame compatibility.
Thank you both, I will go to that link on my pc, hard to navigate on my phone. And I I've tried to look up online for compatibility but they want that last number for the body mounting holes. Guess I can look and call them to see if it's the same set up and if it's not I know I have the other option lol
  • 3 weeks later...
Your options are quite limited.  You have a non HD 2500, so for an extact matching frame you'd need 99-03(maybe at the most) and non HD 2500.  You "might" be able to make it happen on an 01-06 2500 HD frame as well, but that might take some extra work as the HD trucks, the bodies sat 2 inches higher.
Also, extended cab 8ft box is NOT a 143.5" wheelbase.  Your wheelbase is 157.5"
I think its time to go out west and get a new, rust free truck to replace yours with.
Edited by newdude
    Frank V
    Frank V
  • Who's Online   6 Members, 0 Anonymous, 1,398 Guests (See full list)
    • Folks, Have a great new 2026 WT  (std cab, 2.7/4WD) w/base 40/20/40 mech adj bench "fake buckets"  (with lower and upper center console) heavy vinyl seats.  Overall the seats are very comfortable and the vinyl is heavy and appears less likely to 'split out'. Am very tall (6'5")  + a bad back/osteporosis/former hyperparathyroidism so ease/range of movement is a bit restricted.  The truck rides a bit high and I use a nerf step bar w/my left foot to step in, then I put right foot/leg in, drag my butt in  & get seated.  Worked fine in my 2018 RAM quadCab. But I end up dragging my butt over the left raised sidecushsion area of vinyl seat, and due to texture there's fair amount of traction on slide inward.  (ArmorAll didn't improve.) If the seat were even ~1/2" - 3/4" lower it'd be helpful, but base seats just have the forward/backward underseat bail and the side lever for tilt which really doesn't affect seat height.   I really don't want to 'de-puff' the left side sidecushion forming the  fake 'bucket'. I know one company sells 'seat elevator blocks':  but is there a simple way of lowering the height of the driver seat instead?   Thanks Bill W San Jose
    • I have a basic 2026 1500 WT  (2.7L/4WD reg cab shorttbed). Comfy, generally happy with electronics/radio - but is there a way I can add switches to steering wheel right-side position (curr. empty) so I can adjust volume, push phone button to voice dial, etc? Bill W San Jose
    • The curb weight on a 1 ton crew cab long bed is around 7k lbs.  Now, I don't know where you went to school but 9k is not more than 2x 7k lbs. More than 2x 7k lbs would be 14k+.   With that said, obviously yes you're going to feel a 9k lb trailer when slowing down.  I already said, when accelerating.  When changing lanes?  No.  But if you look at the context of what was quoted, the original person said, "after a mile or two..." which means that would be after the accelerating portion and you're driving a generally steady pace.  Please do learn to read and comprehend.
